This content has been marked as final.
Show 4 replies
1. Re: DPI option in Fireworks CS4?
Jim_Babbage Apr 13, 2011 12:05 PM (in response to Budo Cat)There is no "DPI" setting in FW as it is a screen graphics program. Your steps otherwise are correct though. Just bump up the Pixels/inch (PPI) value to 300. Assuming there are no bitmaps in the design, it should scale upwards fine.
Keep in mind too that FW has no concept of color profiles or CMYK, so printing the image may take some testing.
2. Re: DPI option in Fireworks CS4?
Budo Cat Apr 13, 2011 12:14 PM (in response to Jim_Babbage)Jim,
Thank you. Would Photoshop be the better application then?
3. Re: DPI option in Fireworks CS4?
Jim_Babbage Apr 13, 2011 12:21 PM (in response to Budo Cat)For printing? Photoshop, Illustrator or InDesign.
You may be able to export your FW design to Illustrator by choosing File > Export >FXG and Images. If it's all vector, it should come over fairly well.
If there are bitmaps though, you'll need to pull in the original artwork again to work at the higher resolution.
Jim Babbage
4. Re: DPI option in Fireworks CS4?
Budo Cat Apr 13, 2011 12:52 PM (in response to Jim_Babbage)Thank you!
