2 Replies Latest reply on Apr 12, 2011 11:47 PM by John Hawkinson
    Get taged text
    xmlapi Level 1
      In each textframe on each page, I have a textframe called mainText. In the maintext story editor, I have many tags. One of the tags is OfficeNo.
      How do I use a script to extract the text out of this tag?
        • 1. Re: Get taged text
          John Hawkinson Level 5
          Traverse the XML tree associated with your textframe looking for all elements that contain the tag.
          Untested example:
          function traverse(t, p) {
              var r = [], i;
              if (p(t)) {
                  r = r.concat(t);
              for (i=0; i<t.xmlElements.length; i++) {
                  r = r.concat (traverse(t.xmlElements[i], p));
              return r;
          var nodelist, i;
          nodelist = traverse(maintext.associatedXMLElement,
                     function(n) { return n.markupTag.name=="OfficeNo"; });
          for (i=0; i<nodelist.length; i++) {
               alert("Text is "+nodelist[i].contents);
          Alternatively, export the document's XML tree and then use a real XML tool on it, like an XSLT processor or an XPath evaluator.
          • 2. Re: Get taged text
            Whoops, sorry, that's wrong. Or at least, much too general.
            In this case you can use InDesign's limited XPath facilities (they have problems in some cases, including the last time I had to do this, but not for something this straightforward):
            var nodelist, i;
            nodelist = maintext.associatedXMLElement
              .evaluteXPathExpression("//OfficeNo");
