2. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
FLAdude Apr 12, 2011 6:24 AM (in response to jendabek)Thanks, Jen.
I'm working on getting the upgrade right now.
Only thing is I go to get the upgrade and it says something about pre-order.
That confuses me a bit. Anyone know if you can get the upgrade right now or when it will be available?
If I go to get it and choose download will I be able to download it right now?
3. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
jendabek Apr 12, 2011 6:32 AM (in response to FLAdude)I don't know if this is the exact date but on Amazon there is the note "This item will be released on May 27, 2011."
4. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
FLAdude Apr 12, 2011 6:42 AM (in response to jendabek)Hmmm I see. So has nobody gotten the actual upgrade?
This is just an announcement that it will be released in a month or two? In that case I guess I will just have to wait and buy it when it's available...
5. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
jendabek Apr 12, 2011 7:08 AM (in response to FLAdude)Update is not available yet but you can use it's new export functionality right now.
You just need to download AIR 2.6 SDK which is the tool to convert swf to iOS (ipa), Android (apk) etc., and compile your project manually via command-line.
The Flash CS 5.5 will compile it the same way but it will allow us to config everything via graphic interface.
There are a lot of threads in this forum about using AIR 2.6 SDK, just look at the list. But I recommend you to use the official documentation which is very understandable and easy to follow.
6. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
fcolaco.com Apr 13, 2011 1:40 PM (in response to FLAdude)Hi.
Just got an app rejected because the popover to select the pics from the camera roll on the iPad always appears on to-left corner, and the arrow doesn't point anywere, and should be pointing to the button which activated it. That "does not comply with the Apple iOS Human Interface Guidelines, as required...". On the iPhone there's no issue because it takes over the whole screen. More from the apple rejection message:
"Specifically, we noticed your app contained popover elements that didn't point to the element that revealed them. To avoid user confusion, a popover element's arrow should point to the element that revealed it."
So, thanks for including the CameraRoll functionality, but it will be useless in the iPad apparently
Any workaround to make it appear at a specific place when calling myCameraRoll.browseForImage() ?
Fernando
7. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
jendabek Apr 13, 2011 1:45 PM (in response to fcolaco.com)Thanks for sharing this issue, if there is no way to workaround it, report it as a bug / feature request, maybe Adobe will look at it (I don't think they read this thread)...
https://www.adobe.com/cfusion/mmform/index.cfm?name=wishform
8. Re: Does iPhone Packager CS 5.5 support camera access and LOADING images from the camera roll?
Pea Apr 13, 2011 6:20 PM (in response to fcolaco.com)Fernando - please post the same issue only in one place. People do not appreciate forum spam.
