3 Replies Latest reply on Apr 15, 2011 11:18 AM by Claus Richter
    flv video not playing in AIR application
    giuseppe.frau
      Hi everybody,
      i'm building a tutorial with flash catalyst and since the 20 states limit i've split it up in different swf files that I import and show in different states.
      One of these swf (which i built with Catalyst as well) is supposed to play a flv video, and it actually plays it if i run it alone.
      The problem comes when i build the overall tutorial: it works perfectly with the "run project" command in Catalyst and with the run-local version but the video won't play if i try the AIR application.
      Does anyone have any suggestion?
      NB: the "asset" directory created with the AIR application installer does contain the flv file (i didn't have to put it there manually)
      Thanks in advance for your help,
      Giuseppe
        • 1. Re: flv video not playing in AIR application
          Claus Richter
          Hi Giuseppe,
          this seams to be a bug of some sort. I have the same problem.
          I want to play a flv inside an .sw in Adobe Air. Result: Connection Error!
          Hopefulle there is someone out there to help us!
          Claus
          • 2. Re: flv video not playing in AIR application
            giuseppe.frau Level 1
            Thank you for your reply Claus.
            I also think there's some sort of bug, but may I ask you where did you get the connection error message? Cause in my case i just don't get any feedback when I try to play the flv file. Is there any console or log file I can check?
            Giuseppe
            • 3. Re: flv video not playing in AIR application
              Claus Richter Level 1
              Hi Giuseppe,
              what I do is:
              1. create a file using Captivate
              2. i place a .flv video in this file
              3. save the file as .swf
              4. then i go to dreamweaver and put the swf on a html page.
              Now:
              when viewed in a browser, everything runs fine.
              when i pack this page into an air application (in dreamweaver) the video does not appear,
              instead I get this "Connection Error"
              I do not know a console or log file.
              However, I learned that there is a .xml file located in the same AIR folder that you publish in.
              In this .xml file there is a setting :transparency. in order to playt a .flv file this must not be be "transparent"!
              (i read this somewhere in the net)
              hope that helps
              I will talk to a professional programmer, if I have any news, i will let you know
              Claus
