1 Reply Latest reply on Apr 12, 2011 10:49 PM by ArneAtAdobe
    FormDataIntegrationClient.importData() deletes layout information
    ArneAtAdobe Level 1
      I have a pdf document in which every field that has changed is marked in red. I extract XML from it, change one field and import the data into the same pdf document. After that all fields that were red before are not anymore.
      Code example:
      inPdfDocument.copyToFile(new File("/home/arne/fooooooooo.pdf"));          // <-- contains red fields
      FormDataIntegrationClient dataClient = FormDataIntegrationClientFactory.createClient();
      Document inXmlDocument = new Document(inXML);
      Document resultPDF = dataClient.importData(inPdfDocument, inXmlDocument);
      resultPDF.copyToFile(new File("/home/arne/barrrrrrrrrrrr.pdf"));                    // <-- contains no red fields.
      How can I add data to a pdf without losing layout information?
      Thanks in advance for your answer.
      Cheers,
      Arne
