4 Replies Latest reply on Apr 15, 2011 7:46 AM by Carl Sun
    CS5 extensions installation problem- XManConfig.xml is invalid
    a2b9180 Level 1
      Not able to install any extension, though I am using CS5 and have installed the same extension for another machine, which is Mac and is running Fireworks CS4.
      After this, next window comes as
      Then the next message, which I am receiving is "The configuration file 'C:\Program Files\Adobe Fireworks CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated."
      Operating System- Windows 7, 32 bit
      I only have Fireworks and InDesign.
      [In case it is helpful: XManConfig.xml file at C:\Program Files\Adobe\Adobe Fireworks CS5\Configuration
      <?xml version="1.0" encoding="UTF-8"?>
      <Configuration>
          <VariableForExMan>
             <Data key="HostNameForCSXS">FWKS</Data>
             <Data key="ProductVersion">11.0</Data>
             <Data key="$userextensionfolder">$SharedCommonDataFolder/Adobe/Fireworks CS5/Extensions</Data>
          <Data key="PreExtensionFolder">$SharedCommonDataFolder/Adobe/Fireworks CS5/PreInstall</Data>
             <Data key="EmStorePath">$SharedCommonDataFolder/Adobe/Fireworks CS5/EmStorePath</Data>
             <Data key="$fireworks">$installfolder</Data>
          <Data key="$fireworksuser">$userdatafolder/adobe/Fireworks CS5</Data>
             <Data key="SupportedInSuite">CS5</Data>
             <Data key="Bit">32</Data>
          </VariableForExMan>
      </Configuration>
        • 1. Re: CS5 extensions installation problem- XManConfig.xml is invalid
          Carl Sun Level 4
          The content of your XManConfig.xml seems correct. You can generate log files and Attach them here, so other people can help you troubleshooting. The steps to generate log files are as follows: Create a file named “ExManLog.YES” in the same folder as "Adobe Extension Manager CS5.exe", then run Extension Manager. You should find log files in "C:\Users\<YourUserName>\AppData\Roaming\Adobe\Extension Manager CS5".
          • 2. ExtensionManager.log: CS5 extensions installation problem- XManConfig.xml is invalid
            a2b9180 Level 1
            [ INFO] Thu Apr 14 14:02:53 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\startupcmd lineparser.cpp,70) -StartCmdLineParser::m_CmdLine is:
            [ INFO] Thu Apr 14 14:02:53 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\startupcmd lineparser.cpp,71) -"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"
            [DEBUG] Thu Apr 14 14:02:53 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\owlmain.cpp,94 1) -OWL environment initializd OK
            [DEBUG] Thu Apr 14 14:02:53 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\owlmain.cpp,94 4) -C:\Program Files\Adobe\Adobe Extension Manager CS5
            [DEBUG] Thu Apr 14 14:02:53 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\owlmain.cpp,98 6) -Create SWF window OK
            [DEBUG] Thu Apr 14 14:02:53 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\owlmain.cpp,10 05) -C:\Program Files\Adobe\Adobe Extension Manager CS5\ExMan.swf
            [DEBUG] Thu Apr 14 14:02:54 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\owlmain.cpp,10 18) -Load Flash OK
            [DEBUG] Thu Apr 14 14:02:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:02:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is BrowserHistory.getURL
            [DEBUG] Thu Apr 14 14:02:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:02:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,67) -PumpBridgeTalkMessageCommand::execute(), register bridge talk message handler.
            [ERROR] Thu Apr 14 14:02:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,140) -The size of arguments from AIR is zero, it is invalid
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\owlmain.cpp,20 7) -AIR is ready for waiting the invocation from C++ side
            [TRACE] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\win\commandexecuto rmfc.cpp,16) -MESSAGE
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,194) -Sending Suppress contents to AIR
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,399) --------------------Request (C++ side To AIR part ) Start--------------------------
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airParseSuppress
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --1
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -1
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -0
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,445) --------------------Request (C++ side To AIR part ) End---------------------------
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalCallBack
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --1
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -1
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-1. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getsupport edlocallist.cpp,57) -Sending Get Locale list request to AIR
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airGetLocaleList
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --2
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --2
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -0
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_B R,ro_RO,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-2. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getsupport edlocallist.cpp,82) -Get Locale list completed
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,242) -Sending Locale contents to AIR
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airParseLocale
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --3
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --3
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-3. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1457) -=====Supported locales list items:=====
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -en_US
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -da_DK
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -de_DE
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -es_ES
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -fi_FI
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -fr_FR
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -it_IT
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -nb_NO
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -nl_NL
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -pt_BR
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1461) -sv_SE
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1481) -The User preferred language code is en_US
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,1484) -en_US
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airSetLocale
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --4
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -en_US
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,3309) -Bare version is
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,3310) -5.0.0.334
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,3315) -Formal version is
            [DEBUG] Thu Apr 14 14:02:56 2011 (..\MMFC\Source\MacrOS.cpp,3316) -5.0.0.334
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrex tensionmanagerproduct.cpp,168) -Application name is Adobe Extension Manager CS5.exe
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrextensionma nager.cpp,662) ----Begin to read xman master configuration data file---
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrextensionma nager.cpp,663) -The present xman master configuration data file is:
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrextensionma nager.cpp,664) -C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\XManDerive.xml
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrextensionma nager.cpp,673) ----End to read  xman master configuration data file---
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\macrgetxml _impl.cpp,69) -Sending XML contents to AIR
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airParseXML
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --5
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\XManDerive.xml
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Configuration.VariableForExMan.Data
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --5
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -2
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -Invalid
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-5. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrco mmonproduct.cpp,86) -Application path is C:\Program Files\Adobe\Adobe Bridge CS5
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,73) ----Begin to read xman configuration data file---
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,74) -The present xman data file is:
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,75) -C:\Program Files\Adobe\Adobe Bridge CS5\Configuration\XManConfig.xml
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,84) ----End to read  xman configuration data file---
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --6
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Program Files\Adobe\Adobe Bridge CS5\Configuration\XManConfig.xml
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --6
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-6. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrco mmonproduct.cpp,86) -Application path is C:\Program Files\Adobe\Adobe InDesign CS5
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,75) -C:\Program Files\Adobe\Adobe InDesign CS5\Configuration\XManConfig.xml
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --7
            [DEBUG] Thu Apr 14 14:02:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Program Files\Adobe\Adobe InDesign CS5\Configuration\XManConfig.xml
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalCallBack
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --7
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -2
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -Invalid
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-7. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrdr eamweaver10.cpp,73) -Application path is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrdr eamweaver11.cpp,90) -Application path is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfi reworks10.cpp,76) -Application path is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfi reworks11.cpp,93) -Application path is C:\Program Files\Adobe\Adobe Fireworks CS5
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,73) ----Begin to read xman configuration data file---
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,74) -The present xman data file is:
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,75) -C:\Program Files\Adobe\Adobe Fireworks CS5\Configuration\XManConfig.xml
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\mactproductinfo frombridge.cpp,84) ----End to read  xman configuration data file---
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\macrgetxml _impl.cpp,69) -Sending XML contents to AIR
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,399) --------------------Request (C++ side To AIR part ) Start--------------------------
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airParseXML
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --8
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Program Files\Adobe\Adobe Fireworks CS5\Configuration\XManConfig.xml
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Configuration.VariableForExMan.Data
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,445) --------------------Request (C++ side To AIR part ) End---------------------------
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) --8
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is-8. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,3406) -The current operating system is 2,major version is 6,minor version is 1***********
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash10.cpp,429) -The present language code for Flash CS4 is en
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash10.cpp,452) -Application path is
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1457) -=====Supported locales list items:=====
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -da_DK
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -de_DE
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -es_ES
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -fi_FI
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -fr_FR
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -it_IT
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -nb_NO
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -nl_NL
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -pt_BR
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1461) -sv_SE
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1481) -The User preferred language code is en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (..\MMFC\Source\MacrOS.cpp,1484) -en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash11.cpp,576) -The User perferred language code is en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash11.cpp,445) -The present language code for Flash CS5 is en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash11.cpp,468) -Application path is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrco mmonproduct.cpp,383) -Product Name for bridge-4.0 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for  is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrco mmonproduct.cpp,383) -Product Name for indesign-7.0 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrdr eamweaver9.cpp,205) -Language code for Dreamweaver CS4 is en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1305) -EM Store path for Dreamweaver CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for Dreamweaver CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1305) -EM Store path for Dreamweaver CS5 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for Dreamweaver CS5 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfi reworks9.cpp,394) -Language code for Fireworks CS4 is en
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1305) -EM Store path for Fireworks CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for Fireworks CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfi reworks9.cpp,418) -User extension folder for Fireworks CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1305) -EM Store path for Fireworks CS5 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for Fireworks CS5 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash9.cpp,164) -Language code for Flash CS4 is en
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1305) -EM Store path for Flash CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for Flash CS4 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\products\macrfl ash9.cpp,164) -Language code for Flash CS4 is en_US
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1305) -EM Store path for Flash CS5 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,1269) -Preferred folder for Flash CS5 is
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\commandexe cutor.cpp,40) -OWL Controller initialized succeed
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airNotifyReady
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --9
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalGetExManConfigPath
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -1
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getexmanco nfigpathcommand.cpp,69) -GetExMan Config Path: C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getexmanco nfigpathcommand.cpp,76) -Version number is:
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getexmanco nfigpathcommand.cpp,77) -5.0.334
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airCallBack
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -1
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -0
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalGetSupportedProducts
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -5.0.334
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager2\Configuration\Extensions\
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\ProgramData\Adobe\Extension Manager CS5\
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -C:\Users\Public\Roaming\Adobe\Extension Manager2\
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getsupport edproductscommand.cpp,55) -GetProductName Command: parameter1
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getsupport edproductscommand.cpp,55) -GetProductName Command: parameterThe configuration file 'C:\Program Files\Adobe\Adobe Fireworks CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getsupport edproductscommand.cpp,55) -GetProductName Command: parameterThe configuration file 'C:\Program Files\Adobe\Adobe InDesign CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\getsupport edproductscommand.cpp,55) -GetProductName Command: parameterThe configuration file 'C:\Program Files\Adobe\Adobe Bridge CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -2
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -The configuration file 'C:\Program Files\Adobe\Adobe Fireworks CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -The configuration file 'C:\Program Files\Adobe\Adobe InDesign CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -The configuration file 'C:\Program Files\Adobe\Adobe Bridge CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -3
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalMigratePreferredExtension
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalGetLastVersionPointProducts
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -6
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,104) -The product flash-11.0 is not supported by CS4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,104) -The product flash-10.0 is not supported by CS4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,104) -The product fireworks-10.0 is not supported by CS4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,104) -The product dreamweaver-11.0 is not supported by CS4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\extensions\macrproduct.cpp ,104) -The product dreamweaver-10.0 is not supported by CS4
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -6
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalLoadExtension
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -8
