1 Reply Latest reply on Apr 28, 2011 2:01 PM by Mr. Kirkwood
    Adding main menu bar to project
    Mr. Kirkwood
      I have created a Flash Catalyst project , but the frame rate is inccorrect when i publsih. so, i had to open the project in Flash Builder, add frameRate, ShowStatusbar and then publish to AIR. However, when i do this the main toolbar does not show up like it did in the original export from FC. here are some screenshots to demonstrate:
      this image above is the final output from Flash Builder
      this is the original from Flash Catalyst. As you can see at the top it has: File, View, Control, Help. How do i add this in Flash Builder for my final output?
      Message was edited by: robert kirkwood
        • 1. Re: Adding main menu bar to project
          Mr. Kirkwood Level 1
          i found a way around this. i created a button in Flash Catalyst.
          I gave it a property of opening a URL
          i then edited the button in Flash Builder in the mxml by copy pasting this code over the code for calling on the URL:
          protected
          function button_clickHandler_26():void
          var newState:String;
          if (stage.displayState == StageDisplayState.FULL_SCREEN)
          newState = StageDisplayState.NORMAL;
          else
          newState = StageDisplayState.FULL_SCREEN;
          try {
          stage.displayState = newState;
          catch (any:*) {
          //ignore
          now i can just go to full screen without needing the main menu bar...
          this information came from this website:
          http://flashcats.net/2010/06/09/going-fullscreen/
