0 Replies Latest reply on Apr 12, 2011 12:06 PM by ledroff
    [svn:cairngorm3:] 21062: * removed unnecessary locales instructions
    ledroff Adobe Employee
      Revision: 21062
      Revision: 21062
      Author:   ledroff@adobe.com
      Date:     2011-04-12 12:06:00 -0700 (Tue, 12 Apr 2011)
      Log Message:
      • removed unnecessary locales instructions
      • removed the popup/PopUpFactoryTest.as (as part of flex3 support drop) to fix the unit test
      • added the txi internal repo to enable transparent integrationDMS build at least internally
      • added the header.txt in libraries/src/conf to allow license check to work on atomic library builds
      Modified Paths:
          cairngorm3/trunk/libraries/Contract/.actionScriptProperties
          cairngorm3/trunk/libraries/Contract/pom.xml
          cairngorm3/trunk/libraries/ContractTest/.actionScriptProperties
          cairngorm3/trunk/libraries/Integration/.actionScriptProperties
          cairngorm3/trunk/libraries/Integration/pom.xml
          cairngorm3/trunk/libraries/IntegrationDMS/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationDMS/pom.xml
          cairngorm3/trunk/libraries/IntegrationParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/IntegrationParsley/pom.xml
          cairngorm3/trunk/libraries/Module/.actionScriptProperties
          cairngorm3/trunk/libraries/Module/pom.xml
          cairngorm3/trunk/libraries/Navigation/.actionScriptProperties
          cairngorm3/trunk/libraries/Navigation/pom.xml
          cairngorm3/trunk/libraries/NavigationParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationParsley/pom.xml
          cairngorm3/trunk/libraries/NavigationSpringAS/pom.xml
          cairngorm3/trunk/libraries/NavigationSwiz/.actionScriptProperties
          cairngorm3/trunk/libraries/NavigationSwiz/pom.xml
          cairngorm3/trunk/libraries/Observer/.actionScriptProperties
          cairngorm3/trunk/libraries/Observer/pom.xml
          cairngorm3/trunk/libraries/ObserverParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/ObserverParsley/pom.xml
          cairngorm3/trunk/libraries/Persistence/pom.xml
          cairngorm3/trunk/libraries/Popup/.actionScriptProperties
          cairngorm3/trunk/libraries/Popup/pom.xml
          cairngorm3/trunk/libraries/PopupParsley/.actionScriptProperties
          cairngorm3/trunk/libraries/PopupParsley/pom.xml
          cairngorm3/trunk/libraries/Task/.actionScriptProperties
          cairngorm3/trunk/libraries/Task/pom.xml
          cairngorm3/trunk/libraries/Validation/.actionScriptProperties
          cairngorm3/trunk/libraries/Validation/pom.xml
          cairngorm3/trunk/libraries/pom.xml
          cairngorm3/trunk/pom.xml
          cairngorm3/trunk/samples/todo/todo_flex/todo_flex_core/pom.xml
      Added Paths:
          cairngorm3/trunk/libraries/src/
          cairngorm3/trunk/libraries/src/conf/
          cairngorm3/trunk/libraries/src/conf/header.txt