            [FATAL] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\loadextens ioncommand.cpp,46) -Load extension finished
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -8
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is airCommandLineRequestReady
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -10
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\clireadyco mmand.cpp,30) -C++ start to parse CLI and execute it
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airHandleCommandLine
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --10
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airEnableUI
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) --11
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalInstallExtension
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -12
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -C:\Users\abho2185\Desktop\GreekedText-100.mxp
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -5
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,228) -Show progress
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,234) -SetProgressCount:20
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,257) -Update index:1, progress:5, primaryProductCount:-1
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -12
            [DEBUG] Thu Apr 14 14:02:57 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -9
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,234) -SetProgressCount:34
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,257) -Update index:3, progress:8, primaryProductCount:-1
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,399) --------------------Request (C++ side To AIR part ) Start--------------------------
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airCallBack
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -12
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -9
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -8
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,445) --------------------Request (C++ side To AIR part ) End---------------------------
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Flash CS5mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -5
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Flash CS5
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Fireworks
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -0
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalRespondFromAIR
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -12
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is12. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,380) -1
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Flash CS4mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Flash CS4
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Fireworks CS5mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Fireworks CS5
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Fireworks CS4mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Fireworks CS4
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Dreamweaver CS5mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Dreamweaver CS5
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Dreamweaver CS4mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Dreamweaver CS4
            [DEBUG] Thu Apr 14 14:02:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalRespondFromAIR
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -12
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is12. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,380) -1
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Dreamweaver CS5mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,399) --------------------Request (C++ side To AIR part ) Start--------------------------
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airCallBack
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -12
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -5
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Dreamweaver CS5
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Fireworks
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -8
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -0
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,445) --------------------Request (C++ side To AIR part ) End---------------------------
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, Dreamweaver CS4mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -Dreamweaver CS4
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,372) -to request to judge support, productName, mxiProductName, FireworksmxiProductVersion, 8mxiProductMaxVersion,
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,257) -Update index:4, progress:11, primaryProductCount:0
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -9
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -11
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,408) -to request to show required products: Fireworks;8;;0;0;0;0;
            [DEBUG] Thu Apr 14 14:02:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -4
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalRespondFromAIR
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -12
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is12. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,414) -1
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlextensi onmgrui.cpp,300) -Hide progress
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,399) --------------------Request (C++ side To AIR part ) Start--------------------------
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airCallBack
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -12
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -9
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -100
            [DEBUG] Thu Apr 14 14:03:00 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,445) --------------------Request (C++ side To AIR part ) End---------------------------
            [ERROR] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\installext ensioncommand.cpp,320) -Install extension failed, return null extension
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,399) --------------------Request (C++ side To AIR part ) Start--------------------------
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,402) -Method Name: airCallBack
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -12
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -2
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,445) --------------------Request (C++ side To AIR part ) End---------------------------
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalUpdateAirErrorMessageToCLI
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -13
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -This extension can not be installed, it requires Fireworks version 8 or greater.
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -13
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,419) -0
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalSendDraggableArea
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -15
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -50
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -383
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -10
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -312
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -287
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -198
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -173
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -113
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -69
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -54
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -30
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -52
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -37
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -35
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -20
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,154) -RequestId is15. It is a request used to unlock OK/Cancel
            [DEBUG] Thu Apr 14 14:03:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\requestidm anager.cpp,145) -Can not find requestId 15
            [DEBUG] Thu Apr 14 14:03:03 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:03 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:03 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:03 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:03 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:06 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:06 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:06 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:06 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:06 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:09 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:09 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:09 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:09 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:09 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:12 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:12 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:12 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:12 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:12 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:15 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:15 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:15 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:15 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:15 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:18 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:18 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:18 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:18 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:18 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:21 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:21 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:21 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:21 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:21 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:24 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:24 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:24 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:24 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:24 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:27 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:27 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:27 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:27 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:27 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:30 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:30 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:30 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:30 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:30 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:55 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:03:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:03:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:03:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:03:58 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:01 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:01 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:01 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:01 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:01 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:04 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:04 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:04 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:04 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:04 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:07 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:07 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:07 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:07 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:07 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:10 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:10 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:10 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:10 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:10 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:13 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:13 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:13 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:13 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:13 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:16 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:16 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:16 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:16 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:16 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:19 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:19 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:19 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:19 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:19 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:22 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:22 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:22 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:22 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:22 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:25 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:25 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:25 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:25 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:25 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:28 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:28 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:28 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:28 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:28 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:31 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:31 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:31 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:31 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:31 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:34 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:37 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:40 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:43 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:46 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:49 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:52 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:56 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:04:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:04:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:04:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:04:59 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:02 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:05 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:05 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:05 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:05 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:05 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:08 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:08 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:08 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:08 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:08 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:11 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:11 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:11 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:11 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:11 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:14 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:14 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:14 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:14 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:14 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:17 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:17 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:17 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:17 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:17 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:20 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:20 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:20 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:20 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:20 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:23 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:23 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:23 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:23 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:23 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:26 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:26 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:26 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:26 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:26 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            [DEBUG] Thu Apr 14 14:05:29 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,84) ------------------AIR request To C++ Start-----------------------------------------------
            [DEBUG] Thu Apr 14 14:05:29 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,87) -Receive the request from AIR, Request name is externalPumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:29 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,107) -pumpBridgeTalkMessage
            [DEBUG] Thu Apr 14 14:05:29 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\owlfrontco ntroller.cpp,131) -----------------AIR request To C++ End--------------------------------------------------
            [DEBUG] Thu Apr 14 14:05:29 2011 (d:\extensionmanager_5.0.1_win\20110110.5_0_1.334\trelo\source\manager\control\pumpbridge talkmessagecommand.cpp,77) -PumpBridgeTalkMessageCommand::execute()
            • 3. log0.log: CS5 extensions installation problem- XManConfig.xml is invalid
              a2b9180 Level 1
              4/14/2011 14:02:55.375 [INFO] com.adobe.exman.controller.PassiveGatewayPrepCommand execute(), PassiveGatewayPrepCommand is executed.
