4 Replies Latest reply on May 18, 2011 8:16 AM by Haribo2011
    Flash Catalyst won't launch
    Haribo2011
      Every time we try to open Flash Catalyst from Design Premium CS5 we get a reoccuring message As Shown above.
      We have looked over the forums and have found this
      "To repair your Flash Catalyst Fileset you will need to copy  the following directory from a working Flash Catalyst installation into  the same location in your Fileset.
      Import the "temp" directory from:
      /Applications/Adobe Flash Catalyst CS5/plugins/com.adobe.thermo.core_1.0.0.273393/com/adobe/thermo/
      into the same location in your Fileset:
      When completed, the fileset should have the following directories in
      application/
      batching/
      core/
      exceptions/
      headlights/
      interfaces/
      models/
      temp/
      undo/
      utils/
      There are a number of directories in the Plugins directory that start  with "com.adobe.thermo.core…"  Please make sure that you follow the path  correctly."
      Which didn't help. Inside the log file it said this
      "!SESSION 2011-04-13 09:38:35.403 -----------------------------------------------
      eclipse.buildId=unknown
      java.version=1.6.0_24
      java.vendor=Apple Inc.
      BootLoader constants: OS=macosx, ARCH=x86, WS=carbon, NL=en_US
      Framework arguments:  -keyring /Users/g5/.eclipse_keyring -showlocation
      Command-line arguments:  -os macosx -ws carbon -arch x86 -clean -keyring /Users/g5/.eclipse_keyring -consoleLog -showlocation
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:38:41.108
      !MESSAGE An error occurred while automatically activating bundle com.adobe.flexbuilder.project (17).
      !STACK 0
      org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1028)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.start(BundleContextImpl.java:9 84)
      at org.eclipse.osgi.framework.internal.core.BundleHost.startWorker(BundleHost.java:346)
      at org.eclipse.osgi.framework.internal.core.AbstractBundle.start(AbstractBundle.java:265)
      at org.eclipse.osgi.framework.util.SecureAction.start(SecureAction.java:400)
      at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:111)
      at org.eclipse.osgi.baseadaptor.loader.ClasspathManager.findLocalClass(ClasspathManager.java :427)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.findLocalClass(DefaultClassLoade r.java:193)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findLocalClass(BundleLoader.java:36 8)
      at org.eclipse.osgi.framework.internal.core.SingleSourcePackage.loadClass(SingleSourcePackag e.java:33)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClassInternal(BundleLoader.java :441)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:397)
      at org.eclipse.osgi.framework.internal.core.BundleLoader.findClass(BundleLoader.java:385)
      at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.jav a:87)
      at java.lang.ClassLoader.loadClass(ClassLoader.java:248)
      at com.adobe.thermo.application.ThermoApplication.start(ThermoApplication.java:62)
      at org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:193)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLau ncher.java:110)
      at org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.jav a:79)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:382)
      at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
      at sun.reflect.NativeMethodAccessorImpl.invoke0(Native Method)
      at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
      at sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
      at java.lang.reflect.Method.invoke(Method.java:597)
      at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:549)
      at org.eclipse.equinox.launcher.Main.basicRun(Main.java:504)
      at org.eclipse.equinox.launcher.Main.run(Main.java:1236)
      Caused by: java.lang.AbstractMethodError: org.apache.xerces.dom.DocumentImpl.getXmlStandalone()Z
      at com.sun.org.apache.xalan.internal.xsltc.trax.DOM2TO.setDocumentInfo(DOM2TO.java:373)
