8 Replies Latest reply on Apr 25, 2011 9:10 AM by flexy_flex
    Robohelp javascript without popup?
    flexy_flex
      Is there a robohelp javascript command to open help in a given window instead of a popup window?
      Currently I'm trying these commands:
           <p>Click for <A HREF='javascript:RH_ShowHelp(0, "helpContent/index.htm", 0, 10)'>Help</A> (map number 10)</p>
           <p>Click for <A HREF='javascript:RH_ShowHelp(0, "helpContent/index.htm>_self", 0, 100)'>Help in custom window (map number 100)</A></p>
      These both attempt to open popup windows which are hitting my popup blocker.
      I'd like to tell the help to open in a target div or even just a plain new browser window (not a popup).  Is there a command available for this or do I have to re-write the help scripts?
        • 1. Re: Robohelp javascript without popup?
          RoboColum(n) Level 5
          I think you just need to specify the name of the help window you require the display the help in after the RH_ShowHelp command. For example:
          <p>Click for <A HREF='javascript:RH_ShowHelp(0, "helpContent/index.htm">windowname, 0, 10)'>Help</A> (map number 10)</p>
            The RoboColum(n)   @robocolumn   Colum McAndrew
          • 2. Re: Robohelp javascript without popup?
            flexy_flex Level 1
            When I try the line you gave I get the following in my error console:
            Error: a_pszHelpFile.indexOf is not a function
                 Source File: http://ux/HelpTest/RoboHelp_CSH.js
                 Line: 179
            Looking into the javascript, the second parameter you gave ("helpContent/index.htm">windowname) equates to false.
            Assuming you meant to keep the '>' within the string, I have the same issue as before.
            One solution that I have stumbled upon is referring to the resources directly via hashmarks (#).
              myIframe.src = 'helpContent/index.htm#myHelpSubtopic.htm#anAnchorWithinMySubtopic';
            • 3. Re: Robohelp javascript without popup?
              johndaigle Level 4
              (Warning. I'm not a programmer, but play one on TV )
              Two things I'm curious about. First you mention an error
              <snip>
                   Line: 179
              </snip>
              Normally when using the WebHelp (JavaScript) API, I place a script src tag under the first Head tag like so:
              <HEAD>
              <script src="RoboHelp_CSH.js"></script>
              This way, any functions that are called know where to look. (But I may just be mis-reading your snip?)
              As for the call itself, I use this syntax:
              <a href="javascript:RH_ShowHelp(0,'WebHelp/default.htm>SinglePaneHelp', HH_HELP_CONTEXT, 5)">Help</a>
              ...where SinglePaneHelp is the name of my popup window and 5 is the Map Number.
              I have an article that might help. It's very old, but still valid today.
              http://www.adobe.com/devnet-archive/robohelp/articles/context_help.htm
              Hope this helps.
              John Daigle
              Adobe Certified RoboHelp and Captivate Instructor
              Evergreen, Colorado
              www.showmethedemo.com
              • 4. Re: Robohelp javascript without popup?
                johndaigle Level 4
                A couple of things I missed upon re-reading your post.The subject line
                I forgot to mention that this method does require that popup blockers are disabled. Sorry I missed that obvious point!
                Your creative ideas about using a target div are interesting but I've never done this.
                Meanwhile, here is another resource for calling CSH that does not use the WebHelp API.
                http://www.techscribe.co.uk/ta/web-to-help.htm
                You will also want to look at Peter Grainge's site
                http://www.grainge.org/pages/authoring/calling_webhelp/calling_webhelp.htm
                If you are going to use the WebHelp API, make sure you have defined a new Window in RoboHelp in the first place.
                To create a new window, go to the Project Set-up Pod and create a new window. You can give it a relative size and position on the screen. Then give it a name (no spaces).
                I usually have one called WithNavPane and NoNavPane in case I want the CSH topic to open with or without the Navigation Pane.
                Then, when you generate the WebHelp, those window definitions will be ready to deliver.
                John Daigle
                Evergreen, Colorado
                • 5. Re: Robohelp javascript without popup?
                  flexy_flex Level 1
                  Thanks for the links and tips on using the RoboHelp API.
                  I need to make a correction to my comments as well...
                  The method I said worked actually only works for non-Safari.  Safari doesn't like having double hashes (necessary to reach an anchor inside a page).  You just get the second hash url encoded as %23 .  Interestingly I believe that this is proper behavior as #'s are not allowed after #'s in the URL standard.
                  I have bumped another Adobe Forum thread regarding this here: http://forums.adobe.com/message/3618123#3618123.
                  So... still searching for an answer on this one.
                  I'll read through your docs and see if I can find any further insight.
                  • 6. Re: Robohelp javascript without popup?
                    flexy_flex Level 1
                    I read through the pages and tried their links.  It looks like the same conclusions as we've talked about.
                    There's a way to use Javascript (which causes popups), there's a way to refer by HTML (which works fine except except for referencing anchors in Safari).
                    Hopefully someone out there has a way of using RoboHelp without popups and that can call anchor tags within articles that works on Safari?
                    • 7. Re: Robohelp javascript without popup?
                      Is the objective to open the help with a link from an HTML page (non RoboHelp) or to open a topic in a different window from the topic with the link?
                      @petergrainge
                      • 8. Re: Robohelp javascript without popup?
                        flexy_flex Level 1
                        I'm using a floating DIV tag with IFRAME to provide help for a web-based Flash app.  Pop-ups are not considered acceptable because of pop-up blockers.
                        It's all working on non-Safari browsers (Chrome, Firefox and even IE), but I will have to re-write my help pages (which will be sub-par even though it works) to not require anchor level references if I can't get it to work on Safari.