              4/14/2011 14:02:56.189 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway registerAirInterfaces
              4/14/2011 14:02:56.193 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway sendCallBackReady(), available==true
              4/14/2011 14:02:56.199 [INFO] com.adobe.exman.controller.ModelPrepCommand ModelPrepCommand command finished.
              4/14/2011 14:02:56.217 [INFO] com.adobe.exman.model.ExManConfigurationProxy ExManConfigurationProxy(), zstringPath is: C:\Program Files\Adobe\Adobe Extension Manager CS5\ZStringResources
              4/14/2011 14:02:56.224 [INFO] com.adobe.exman.model.ExManConfigurationProxy initLocaleList(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ro_RO,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
              4/14/2011 14:02:56.237 [INFO] com.adobe.exman.view.ExManApp ExManApp(), instance is constructed.
              4/14/2011 14:02:56.241 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:56.263 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.266 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.267 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.269 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:56.271 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.273 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.274 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.310 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.312 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.314 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.315 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.318 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.onRMChange(), _key=ExMan.Enabled event=[Event type="change" bubbles=false cancelable=false eventPhase=2]
              4/14/2011 14:02:56.320 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.onRMChange(), _key=ExMan.Version event=[Event type="change" bubbles=false cancelable=false eventPhase=2]
              4/14/2011 14:02:56.345 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseSuppress(), sessionId==-1requestBody: "C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop",1,0
              4/14/2011 14:02:56.346 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser initFromScratch(), use space character as separator.
              4/14/2011 14:02:56.349 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.350 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.352 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ' -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.353 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: MXPFILENAME, Value: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.355 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: ' '
              4/14/2011 14:02:56.357 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '-CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.358 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '-CurrDir'
              4/14/2011 14:02:56.360 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.361 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:56.362 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:56.364 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '='
              4/14/2011 14:02:56.365 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.366 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: EQUAL, Value: '='
              4/14/2011 14:02:56.367 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: EQUAL, Value: '='
              4/14/2011 14:02:56.369 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.370 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ''
              4/14/2011 14:02:56.372 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.373 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.374 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: DONE
              4/14/2011 14:02:56.376 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: DONE
              4/14/2011 14:02:56.377 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser init(), the cliString does not contain EMBT
              4/14/2011 14:02:56.379 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser initFromScratch(), use space character as separator.
              4/14/2011 14:02:56.380 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.382 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.383 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ' -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.385 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: MXPFILENAME, Value: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.386 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-1,1
              4/14/2011 14:02:56.391 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirGetLocaleList(), sessionId== -2
              4/14/2011 14:02:56.392 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), sessionId= -2
              4/14/2011 14:02:56.394 [INFO] com.adobe.exman.controller.passivecommand.GetLocaleListCommand execute(), the locale list is: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ro_RO,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
              4/14/2011 14:02:56.395 [INFO] com.adobe.exman.controller.passivecommand.RespondPassiveExternalGatewayCommand execute(), parameter: sessionId to respond: -2parameters to respond: en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,nb_NO,nl_NL,pl_PL,pt_BR ,ro_RO,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
              4/14/2011 14:02:56.397 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-2,0,en_US,da_DK,de_DE,cs_CZ,es_ES,fi_FI,fr_FR,hu_HU,it_IT,ja_JP,ko_KR,n b_NO,nl_NL,pl_PL,pt_BR,ro_RO,ru_RU,sv_SE,tr_TR,uk_UA,zh_CN,zh_TW
              4/14/2011 14:02:56.403 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseLocale(), sessionId==-3requestBody: "C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop",1,0
              4/14/2011 14:02:56.405 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser initFromScratch(), use space character as separator.
              4/14/2011 14:02:56.406 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.408 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.409 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ' -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.410 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: MXPFILENAME, Value: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.412 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: ' '
              4/14/2011 14:02:56.414 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '-CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.415 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '-CurrDir'
              4/14/2011 14:02:56.416 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.417 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:56.419 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:56.420 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '='
              4/14/2011 14:02:56.421 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.422 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: EQUAL, Value: '='
              4/14/2011 14:02:56.423 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: EQUAL, Value: '='
              4/14/2011 14:02:56.424 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.425 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ''
              4/14/2011 14:02:56.426 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.427 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.428 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: DONE
              4/14/2011 14:02:56.429 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: DONE
              4/14/2011 14:02:56.430 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser init(), the cliString does not contain EMBT
              4/14/2011 14:02:56.431 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser initFromScratch(), use space character as separator.
              4/14/2011 14:02:56.432 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.433 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.435 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ' -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:56.436 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: MXPFILENAME, Value: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:56.437 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway giveResponseToExternal(), the args to external interface is: externalCallBack,-3,1
              4/14/2011 14:02:56.456 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirSetLocale(), sessionId=-4args=en_US
              4/14/2011 14:02:56.457 [INFO] com.adobe.exman.model.ExManConfigurationProxy defaultOSLocale(), set to: en_US
              4/14/2011 14:02:56.459 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: SET_LOCAL
              notification body: en_US
              4/14/2011 14:02:56.460 [INFO] com.adobe.exman.view.ExManApp handleNotification(), locale= en_US
              4/14/2011 14:02:56.462 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.463 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.464 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.465 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.467 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.onRMChange(), _key=ExMan.Enabled event=[Event type="change" bubbles=false cancelable=false eventPhase=2]
              4/14/2011 14:02:56.468 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.onRMChange(), _key=ExMan.Version event=[Event type="change" bubbles=false cancelable=false eventPhase=2]
              4/14/2011 14:02:56.471 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-5got xml String to parse: C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\XManDerive.xml
              4/14/2011 14:02:56.473 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
              4/14/2011 14:02:56.474 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load xmiFileName: file:///C:/Users/abho2185/AppData/Roaming/Adobe/Extension%20Manager%20CS5/XManDerive.xml
              4/14/2011 14:02:56.508 [FATAL] com.adobe.exman.business.XMLLoader Unable to load requested file! : file:///C:/Users/abho2185/AppData/Roaming/Adobe/Extension%20Manager%20CS5/XManDerive.xml
              4/14/2011 14:02:56.510 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, fail, externalCallBack,-5,2,Invalid
              4/14/2011 14:02:56.617 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.620 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.623 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange()
              4/14/2011 14:02:56.625 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Enabled
              4/14/2011 14:02:56.627 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth()
              4/14/2011 14:02:56.631 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth(), width of column [OnOff] set to: 73
              4/14/2011 14:02:56.633 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange(), extensionColumn.width set to: 148.2, authorColumn.width set to: 113.80000000000001
              4/14/2011 14:02:56.635 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.637 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.639 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange()
              4/14/2011 14:02:56.641 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.642 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.643 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.Version
              4/14/2011 14:02:56.645 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth()
              4/14/2011 14:02:56.646 [INFO] com.adobe.exman.view.widget.ExManDataGridColumn adjustColumnWidth(), width of column [version] set to: 70
              4/14/2011 14:02:56.648 [INFO] com.adobe.exman.ExManGUI onColumnAssociateChange(), extensionColumn.width set to: 151.2, authorColumn.width set to: 102.80000000000001
              4/14/2011 14:02:56.650 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.onRMChange(), _key=ExMan.Enabled event=[Event type="change" bubbles=false cancelable=false eventPhase=2]
              4/14/2011 14:02:56.651 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.onRMChange(), _key=ExMan.Version event=[Event type="change" bubbles=false cancelable=false eventPhase=2]
              4/14/2011 14:02:56.675 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-6got xml String to parse: C:\Program Files\Adobe\Adobe Bridge CS5\Configuration\XManConfig.xml
              4/14/2011 14:02:56.677 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
              4/14/2011 14:02:56.678 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load xmiFileName: file:///C:/Program%20Files/Adobe/Adobe%20Bridge%20CS5/Configuration/XManConfig.xml
              4/14/2011 14:02:56.781 [FATAL] com.adobe.exman.business.XMLLoader Unable to load requested file! : file:///C:/Program%20Files/Adobe/Adobe%20Bridge%20CS5/Configuration/XManConfig.xml
              4/14/2011 14:02:56.783 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, fail, externalCallBack,-6,2,Invalid
              4/14/2011 14:02:56.895 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-7got xml String to parse: C:\Program Files\Adobe\Adobe InDesign CS5\Configuration\XManConfig.xml
              4/14/2011 14:02:56.897 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
              4/14/2011 14:02:56.900 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load xmiFileName: file:///C:/Program%20Files/Adobe/Adobe%20InDesign%20CS5/Configuration/XManConfig.xml
              4/14/2011 14:02:57.004 [FATAL] com.adobe.exman.business.XMLLoader Unable to load requested file! : file:///C:/Program%20Files/Adobe/Adobe%20InDesign%20CS5/Configuration/XManConfig.xml
              4/14/2011 14:02:57.006 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, fail, externalCallBack,-7,2,Invalid
              4/14/2011 14:02:57.211 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML(), sessionId==-8got xml String to parse: C:\Program Files\Adobe\Adobe Fireworks CS5\Configuration\XManConfig.xml
              4/14/2011 14:02:57.213 [INFO] com.adobe.exman.controller.ParseXMLCommand execute(), ParseXMLCommand is executed.
