4 Replies Latest reply on Aug 15, 2006 7:34 AM by Scnoods
    Rollover not working due to audio cue-point
    Scnoods
      I have a problem with a rollover state not working on a button when the play head is paused due to a cue-point in the audio file.
      I have a basic swap cast member scrip attached to the sprite (button) but since the playback head is paused on the cue-point the swap cast member script doesn't seem to be recognised (only works when the play head is moving).
      Is there any fix/lingo I can add to my sprite script that will tell it to ignore the cue-point/play-head..?
      I've got to get this job out the door asap, so any help here will be greatly appreciated.
      Thanks.
        • 1. Re: Rollover not working due to audio cue-point
          Scnoods Level 1
          Well, seem to have found a fix.
          I've added a 'go the frame' after the cast member swap - seems to work okay?!
          on mouseEnter me
          sprite(me.spriteNum).member = member("Button Rollover")
          go the frame
          end
          on mouseLeave me
          sprite(me.spriteNum).member = member("Button")
          go the frame
          end
          If anybody know any known issues regarding this I'd be happy to hear them.
          • 2. Re: Rollover not working due to audio cue-point
            BSpero Level 1
            I would use a frame script and have it repeat while it waits for the cue point to pass. When I have used the tempo channel for cue points, it always messes up any animation I have on the stage.
            • 3. Re: Rollover not working due to audio cue-point
              Level 7
              I've said this probably 20 times in this forum. The Tempo channel should be
              scrapped. It wastes more people's time like yours when some basic Lingo
              will avoid all issues.
              Craig Wollman
              Word of Mouth Productions
              phone 212 928 9581
              fax 212 928 9582
              159-00 Riverside Drive West #5H-70
              NY, NY 10032
              www.wordofmouthpros.com
              "Scnoods" <webforumsuser@macromedia.com> wrote in message
              news:ebshup$m5p$1@forums.macromedia.com...
              >play
              > script
              > greatly
              > appreciated.
              > Thanks.
              • 4. Re: Rollover not working due to audio cue-point
                Scnoods Level 1
                Thanks for the advice.
                I need to brush up on my lingo, and try to scrap some of my old methods (like using the tempo channel).
