I am using CF9 and have generated a report using CF Report Builder that has a report parameter that function correctly.
I am trying to be able to get the variable value from the the address line and then display the cooresponding report page.
I have set a default value in report builder and written a simple viewing cfm.
<cfreport template="NC_ImpactReport.cfr" format="pdf">
<cfreportparam name= "CFVarProjectID" value=55>
</cfreport>
When I run this I get the report returned correctly for record '55'
http://website/nc_impactreport.cfm
Another program will have the hyperlink (http://website/nc_impactreport.cfm) with the selected record id(ie55) all on one line.
How do I get the variable value from the address line into the cfm correctly to pass it into the report?
Kurt
If your URL is "http://website/nc_impactreport.cfm?id=55" then your cfreportparam line should be:
<cfreportparam name= "CFVarProjectID" value="#URL.id#">