              4/14/2011 14:02:57.216 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load xmiFileName: file:///C:/Program%20Files/Adobe/Adobe%20Fireworks%20CS5/Configuration/XManConfig.xml
              4/14/2011 14:02:57.316 [FATAL] com.adobe.exman.business.XMLLoader Unable to load requested file! : file:///C:/Program%20Files/Adobe/Adobe%20Fireworks%20CS5/Configuration/XManConfig.xml
              4/14/2011 14:02:57.318 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirParseXML, fail, externalCallBack,-8,2,Invalid
              4/14/2011 14:02:57.361 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleAirNotifyReady(), sessionId=-9
              4/14/2011 14:02:57.363 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
              4/14/2011 14:02:57.365 [INFO] com.adobe.exman.controller.gateway.ExternalGateway ExternalGateway()
              4/14/2011 14:02:57.366 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface()
              4/14/2011 14:02:57.367 [INFO] com.adobe.exman.controller.gateway.ExternalGateway resetExternalInterface(), airCallBack added.
              4/14/2011 14:02:57.368 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----
              4/14/2011 14:02:57.370 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----1----
              4/14/2011 14:02:57.371 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----1----
              4/14/2011 14:02:57.372 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----1----2----
              4/14/2011 14:02:57.373 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----1----2----
              4/14/2011 14:02:57.374 [INFO] com.adobe.exman.controller.gateway.ExternalGateway getExManConfigPath(), the params to OWL: sessionid=1
              4/14/2011 14:02:57.376 [INFO] com.adobe.exman.controller.gateway.ExternalGateway getSupportedProducts(), the params to OWL: sessionid=2
              4/14/2011 14:02:57.380 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 1
              responseType= 0
              responseBody=C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\,5.0.334,C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager2\Configuration\Extensions\,C:\ProgramData\Adobe\Extension Manager CS5\,C:\Users\Public\Roaming\Adobe\Extension Manager2\,C:\Program Files
              4/14/2011 14:02:57.381 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\
              4/14/2011 14:02:57.382 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :5.0.334
              4/14/2011 14:02:57.384 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager2\Configuration\Extensions\
              4/14/2011 14:02:57.385 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :C:\ProgramData\Adobe\Extension Manager CS5\
              4/14/2011 14:02:57.386 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4 :C:\Users\Public\Roaming\Adobe\Extension Manager2\
              4/14/2011 14:02:57.387 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5 :C:\Program Files
              4/14/2011 14:02:57.388 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetExManConfigPathSession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:02:57.389 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\
              4/14/2011 14:02:57.390 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :5.0.334
              4/14/2011 14:02:57.391 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager2\Configuration\Extensions\
              4/14/2011 14:02:57.392 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :C:\ProgramData\Adobe\Extension Manager CS5\
              4/14/2011 14:02:57.393 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :C:\Users\Public\Roaming\Adobe\Extension Manager2\
              4/14/2011 14:02:57.394 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :C:\Program Files
              4/14/2011 14:02:57.395 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy totalExtDir(), the _totalExtDir is set to: C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\
              4/14/2011 14:02:57.397 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager's version is set to: 5.0.334
              4/14/2011 14:02:57.398 [INFO] com.adobe.exman.model.ProductExtensionManagerProxy the extension manager last version extension path is set to: C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager2\Configuration\Extensions\
              4/14/2011 14:02:57.399 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----2----
              4/14/2011 14:02:57.401 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 2
              responseType= 0
              responseBody=1,The configuration file 'C:\Program Files\Adobe\Adobe Fireworks CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.,1,The configuration file 'C:\Program Files\Adobe\Adobe InDesign CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.,1,The configuration file 'C:\Program Files\Adobe\Adobe Bridge CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.402 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :1
              4/14/2011 14:02:57.404 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :The configuration file 'C:\Program Files\Adobe\Adobe Fireworks CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.405 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :1
              4/14/2011 14:02:57.406 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :The configuration file 'C:\Program Files\Adobe\Adobe InDesign CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.407 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4 :1
              4/14/2011 14:02:57.408 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5 :The configuration file 'C:\Program Files\Adobe\Adobe Bridge CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.409 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetSupportedProductsSession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:02:57.410 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :1
              4/14/2011 14:02:57.411 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :The configuration file 'C:\Program Files\Adobe\Adobe Fireworks CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.412 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :1
              4/14/2011 14:02:57.413 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :The configuration file 'C:\Program Files\Adobe\Adobe InDesign CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.414 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4 :1
              4/14/2011 14:02:57.415 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5 :The configuration file 'C:\Program Files\Adobe\Adobe Bridge CS5\XManConfig.xml' is invalid. The corresponding product can not be integrated.
              4/14/2011 14:02:57.417 [INFO] com.adobe.exman.controller.LoadUIPreferencesCommand execute(), LoadUIPreferencesCommand is executed.
              4/14/2011 14:02:57.420 [INFO] com.adobe.exman.controller.LoadUIPreferencesCommand execute(), read out the ui preferences:
              <ExMan-UI-Preferences>
                <windowCurrentState>null</windowCurrentState>
                <windowPosition_x>571</windowPosition_x>
                <windowPosition_y>139</windowPosition_y>
                <windowWidth>800</windowWidth>
                <windowHeight>600</windowHeight>
                <descriptionHeight>293</descriptionHeight>
                <extensionColumnWidth>53.875146138883</extensionColumnWidth>
                <versionColumnWidth>40.804444522599944</versionColumnWidth>
                <authorColumnWidth>227.320409338517</authorColumnWidth>
                <sortedColumn/>
                <descending>false</descending>
                <selectedProduct/>
                <selectedExtension/>
              </ExMan-UI-Preferences>
              4/14/2011 14:02:57.422 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: LOAD_UI_PREFERENCES_DONE
              notification body: [object UIPreferences]
              4/14/2011 14:02:57.423 [INFO] com.adobe.exman.controller.SetWindowPreferencesCommand execute(), SetWindowPreferencesCommand is executed.
