2 Replies Latest reply on Apr 13, 2011 6:07 AM by jscotti
    Problem with populating dynamic drop down
      I am hoping someone can help.
      I have a process that is retrieving a series of codes from a table. It generates an XML which I have bound to a text field on the form. For testing, the field is visible and I can see the XML when I run it.
      However the code that I am using to populate the drop down is not working.
      I'm ot sure if I have done somethin wrong in the process or in the form.
      The XML in the field looks like:
      <?xml version="1.0"?>
                                              <CD type="CHAR">ES</CD>
                                              <CD type="CHAR">EX</CD>
                                              <CD type="CHAR">NF</CD>
      In the JavaScript of the form I have:
      var parsedOther = new Array();
      var taxtypeXML = XMLData.parse(form.Page1.type.assignedOther.rawValue, false);
      var otherList = XMLData.applyXPath(taxtypeXML, "//code[*]/CD");
      if (otherList.length){
           for (var i = 0; i < otherList.length; i++){
           if (otherList.value){
      assignedOther if the text field that has the XML and otherExpl if the drop down fiend.
