5 Replies Latest reply on Apr 13, 2011 10:48 PM by pradeep reddy
    Flex 3: DataGrid Column width on resize
    srilatha reddy
      Hello experts,
      I am facing an issue with width of DataGrid columns. We are using Flex 3.2.
      I am setting the widths for columns in creationComplete handler of DataGrid. When the browser window is resized, say restore down and then maximize,
      the column widths are changing. Please find the code below:
      <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" height="100%" width="100%">
      <mx:Script>
          <![CDATA[
              import mx.core.ScrollPolicy;
              [Bindable]
              private var isVisible:Boolean = true;
              private function creationCompleteHandler():void{
                  dataGrid.horizontalScrollPolicy = ScrollPolicy.ON;
                  artist.width = dataGrid.width * 0.40;
                  album.width = dataGrid.width * 0.50;
                  Price.width = dataGrid.width * 0.10;
                  dataGrid.horizontalScrollPolicy = ScrollPolicy.OFF;
      </mx:Script>
      <mx:DataGrid id="dataGrid" width="80%" height="100%" creationComplete="creationCompleteHandler()">
            <mx:ArrayCollection>
               <mx:Object Artist="Pavement" Price="11.99"
                  Album="Slanted and Enchanted" />
                  Album="Brighten the Corners" Price="11.99" />
            </mx:ArrayCollection>
            <mx:columns>
                <mx:DataGridColumn id="artist" dataField="Artist"/>
               <mx:DataGridColumn id="album" dataField="Album" visible="{isVisible}"/>
               <mx:DataGridColumn id="Price" dataField="Price" />
            </mx:columns>
         </mx:DataGrid>
      </mx:Application>
      Is there anything wrong i am doing here? Please help me in resolving this.
      Srilatha
        • 1. Re: Flex 3: DataGrid Column width on resize
          pradeep reddy Level 1
          Hi Srilatha,
          DataGrid width is 100% and the main application width also 100%, So the
          DataGrid will try to occupy the whole window, when you do "restore down" &
          "maximize" Application width will change.. and it will effect DataGrid and
          its columns also. Try to give some fixed width for dataGrid and you can
          expect the result.
              <mx:Script>
                  <![CDATA[
              </mx:Script>
              <mx:DataGrid id="dataGrid" width="500" height="100%"
                  <mx:columns>
          visible=""/>
                  </mx:columns>
              </mx:DataGrid>
          </mx:Application>
          Pradeep Reddy
          • 2. Re: Flex 3: DataGrid Column width on resize
            Flex harUI Adobe Employee
            That's expected behavior.  With ScrollPolicy.OFF, the datagrid will shrink
            down all column until they fit, then when you expand, they may expand
            differently because they lost their proportions during the shrinking.  You
            may want to call your columns sizing code when the app resizes.
            • 3. Re: Flex 3: DataGrid Column width on resize
              srilatha reddy Level 1
              Thanks for your quick responses.
              @Pradeep:
              I cannot fix the width of DataGrid as i want it to occupy 100% of the Flex application size.
              @Flex harUI:
              I understand what you said. Could you please give me the event which gets dispatched on application resize?
              And if the user has manually dragged the columns, i shouldnt reset the widths of the columns again right. Is there a way to find out if the user has changed the size of the columns?
              Srilatha
              • 4. Re: Flex 3: DataGrid Column width on resize
                There should be RESIZE event from the application.  I'd probably store the
                column widths somewhere else on maybe UPDATE_COMPLETE and use that
                information during the RESIZE.
                • 5. Re: Flex 3: DataGrid Column width on resize
                  Srilatha,
                  Then Don't make the DataGrid Columns depend on DataGrid width.
                  Pradeep