              4/14/2011 14:02:57.424 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----2----3----
              4/14/2011 14:02:57.425 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 0----2----3----
              4/14/2011 14:02:57.426 [INFO] com.adobe.exman.controller.gateway.ExternalGateway setWindowPreferences(), sessionId= 3, windowPosition_x= 571, windowPosition_y= 139, windowWidth= 800, windowHeight= 600
              4/14/2011 14:02:57.432 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 2----3----
              4/14/2011 14:02:57.433 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----
              4/14/2011 14:02:57.436 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 3
              responseType= 0
              responseBody=
              4/14/2011 14:02:57.438 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::SetWindowPreferencesSession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:02:57.440 [INFO] com.adobe.exman.controller.MigratePreferredExtensionCommand execute(), MigratePreferredExtensionCommand
              4/14/2011 14:02:57.441 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----
              4/14/2011 14:02:57.443 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----
              4/14/2011 14:02:57.444 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----5----
              4/14/2011 14:02:57.445 [INFO] com.adobe.exman.controller.session.frontend.FrontendMigratePreferredExtensionSession initiate()
              4/14/2011 14:02:57.446 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 3----4----
              4/14/2011 14:02:57.448 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
              notification body: [object ActionBeginParameter]
              4/14/2011 14:02:57.449 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
              4/14/2011 14:02:57.451 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.452 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
              4/14/2011 14:02:57.453 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
              4/14/2011 14:02:57.455 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. initiate ()
              4/14/2011 14:02:57.456 [INFO] com.adobe.exman.controller.gateway.ExternalGateway migratePreferredExtension(), the params to external install: sessionid=4
              4/14/2011 14:02:57.458 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----
              4/14/2011 14:02:57.460 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 4
              responseType= 0
              responseBody=
              4/14/2011 14:02:57.461 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::MigratePreferredExtensionSession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:02:57.463 [INFO] com.adobe.exman.controller.MigratePreferredExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
              4/14/2011 14:02:57.465 [INFO] com.adobe.exman.controller.GetLastVersionPointProductsCommand execute(), GetLastVersionPointProductsCommand
              4/14/2011 14:02:57.466 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----6----
              4/14/2011 14:02:57.468 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----6----
              4/14/2011 14:02:57.469 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----6----7----
              4/14/2011 14:02:57.470 [INFO] com.adobe.exman.controller.session.frontend.FrontendGetLastVersionPointProductsSession initiate()
              4/14/2011 14:02:57.471 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 4----6----
              4/14/2011 14:02:57.472 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
              4/14/2011 14:02:57.473 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
              4/14/2011 14:02:57.475 [ERROR] com.adobe.exman.ExManGUI onActionBegin(), unknown action name: GET_LAST_VERSION_PRODUCTS
              4/14/2011 14:02:57.477 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
              4/14/2011 14:02:57.478 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
              4/14/2011 14:02:57.479 [INFO] com.adobe.exman.controller.GetLastVersionPointProductsSession. GetLastVersionPointProductsSession. initiate ()
              4/14/2011 14:02:57.481 [INFO] com.adobe.exman.controller.gateway.ExternalGateway getLastVersionPointProducts(), the params to external install: sessionid=6
              4/14/2011 14:02:57.483 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 6----
              4/14/2011 14:02:57.488 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 6
              responseType= 0
              responseBody=
              4/14/2011 14:02:57.490 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::GetLastVersionPointProductsSession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:02:57.491 [INFO] com.adobe.exman.controller.GetLastVersionPointProductsSession. GetLastVersionPointProductsSession. specificHandleSuccess ()
              4/14/2011 14:02:57.493 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _already_Migrated_Flag_File: C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\Migrated.YES
              4/14/2011 14:02:57.494 [INFO] com.adobe.exman.model.MigrationExtensionsProxy MigrateExtensionsProxy(), _never_Migrated_Flag_File: C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions\Migrated.NEVER
              4/14/2011 14:02:57.496 [INFO] com.adobe.exman.model.MigrationExtensionsProxy migrateExtensions(), don't need to immigrate extensions.
              4/14/2011 14:02:57.497 [INFO] com.adobe.exman.controller.RequestLoadExtensionCommand execute(), RequestLoadExtensionCommand
              4/14/2011 14:02:57.498 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 6----8----
              4/14/2011 14:02:57.499 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 6----8----
              4/14/2011 14:02:57.500 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 6----8----9----
              4/14/2011 14:02:57.501 [INFO] com.adobe.exman.controller.session.frontend.FrontendRequestLoadExtensionSession initiate()
              4/14/2011 14:02:57.502 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 6----8----
              4/14/2011 14:02:57.504 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
              4/14/2011 14:02:57.505 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
              4/14/2011 14:02:57.507 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.ImportingExtensions
              4/14/2011 14:02:57.508 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
              4/14/2011 14:02:57.509 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
              4/14/2011 14:02:57.510 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. initiate ()
              4/14/2011 14:02:57.511 [INFO] com.adobe.exman.controller.gateway.ExternalGateway requestToLoadExtension(), the params to external install: sessionid=8
              4/14/2011 14:02:57.514 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----
              4/14/2011 14:02:57.528 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 8
              responseType= 0
              responseBody=
              4/14/2011 14:02:57.540 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::RequestLoadExtensionSession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:02:57.541 [INFO] com.adobe.exman.controller.RequestLoadExtensionSession. MigratePreferredExtensionSession. specificHandleSuccess ()
              4/14/2011 14:02:57.597 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.598 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LABEL_OK
              4/14/2011 14:02:57.599 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LABEL_OK
              4/14/2011 14:02:57.600 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LABEL_OK
              4/14/2011 14:02:57.602 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.603 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.DialogTitle
              4/14/2011 14:02:57.604 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.DialogTitle
              4/14/2011 14:02:57.605 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.DialogTitle
              4/14/2011 14:02:57.612 [INFO] com.adobe.exman.ExManGUI chenxiaoyan: п
              4/14/2011 14:02:57.617 [INFO] com.adobe.exman.view.ExManApp loadSupportProducts, no supported product installed
              4/14/2011 14:02:57.618 [INFO] com.adobe.exman.view.ExManApp onUIInitializationDone()
              4/14/2011 14:02:57.619 [INFO] com.adobe.exman.controller.StartTimerToBumpBridgeTalkMessages execute(), StartTimerToBumpBridgeTalkMessages is executed.
              4/14/2011 14:02:57.620 [INFO] com.adobe.exman.model.PumpBridgeTalkMessagesProxy startTimer(), to start timer.
              4/14/2011 14:02:57.621 [INFO] com.adobe.exman.controller.CommandLineRequestReadyCommand execute(), CommandLineRequestReadyCommand is executed.
              4/14/2011 14:02:57.622 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway sendCommandLineRequestReady(), available==true
              4/14/2011 14:02:57.624 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
              4/14/2011 14:02:57.626 [INFO] com.adobe.exman.controller.RemoveProductCommand execute(), RemoveProductCommand is executed.
              4/14/2011 14:02:57.627 [INFO] com.adobe.exman.controller.ImportProductCommand XManDerived path = C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration\Extensions,name = XManDerive.xml
              4/14/2011 14:02:57.628 [INFO] com.adobe.exman.controller.ImportProductCommand XManDerived path = C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\Configuration,name = XManDerive.xml
              4/14/2011 14:02:57.629 [INFO] com.adobe.exman.controller.ImportProductCommand XManDerived path = C:\Users\abho2185\AppData\Roaming\Adobe\Extension Manager CS5\,name = XManDerive.xml
              4/14/2011 14:02:57.631 [INFO] com.adobe.exman.business.XMLLoader XMLLoader(), will load xmiFileName: file:///C:/Users/abho2185/AppData/Roaming/Adobe/Extension%20Manager%20CS5/XManDerive.xml
              4/14/2011 14:02:57.673 [FATAL] com.adobe.exman.business.XMLLoader Unable to load requested file! : file:///C:/Users/abho2185/AppData/Roaming/Adobe/Extension%20Manager%20CS5/XManDerive.xml
              4/14/2011 14:02:57.697 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handleCommandLine(), + sessionId=-10, args="C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop",1,0
              4/14/2011 14:02:57.699 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser initFromScratch(), use space character as separator.
              4/14/2011 14:02:57.700 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.701 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:57.702 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ' -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.703 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: MXPFILENAME, Value: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:57.704 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: ' '
              4/14/2011 14:02:57.705 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '-CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.706 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '-CurrDir'
              4/14/2011 14:02:57.707 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.708 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:57.709 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:57.710 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '='
              4/14/2011 14:02:57.711 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.712 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: EQUAL, Value: '='
              4/14/2011 14:02:57.713 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: EQUAL, Value: '='
              4/14/2011 14:02:57.714 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.715 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ''
              4/14/2011 14:02:57.716 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.717 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.718 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: DONE
              4/14/2011 14:02:57.719 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: DONE
              4/14/2011 14:02:57.720 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser init(), the cliString does not contain EMBT
              4/14/2011 14:02:57.721 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser initFromScratch(), use space character as separator.