      at com.sun.org.apache.xalan.internal.xsltc.trax.DOM2TO.parse(DOM2TO.java:127)
      at com.sun.org.apache.xalan.internal.xsltc.trax.DOM2TO.parse(DOM2TO.java:94)
      at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transformIdentity(Transforme rImpl.java:661)
      at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.ja va:707)
      at com.sun.org.apache.xalan.internal.xsltc.trax.TransformerImpl.transform(TransformerImpl.ja va:313)
      at com.adobe.flexbuilder.util.XMLUtil.toByteArrayOutputStream(XMLUtil.java:232)
      at com.adobe.flexbuilder.util.XMLUtil.toString(XMLUtil.java:94)
      at com.adobe.flexbuilder.project.sdks.FlexSDKPreferences.saveToPrefStore(FlexSDKPreferences. java:318)
      at com.adobe.flexbuilder.project.sdks.FlexSDKPreferenceInitializer.initializeDefaultPreferen ces(FlexSDKPreferenceInitializer.java:44)
      at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.runInitializer(Pref erenceServiceRegistryHelper.java:276)
      at org.eclipse.core.internal.preferences.PreferenceServiceRegistryHelper.applyRuntimeDefault s(PreferenceServiceRegistryHelper.java:130)
      at org.eclipse.core.internal.preferences.PreferencesService.applyRuntimeDefaults(Preferences Service.java:367)
      at org.eclipse.core.internal.preferences.DefaultPreferences.applyRuntimeDefaults(DefaultPref erences.java:163)
      at org.eclipse.core.internal.preferences.DefaultPreferences.loadDefaults(DefaultPreferences. java:236)
      at org.eclipse.core.internal.preferences.DefaultPreferences.load(DefaultPreferences.java:232 )
      at org.eclipse.core.internal.preferences.EclipsePreferences.create(EclipsePreferences.java:3 07)
      at org.eclipse.core.internal.preferences.EclipsePreferences.internalNode(EclipsePreferences. java:543)
      at org.eclipse.core.internal.preferences.DefaultPreferences.node(DefaultPreferences.java:150 )
      at org.eclipse.core.internal.preferences.legacy.PreferenceForwarder.getDefaultPreferences(Pr eferenceForwarder.java:130)
      at org.eclipse.core.internal.preferences.legacy.PreferenceForwarder.getString(PreferenceForw arder.java:636)
      at com.adobe.flexbuilder.project.sdks.FlexSDKPreferences.loadFromPreferenceStore(FlexSDKPref erences.java:307)
      at com.adobe.flexbuilder.project.internal.FlexProjectCore.getFlexSDKPreferences(FlexProjectC ore.java:1127)
      at com.adobe.flexbuilder.project.actionscript.ActionScriptCore.start(ActionScriptCore.java:3 80)
      at com.adobe.flexbuilder.project.internal.FlexProjectCore.start(FlexProjectCore.java:320)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl$2.run(BundleContextImpl.java:1 009)
      at java.security.AccessController.doPrivileged(Native Method)
      at org.eclipse.osgi.framework.internal.core.BundleContextImpl.startActivator(BundleContextIm pl.java:1003)
      ... 27 more
      Root exception:
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:38:41.122
      !MESSAGE Application error
      !STACK 1
      java.lang.NoClassDefFoundError: com/adobe/flexbuilder/project/FlexBuilderInstallation
      Caused by: org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter$TerminatingClassNotFoundExce ption: An error occurred while automatically activating bundle com.adobe.flexbuilder.project (17).
      at org.eclipse.core.runtime.internal.adaptor.EclipseLazyStarter.postFindLocalClass(EclipseLa zyStarter.java:125)
      ... 13 more
      Caused by: org.osgi.framework.BundleException: Exception in com.adobe.flexbuilder.project.internal.FlexProjectCore.start() of bundle com.adobe.flexbuilder.project.
      ... 22 more
      ... 27 more
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:38:41.131
      !MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.131
      !MESSAGE Bundle update@plugins/org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.131
      !MESSAGE Missing host org.eclipse.ui.cheatsheets_[0.0.0,9.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.help.webapp.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.132
      !MESSAGE Missing host org.eclipse.help.webapp_[0.0.0,9.0.0).
