good day,
I'm trying to configure a hibernate assembler using the lcds 4.5 beta, When I start lcds I get the following error message:
Caused by: org.hibernate.MappingException: An AnnotationConfiguration instance is required to use <mapping class="my.model.db.TestClass"...
the recomendation from googling the error message, is that I need to set the session factory to use the annotationConfiguration where do I do this within wth lcds context?
I'm using an annotated class created from fml using the server side generator.
here is my hibernate.cfg.xml
<?xml version='1.0' encoding='utf-8'?>
<!DOCTYPE hibernate-configuration PUBLIC "-//Hibernate/Hibernate Configuration DTD 3.0//EN"
"http://hibernate.sourceforge.net/hibernate-configuration-3.0.dtd">
<hibernate-configuration>
<session-factory>
<!-- Database connection settings. -->
<property name="connection.driver_class">oracle.jdbc.driver.OracleDriver</property>
<property name="connection.url">
jdbc:oracle:thin:@dbhost:1521:castlewr
</property>
<property name="connection.username">
aUser
</property>
<property name="connection.password">
ultrasecret
</property>
<!-- JDBC connection pool (use the built-in). -->
<property name="connection.pool_size">
1
</property>
<!-- SQL dialect. -->
<property name="dialect">org.hibernate.dialect.Oracle10gDialect</property>
<!-- Enable the Hibernate automatic session context management. -->
<property name="current_session_context_class">thread</property>
<!-- Disable the second-level cache. -->
<property name="cache.provider_class">
org.hibernate.cache.NoCacheProvider
</property>
<property name="show_sql">true</property>
<mapping class="my.model.db.TestClass" />
<!-- Echo all executed SQL to stdout. -->
</session-factory>
</hibernate-configuration>
Views
Total Likes
How are you declaring your DMS destination? I believe you should be using the HibernateAnnotationsAssembler as your assembler. You might want to refer to the LCDS 3.1 documentation for using it.
Rohit
Views
Total Likes
Thanks that was it, I missed it somehow with all the other assemblers.
Chuckles
Views
Total Likes