              4/14/2011 14:02:57.722 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex _input is: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp" -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.723 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:57.724 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ' -CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.725 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: MXPFILENAME, Value: '"C:\Users\abho2185\Desktop\GreekedText-100.mxp"'
              4/14/2011 14:02:57.727 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: ' '
              4/14/2011 14:02:57.728 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '-CurrDir="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.729 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '-CurrDir'
              4/14/2011 14:02:57.730 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '="C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.731 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:57.732 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: CURRENTDIRECTORY, Value: '-CurrDir'
              4/14/2011 14:02:57.733 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '='
              4/14/2011 14:02:57.734 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.735 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: EQUAL, Value: '='
              4/14/2011 14:02:57.736 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: EQUAL, Value: '='
              4/14/2011 14:02:57.737 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), matched result: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.738 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex doGetNextSymbol(), now _input is: ''
              4/14/2011 14:02:57.739 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.740 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: STRINGVALUE, Value: '"C:\Users\abho2185\Desktop"'
              4/14/2011 14:02:57.741 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: DONE
              4/14/2011 14:02:57.742 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: DONE
              4/14/2011 14:02:57.743 [INFO] com.adobe.exman.controller.commandlinerequest.CommandLineRequest currentDirectory(), set currentDirectory to C:\Users\abho2185\Desktop
              4/14/2011 14:02:57.744 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIArgLex getNextSymbol(), return symbol: Token: DONE
              4/14/2011 14:02:57.745 [INFO] com.adobe.exman.util.cliargumentprocessor.CLIParser match(), _symbolLookAhead is: Token: DONE
              4/14/2011 14:02:57.746 [INFO] com.adobe.exman.controller.commandlinerequest.CompositeCommandLineRequest Add a new request to composite request, chid request is : com.adobe.exman.controller.commandlinerequest::InstallCommandLineRequest: requestArguments=C:\Users\abho2185\Desktop\GreekedText-100.mxp timeout=5
              4/14/2011 14:02:57.747 [INFO] com.adobe.exman.controller.commandlinerequest.CompositeCommandLineRequest Add a new request to composite request, chid request is : com.adobe.exman.controller.commandlinerequest::UpdateAirErrorMessageToCLICommandLineReque st: requestArguments= timeout=5
              4/14/2011 14:02:57.748 [INFO] com.adobe.exman.model.CommandLineRequestProxy pushRequest(), can execute command line request now, directly execute it.
              4/14/2011 14:02:57.749 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
              4/14/2011 14:02:57.751 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::CompositeCommandLineRequest: requestArguments= timeout=5
              4/14/2011 14:02:57.752 [INFO] com.adobe.exman.controller.commandlinerequest.InstallCommandLineRequest execute(), InstallCommandLineRequest is executed, suppress mode= false
              4/14/2011 14:02:57.753 [INFO] com.adobe.exman.controller.InstallExtensionCommand execute(), InstallExtensionCommand is executed.
              4/14/2011 14:02:57.755 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----
              4/14/2011 14:02:57.756 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----12----
              4/14/2011 14:02:57.757 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----12----
              4/14/2011 14:02:57.758 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession initiate()
              4/14/2011 14:02:57.759 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
              4/14/2011 14:02:57.760 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
              4/14/2011 14:02:57.761 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LoadingExtensions
              4/14/2011 14:02:57.762 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
              4/14/2011 14:02:57.763 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
              4/14/2011 14:02:57.764 [INFO] com.adobe.exman.controller.gateway.ExternalGateway installExtension(), the params to external install: sessionid=12, product=, sourcepath= C:\Users\abho2185\Desktop\GreekedText-100.mxp, timeout= 5
              4/14/2011 14:02:57.767 [INFO] com.adobe.exman.controller.gateway.PassiveExternalGateway handlAirEnableUI(), sessionId=-11
              4/14/2011 14:02:57.769 [INFO] com.adobe.exman.model.CommandLineRequestProxy pushRequest(), request added to pending queue: com.adobe.exman.controller.commandlinerequest::EnableUICommandLineRequest: requestArguments=null timeout=5
              4/14/2011 14:02:57.780 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 9
              responseBody=5
              4/14/2011 14:02:57.781 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :5
              4/14/2011 14:02:57.782 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 9
              4/14/2011 14:02:57.783 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :5
              4/14/2011 14:02:57.784 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 5
              4/14/2011 14:02:57.785 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 2.5
              4/14/2011 14:02:57.786 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
              notification body: 2.5
              4/14/2011 14:02:57.787 [INFO] com.adobe.exman.view.ExManApp app got progress: 2.5
              4/14/2011 14:02:57.792 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.793 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.794 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.797 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.InstallingExtension
              4/14/2011 14:02:57.798 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.InstallingExtension
              4/14/2011 14:02:57.799 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:57.800 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.InstallingExtension
              4/14/2011 14:02:57.802 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.InstallingExtension
              4/14/2011 14:02:58.664 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 9
              responseBody=8
              4/14/2011 14:02:58.665 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :8
              4/14/2011 14:02:58.666 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 9
              4/14/2011 14:02:58.668 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :8
              4/14/2011 14:02:58.669 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 8
              4/14/2011 14:02:58.670 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 4
              4/14/2011 14:02:58.671 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
              notification body: 4
              4/14/2011 14:02:58.672 [INFO] com.adobe.exman.view.ExManApp app got progress: 4
              4/14/2011 14:02:58.722 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=Flash CS5,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.723 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Flash CS5
              4/14/2011 14:02:58.724 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.725 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.726 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.727 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.728 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.729 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.730 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.731 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Flash CS5
              4/14/2011 14:02:58.732 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.733 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.734 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.735 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.736 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.737 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.739 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Flash CS5, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.740 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Flash CS5
              4/14/2011 14:02:58.741 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.742 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.743 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.748 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=Flash CS4,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.749 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Flash CS4
              4/14/2011 14:02:58.750 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.751 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.752 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.753 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.754 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.755 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.756 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.757 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Flash CS4
              4/14/2011 14:02:58.758 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.759 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.760 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.761 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.762 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.763 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.764 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Flash CS4, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.765 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Flash CS4
              4/14/2011 14:02:58.766 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.767 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.768 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.772 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=Fireworks CS5,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.774 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Fireworks CS5
              4/14/2011 14:02:58.775 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.775 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.776 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.777 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.778 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.779 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.780 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.781 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Fireworks CS5
              4/14/2011 14:02:58.782 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.783 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.784 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.785 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.786 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.787 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.788 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Fireworks CS5, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.789 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Fireworks CS5
              4/14/2011 14:02:58.790 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.791 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.792 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.797 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=Fireworks CS4,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.798 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Fireworks CS4
              4/14/2011 14:02:58.799 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.800 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.801 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.802 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.803 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.804 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.805 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.806 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Fireworks CS4
              4/14/2011 14:02:58.807 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.808 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.809 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.810 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.811 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.812 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.813 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Fireworks CS4, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.814 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Fireworks CS4
              4/14/2011 14:02:58.815 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.816 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.817 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.822 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=Dreamweaver CS5,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.823 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Dreamweaver CS5
              4/14/2011 14:02:58.824 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.825 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.826 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.827 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.828 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.829 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.830 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.831 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Dreamweaver CS5
              4/14/2011 14:02:58.832 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.833 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.834 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.835 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.837 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.838 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.839 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Dreamweaver CS5, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.840 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Dreamweaver CS5
              4/14/2011 14:02:58.841 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.842 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.843 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.847 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=Dreamweaver CS4,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.848 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Dreamweaver CS4
              4/14/2011 14:02:58.849 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.850 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.851 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.852 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.853 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.854 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.855 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.856 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Dreamweaver CS4
              4/14/2011 14:02:58.857 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.858 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.859 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.860 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.861 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.862 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.863 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Dreamweaver CS4, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.864 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Dreamweaver CS4
              4/14/2011 14:02:58.865 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.866 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.867 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.871 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              responseBody=,Fireworks,8,,0,0,0
              4/14/2011 14:02:58.872 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :
              4/14/2011 14:02:58.873 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.874 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.875 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.876 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.877 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.878 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.879 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.880 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :
              4/14/2011 14:02:58.881 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.882 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.883 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.884 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.885 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.886 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.887 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.888 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product:
