3 Replies Latest reply on Apr 16, 2011 2:31 AM by Anstellos1
    Detecting Megapixels to do proper actions
    Anstellos1 Level 1
      I am a photographer. here is the situation:
      I have several pictures from different cameras (different megapixels) and different files format (RAW JPG)
      I'm looking for a javascript that tells photoshop to "detect" the document megapixels and then apply an action I already created.
      it would go like:
      If active document megapixel count is < 5 MP then do action 5 MP -
      If active document megapixel count is between 5 MP and 10 MP then do action 5-10 MP
      If active document megapixel count is between 10 MP and 15 MP then do action 10-15 MP ect...
      the problem is I don't find a command that would make a "pixel count" if I use the document size I m worried that a big raw file would be detect as "big megapixels" and a small jpegs like it was a small megapixels if it makes sense ?
      Do you have an idea ? How would you write that in java script ?
      regards
        • 1. Re: Detecting Megapixels to do proper actions
          Paul Riggott Level 6
          You could do something like this...
          #target photoshop
          main();
          function main(){
          if(!documents.length) return;
          var Width = activeDocument.width.as('px');
          var Height = activeDocument.height.as('px');
          var megaPixels = (((Width * Height) / 1000)/1000).toFixed(3);
          //amend ActionName,ActionSet to suit.
          if(megaPixels < 5) doAction("ActionName","ActionSet");
          if(megaPixels >= 5 && megaPixels < 10) doAction("ActionName","ActionSet");
          if(megaPixels >= 10 ) doAction("ActionName","ActionSet");
          • 2. Re: Detecting Megapixels to do proper actions
            Anstellos1 Level 1
            Thanks its working like a charm ^^
            • 3. Re: Detecting Megapixels to do proper actions
              Anstellos1 Level 1
              I would like now to go a bit further:
              First I would like to detect document megapixel size using your script (working!)
              then if the megapixel count is bigger than 1.35 MP (1350px) I will have a new script detecting if the document is horizontal, vertical or a square. in fact my actions resize document to be maximum 1350 px wide or height. Maybe I can write the command directly into the script instead of calling actions ? is there a way to transform a photoshop action directly into java script ?
              the correct formula doesn't look like "else"
              I wrote it this way but its not working, an idea?
              #target photoshop
              main();
              function main(){
              var doc = activeDocument;
              var megaPixels = (((Width * Height)).toFixed(3);
              if(megaPixels < 1350) doAction("action","action set");
              else
              if(doc.width.value>=doc.height.value){//Landscape
              doAction("actionH", "action set");
              }else if(doc.width.value==doc.height.value){//square
              }else{//Portrait
              doAction("actionV", "action set");