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.132
      !MESSAGE Bundle update@plugins/org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.132
      !MESSAGE Missing host org.eclipse.update.scheduler_[0.0.0,9.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.132
      !MESSAGE Missing host org.eclipse.team.cvs.ssh_[0.0.0,9.0.0).
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.133
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.133
      !MESSAGE Missing host org.eclipse.team.cvs.ui_[0.0.0,9.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.133
      !MESSAGE Missing host org.eclipse.team.cvs.ssh2_[0.0.0,9.0.0).
      !MESSAGE Bundle update@plugins/org.junit4.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.133
      !MESSAGE Missing host org.junit4_[0.0.0,9.0.0).
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.134
      !MESSAGE Bundle update@plugins/org.eclipse.help.ui.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.134
      !MESSAGE Missing host org.eclipse.help.ui_[0.0.0,9.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.134
      !MESSAGE Missing host org.eclipse.ui.externaltools_[0.0.0,9.0.0).
      !MESSAGE Bundle update@plugins/org.eclipse.help.appserver.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.134
      !MESSAGE Missing host org.eclipse.help.appserver_[0.0.0,9.0.0).
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.135
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401.jar was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.135
      !MESSAGE Missing host org.eclipse.team.cvs.core_[0.0.0,9.0.0).
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:38:41.136
      !MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.136
      !MESSAGE Bundle update@plugins/com.adobe.flexbuilder.utils.osnative.win_1.0.0.273393/ [19] was not resolved.
      !SUBENTRY 2 com.adobe.flexbuilder.utils.osnative.win 2 0 2011-04-13 09:38:41.137
      !MESSAGE Platform filter did not match: (& (osgi.ws=win32) (osgi.os=win32) (osgi.arch=x86))
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.137
      !MESSAGE Bundle update@plugins/org.eclipse.help.appserver.nl1_0.2.0.v20080914043401.jar [171] was not resolved.
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.137
      !MESSAGE Bundle update@plugins/org.eclipse.help.ui.nl1_0.2.0.v20080914043401.jar [175] was not resolved.
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.137
      !MESSAGE Bundle update@plugins/org.eclipse.help.webapp.nl1_0.2.0.v20080914043401.jar [176] was not resolved.
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.138
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.138
      !MESSAGE Bundle update@plugins/org.eclipse.swt.carbon.macosx_3.4.0.v3448f.jar [205] was not resolved.
      !SUBENTRY 2 org.eclipse.swt.carbon.macosx 2 0 2011-04-13 09:38:41.138
      !MESSAGE Another singleton version selected: org.eclipse.swt.carbon.macosx_3.4.0.v3449
      !MESSAGE Bundle update@plugins/org.eclipse.swt_3.4.0.v3448f.jar [208] was not resolved.
      !SUBENTRY 2 org.eclipse.swt 2 0 2011-04-13 09:38:41.138
      !MESSAGE Missing imported package org.mozilla.xpcom_0.0.0.
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401.jar [212] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.139
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.139
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401.jar [213] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.139
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401.jar [214] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.139
      !MESSAGE Bundle update@plugins/org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401.jar [215] was not resolved.
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.139
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.140
      !MESSAGE Bundle update@plugins/org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401.jar [224] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.140
      !MESSAGE Bundle update@plugins/org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401.jar [229] was not resolved.
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.140
      !MESSAGE Bundle update@plugins/org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401.jar [263] was not resolved.
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.140
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:38:41.141
      !MESSAGE Bundle update@plugins/org.junit4.nl1_0.2.0.v20080914043401.jar [266] was not resolved.