              4/14/2011 14:02:58.889 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.890 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.891 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.895 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:58.897 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :
              4/14/2011 14:02:58.898 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.899 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.900 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.901 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.902 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.903 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.904 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.905 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :
              4/14/2011 14:02:58.906 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.907 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.908 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.909 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.910 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.911 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.912 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.913 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product:
              4/14/2011 14:02:58.914 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.915 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.916 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.920 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:58.921 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Flash CS5
              4/14/2011 14:02:58.922 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.923 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.924 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.925 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.926 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.927 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.928 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.929 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Flash CS5
              4/14/2011 14:02:58.930 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.931 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.932 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.933 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.934 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.935 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.936 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Flash CS5, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.937 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Flash CS5
              4/14/2011 14:02:58.938 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.939 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.940 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.944 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:58.945 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Flash CS4
              4/14/2011 14:02:58.946 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.947 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.948 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.949 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.950 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.951 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.952 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.953 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Flash CS4
              4/14/2011 14:02:58.954 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.955 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.956 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.957 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.958 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.959 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.960 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Flash CS4, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.961 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Flash CS4
              4/14/2011 14:02:58.962 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.963 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.964 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.969 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:58.970 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Fireworks CS5
              4/14/2011 14:02:58.971 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.972 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.973 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.974 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.975 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:58.976 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:58.977 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:58.978 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Fireworks CS5
              4/14/2011 14:02:58.979 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:58.980 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:58.981 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:58.982 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:58.983 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:58.984 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:58.985 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Fireworks CS5, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:58.986 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Fireworks CS5
              4/14/2011 14:02:58.987 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:58.988 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:58.989 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:58.993 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:58.994 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Fireworks CS4
              4/14/2011 14:02:58.995 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:58.996 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:58.997 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:58.998 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:58.999 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:59.000 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:59.001 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:59.002 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Fireworks CS4
              4/14/2011 14:02:59.003 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:59.004 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:59.005 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:59.006 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:59.007 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:59.008 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:59.009 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Fireworks CS4, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:59.010 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Fireworks CS4
              4/14/2011 14:02:59.011 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:59.012 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:59.013 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:59.017 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:59.018 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Dreamweaver CS5
              4/14/2011 14:02:59.019 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:59.020 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:59.021 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:59.022 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:59.023 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:59.024 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:59.025 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:59.026 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Dreamweaver CS5
              4/14/2011 14:02:59.027 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:59.029 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:59.030 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:59.031 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:59.032 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:59.033 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:59.034 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Dreamweaver CS5, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:59.035 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Dreamweaver CS5
              4/14/2011 14:02:59.036 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:59.037 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:59.037 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:59.042 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:59.043 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Dreamweaver CS4
              4/14/2011 14:02:59.044 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:59.045 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:59.047 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:59.048 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:59.049 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:59.050 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:59.051 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:59.052 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Dreamweaver CS4
              4/14/2011 14:02:59.053 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:59.054 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:59.054 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:59.055 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:59.056 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:59.057 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:59.058 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=Dreamweaver CS4, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:59.060 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product: Dreamweaver CS4
              4/14/2011 14:02:59.061 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:59.062 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:59.062 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:59.067 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:59.068 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :
              4/14/2011 14:02:59.069 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:59.070 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:59.071 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:59.072 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:59.073 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:59.074 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:59.075 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:59.076 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :
              4/14/2011 14:02:59.077 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:59.078 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:59.079 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:59.080 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:59.081 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:59.082 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:59.083 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:59.084 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product:
              4/14/2011 14:02:59.085 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:59.086 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:59.087 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:59.092 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 5
              4/14/2011 14:02:59.093 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :
              4/14/2011 14:02:59.094 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :Fireworks
              4/14/2011 14:02:59.095 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :8
              4/14/2011 14:02:59.096 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3 :
              4/14/2011 14:02:59.097 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:59.098 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:59.099 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:59.099 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 5
              4/14/2011 14:02:59.100 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :
              4/14/2011 14:02:59.101 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :Fireworks
              4/14/2011 14:02:59.102 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :8
              4/14/2011 14:02:59.103 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3 :
              4/14/2011 14:02:59.104 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:59.105 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:59.106 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:59.107 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand execute(), parameter: _productNameToJudge=, _productName=Fireworks, _version=8, _maxversion=2147483647
              4/14/2011 14:02:59.108 [FATAL] com.adobe.exman.model.ProductExtensionManagerProxy getProductInfo(), can not find the productInfo for the product:
              4/14/2011 14:02:59.109 [INFO] com.adobe.exman.controller.JudgeProductSupportCommand giveResponse(), sessionId=12, support=false
              4/14/2011 14:02:59.110 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondJudgeProductSupport(), sessionid= 12, support=false
              4/14/2011 14:02:59.111 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respondProductSupport(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:02:59.115 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 9
              responseBody=11,1
              4/14/2011 14:02:59.116 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :11
              4/14/2011 14:02:59.117 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :1
              4/14/2011 14:02:59.118 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 9
              4/14/2011 14:02:59.119 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :11
              4/14/2011 14:02:59.120 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :1
              4/14/2011 14:02:59.121 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 11
              4/14/2011 14:02:59.122 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 11
              4/14/2011 14:02:59.123 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
              notification body: 11
              4/14/2011 14:02:59.124 [INFO] com.adobe.exman.view.ExManApp app got progress: 11
              4/14/2011 14:02:59.125 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 4
              responseBody=Fireworks,8,,0,0,0,0
              4/14/2011 14:02:59.127 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :Fireworks
              4/14/2011 14:02:59.128 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 1 :8
              4/14/2011 14:02:59.129 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 2 :
              4/14/2011 14:02:59.130 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 3
              4/14/2011 14:02:59.131 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 4
              4/14/2011 14:02:59.132 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 5
              4/14/2011 14:02:59.133 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 6
              4/14/2011 14:02:59.134 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 4
              4/14/2011 14:02:59.135 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :Fireworks
              4/14/2011 14:02:59.136 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 1 :8
              4/14/2011 14:02:59.137 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 2 :
              4/14/2011 14:02:59.138 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 3
              4/14/2011 14:02:59.139 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 4
              4/14/2011 14:02:59.139 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 5
              4/14/2011 14:02:59.140 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 6
              4/14/2011 14:02:59.141 [INFO] com.adobe.exman.controller.session.backend.BackendSession handleShowRequiredProducts()
              4/14/2011 14:02:59.143 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_SHOW_REQUIRED_PRODUCTS
              notification body: [object RequiredProductsParameter]
              4/14/2011 14:02:59.144 [INFO] com.adobe.exman.view.ExManApp handleNotification(), need to show required products.
              4/14/2011 14:02:59.145 [INFO] com.adobe.exman.view.ExManApp handleShowRequiredProducts(), suppress mode= false
              4/14/2011 14:02:59.154 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:59.156 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LABEL_OK
              4/14/2011 14:02:59.157 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LABEL_OK
              4/14/2011 14:02:59.158 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.LABEL_OK
              4/14/2011 14:02:59.159 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=null
              4/14/2011 14:02:59.160 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.DialogTitle
              4/14/2011 14:02:59.161 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.DialogTitle
              4/14/2011 14:02:59.162 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.DialogTitle
              4/14/2011 14:03:00.629 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:00.977 [INFO] com.adobe.exman.view.widget.ConfigurableButtonBox onClickConfiguredButton() label =  OK, name = Button529, keys[(event.target as Button).name] = ExMan.LABEL_OK
              4/14/2011 14:03:00.979 [INFO] com.adobe.exman.view.widget.ConfigurableButtonBox _extraParameter,_checkRestartFlag is null
              4/14/2011 14:03:00.982 [INFO] com.adobe.exman.controller.RespondCommand execute(), RespondCommand is executed.
              4/14/2011 14:03:00.983 [INFO] com.adobe.exman.controller.RespondCommand execute(), sessionId: 12, confirm: 1
              4/14/2011 14:03:00.985 [INFO] com.adobe.exman.controller.session.backend.BackendSession respondGateway(), session responds to the gateway with params: sessionid= 12, and response= 1
              4/14/2011 14:03:00.987 [INFO] com.adobe.exman.controller.gateway.ExternalGateway respond(), the params to OWL: sessionid=12, response= 1
              4/14/2011 14:03:01.002 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 9
              responseBody=100
              4/14/2011 14:03:01.004 [INFO] com.adobe.exman.controller.gateway.ExternalGateway responsebody 0 :100
              4/14/2011 14:03:01.005 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 9
              4/14/2011 14:03:01.007 [INFO] com.adobe.exman.controller.session.backend.BackendSession responsebody 0 :100
              4/14/2011 14:03:01.009 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), 100
              4/14/2011 14:03:01.010 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionProgress(), calculatedProgress is 100
              4/14/2011 14:03:01.012 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_PROGRESS
              notification body: 100
              4/14/2011 14:03:01.014 [INFO] com.adobe.exman.view.ExManApp app got progress: 100
              4/14/2011 14:03:02.186 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 12
              responseType= 2
              responseBody=
              4/14/2011 14:03:02.187 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::InstallExtensionSession got parameters in handleResponse:
              responseType= 2
              4/14/2011 14:03:02.189 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionNeutralEndding()
              4/14/2011 14:03:02.190 [INFO] com.adobe.exman.controller.session.frontend.FrontendInstallExtensionSession onBackendSessionNeutralEndding(), got NeutralEndding notification for install, we don not continue.
              4/14/2011 14:03:02.191 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
              4/14/2011 14:03:02.192 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
              4/14/2011 14:03:02.193 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
              4/14/2011 14:03:02.194 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::CompositeCommandLineRequest: requestArguments= timeout=5
              4/14/2011 14:03:02.195 [INFO] com.adobe.exman.controller.commandlinerequest.UpdateAirErrorMessageToCLICommandLineReques t execute(), UpdateAirErrorMessageToCLICommandLineRequest is executed, suppress mode= false
              4/14/2011 14:03:02.196 [INFO] com.adobe.exman.controller.UpdateAirErrorMessageToCLICommand execute(), UpdateAirErrorMessageToCLICommand got params: error string = This extension can not be installed, it requires Fireworks version 8 or greater.
              4/14/2011 14:03:02.198 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----12----13----
              4/14/2011 14:03:02.199 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----12----13----
              4/14/2011 14:03:02.200 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----12----13----14----
              4/14/2011 14:03:02.202 [INFO] com.adobe.exman.controller.session.frontend.FrontendUpdateAirErrorMessageToCLISession initiate()
              4/14/2011 14:03:02.203 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----11----12----13----
              4/14/2011 14:03:02.204 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_BEGIN
              notification body: [object ActionBeginParameter]
              4/14/2011 14:03:02.205 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: false
              4/14/2011 14:03:02.206 [INFO] com.adobe.exman.view.widget.BindableZStringLabel BindableZStringLabel.get key(), _key=ExMan.InstallingExtension
              4/14/2011 14:03:02.207 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: false
              4/14/2011 14:03:02.208 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: false
              4/14/2011 14:03:02.209 [INFO] com.adobe.exman.controller.gateway.ExternalGateway UpdateAirErrorMessageToCLI(), sessionId= 13errorString = This extension can not be installed, it requires Fireworks version 8 or greater.
              4/14/2011 14:03:02.213 [INFO] com.adobe.exman.model.CommandLineRequestProxy clRequest.executeChildCommand()
              4/14/2011 14:03:02.214 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----12----13----
              4/14/2011 14:03:02.215 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----13----
              4/14/2011 14:03:02.217 [INFO] com.adobe.exman.controller.gateway.ExternalGateway handleResponse(), parameters of handleResponse:
              sessionId= 13
              responseType= 0
              responseBody=
              4/14/2011 14:03:02.219 [INFO] com.adobe.exman.controller.session.backend.BackendSession com.adobe.exman.controller.session.backend::UpdateAirErrorMessageToCLISession got parameters in handleResponse:
              responseType= 0
              4/14/2011 14:03:02.220 [INFO] com.adobe.exman.view.ExManApp handleNotification(), got notification: NOTIF_ACTION_NEUTRAL_ENDDING
              notification body: [object ActionSucceedParameter]
              4/14/2011 14:03:02.222 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
              4/14/2011 14:03:02.223 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
              4/14/2011 14:03:02.225 [INFO] com.adobe.exman.model.CommandLineRequestProxy canExecuteCommandLineRequest, set value to: true
              4/14/2011 14:03:02.226 [INFO] com.adobe.exman.model.CommandLineRequestProxy The current request is : com.adobe.exman.controller.commandlinerequest::EnableUICommandLineRequest: requestArguments=null timeout=5
              4/14/2011 14:03:02.227 [INFO] com.adobe.exman.controller.commandlinerequest.EnableUICommandLineRequest execute(), EnableUICommandLineRequest is executed.
              4/14/2011 14:03:02.229 [INFO] com.adobe.exman.controller.SendDraggableAreaToExternalCommand execute(), SendDraggableAreaToExternalCommand is executed. the parameter is:
              Title bar height: 50
              Excluded area: 383, 10, 312, 38
              Excluded area: 287, 10, 198, 38
              Excluded area: 173, 10, 113, 38
              Excluded area: 69, 17, 54, 30
              Excluded area: 52, 17, 37, 30
              Excluded area: 35, 17, 20, 30
              4/14/2011 14:03:02.230 [INFO] com.adobe.exman.controller.gateway.ExternalGateway sendDraggableAreaToExternal(), sessionId= 15, titleBarHeight=50, excludedAreas= 383,10,312,38,287,10,198,38,173,10,113,38,69,17,54,30,52,17,37,30,35,17,20,30
              4/14/2011 14:03:02.238 [INFO] com.adobe.exman.ExManGUI enableApp(), set value to: true
              4/14/2011 14:03:02.240 [INFO] com.adobe.exman.ExManGUI canAcceptUIInput(), set to: true
              4/14/2011 14:03:02.241 [INFO] com.adobe.exman.model.CommandLineRequestProxy clRequest.executeChildCommand()
              4/14/2011 14:03:02.242 [INFO] com.adobe.exman.model.SessionManagerProxy outputAllTheSessionId(), there are following sessions now: 8----
              4/14/2011 14:03:03.471 [INFO] com.adobe.exman.view.widget.ConfigurableButtonBox onClickConfiguredButton() label =  OK, name = Button441, keys[(event.target as Button).name] = ExMan.LABEL_OK
              4/14/2011 14:03:03.654 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:06.682 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:09.718 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:12.759 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:15.795 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:18.830 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:21.866 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:24.911 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:27.947 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:30.983 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:34.024 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:37.059 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:40.095 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:43.132 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:46.168 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:49.204 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:52.240 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:55.276 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:03:58.312 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:01.348 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:04.385 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:07.421 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:10.452 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:13.489 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:16.525 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:19.561 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:22.598 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:25.634 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:28.669 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:31.705 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:34.742 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:37.774 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:40.819 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:43.856 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:46.891 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:49.928 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:52.964 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:56.001 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:04:59.034 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:02.081 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:05.118 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:08.154 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:11.191 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:14.228 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:17.264 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:20.300 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:23.336 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:26.373 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:29.410 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:32.422 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:35.443 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              4/14/2011 14:05:38.474 [DEBUG] com.adobe.exman.controller.gateway.ExternalGateway pumpBridgeTalkMessage(), sessionId: pumpBridgeTalkMessage
              • 4. Re: log0.log: CS5 extensions installation problem- XManConfig.xml is invalid
                Carl Sun Level 4
                It seems that there is encoding problem in your Windows. There is extra space character in the full path name of XManConfig.xml after the path name is encoded to url format. For example, "C:\Program Files\Adobe\Adobe Bridge CS5\Configuration\XManConfig.xml" is converted into "file:///C:/Program%20Files/Adobe/Adobe%20Bridge%20CS5/Configuration/XM anConfig.xml". A space character exists between M and a, which causes XManConfig.xml can't be loaded. Please check your "Region and Language" settings in Control Panel, as well as other encoding-related configurations. which locale/language are you using?