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:38:41.141
      !SESSION 2011-04-13 09:42:01.597 -----------------------------------------------
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:42:03.397
      !STACK 0
      ... 27 more
      Root exception:
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:42:03.479
      !STACK 1
      ... 13 more
      ... 22 more
      ... 27 more
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:42:03.488
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.488
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.489
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.489
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.489
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.489
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.490
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.490
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.490
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.490
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.491
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.491
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.491
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.491
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.492
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.492
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.492
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:42:03.494
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.495
      !SUBENTRY 2 com.adobe.flexbuilder.utils.osnative.win 2 0 2011-04-13 09:42:03.498
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.498
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.498
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.499
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.499
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.499
      !SUBENTRY 2 org.eclipse.swt.carbon.macosx 2 0 2011-04-13 09:42:03.499
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.500
      !SUBENTRY 2 org.eclipse.swt 2 0 2011-04-13 09:42:03.500
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.502
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.502
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.502
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.503
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.503
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.503
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.503
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:42:03.504
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.504
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.504
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:42:03.505
      !SESSION 2011-04-13 09:43:16.242 -----------------------------------------------
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:43:17.932
      !STACK 0
      ... 27 more
      Root exception:
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:43:17.936
      !STACK 1
      ... 13 more
      ... 22 more
      ... 27 more
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:43:17.948
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.948
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.948
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.948
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.949
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.949
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.949
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.949
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.950
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.950
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.950
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.950
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.951
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.951
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.951
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.951
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:43:17.953
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.953
      !SUBENTRY 2 com.adobe.flexbuilder.utils.osnative.win 2 0 2011-04-13 09:43:17.953
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.953
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.954
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.954
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.954
      !SUBENTRY 2 org.eclipse.swt.carbon.macosx 2 0 2011-04-13 09:43:17.954
      !SUBENTRY 2 org.eclipse.swt 2 0 2011-04-13 09:43:17.955
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.955
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.955
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.955
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.956
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.956
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.956
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.956
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.956
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:43:17.957
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.957
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:43:17.957
      !SESSION 2011-04-13 09:44:12.535 -----------------------------------------------
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:44:14.440
      !STACK 0
      ... 27 more
      Root exception:
      !ENTRY org.eclipse.osgi 4 0 2011-04-13 09:44:14.444
      !STACK 1
      ... 13 more
      ... 22 more
      ... 27 more
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:44:14.456
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.457
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.457
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.457
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.458
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.458
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.459
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.459
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.459
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.459
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.460
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.460
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.460
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.460
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.461
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.461
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.461
      !ENTRY org.eclipse.osgi 2 0 2011-04-13 09:44:14.462
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.462
      !SUBENTRY 2 com.adobe.flexbuilder.utils.osnative.win 2 0 2011-04-13 09:44:14.463
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.463
      !SUBENTRY 2 org.eclipse.help.appserver.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.463
      !SUBENTRY 2 org.eclipse.help.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.463
      !SUBENTRY 2 org.eclipse.help.webapp.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.464
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.464
      !SUBENTRY 2 org.eclipse.swt.carbon.macosx 2 0 2011-04-13 09:44:14.464
      !SUBENTRY 2 org.eclipse.swt 2 0 2011-04-13 09:44:14.464
      !SUBENTRY 2 org.eclipse.team.cvs.core.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.464
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.465
      !SUBENTRY 2 org.eclipse.team.cvs.ssh.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.465
      !SUBENTRY 2 org.eclipse.team.cvs.ssh2.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.465
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.466
      !SUBENTRY 2 org.eclipse.team.cvs.ui.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.466
      !SUBENTRY 2 org.eclipse.ui.cheatsheets.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.466
      !SUBENTRY 2 org.eclipse.ui.externaltools.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.466
      !SUBENTRY 1 org.eclipse.osgi 2 0 2011-04-13 09:44:14.467
      !SUBENTRY 2 org.eclipse.update.scheduler.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.467
      !SUBENTRY 2 org.junit4.nl1_0.2.0.v20080914043401 2 0 2011-04-13 09:44:14.467
      !MESSAGE Missing host org.junit4_[0.0.0,9.0.0)."
      Without the Quotes
      Any help is appreciated!
      Harry
      After looking throught a little bit more myself I believe it has something to do with "eclipse", I have looked on their website to find no help.
