17 Replies Latest reply on May 18, 2011 3:00 AM by Mohammad Tahseen
    Premiere Elements 9 Crashes
    obeydesign
      Starting application and starting new project gets as far as name new project dialogue box, then the application hangs. Notice in lower left corner stays at, "initializing the user interface." Quitting coughs up an error message (attached).
      Crash log is as follows:
      Process:         Adobe Premiere Elements [490]
      Path:            /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/Adobe Premiere Elements
      Identifier:      com.adobe.Adobe Premiere Elements.framework
      Version:         N224.08092010.240488 (9.0)
      Code Type:       X86 (Native)
      Parent Process:  launchd [173]
      Date/Time:       2011-04-14 17:56:32.912 -0400
      OS Version:      Mac OS X 10.6.7 (10J869)
      Report Version:  6
      Interval Since Last Report:          456281 sec
      Crashes Since Last Report:           11
      Per-App Interval Since Last Report:  3540 sec
      Per-App Crashes Since Last Report:   3
      Anonymous UUID:                      5FDFAEB2-103A-4E07-B2CF-AC303755E480
      Exception Type:  EXC_BREAKPOINT (SIGTRAP)
      Exception Codes: 0x0000000000000002, 0x0000000000000000
      Crashed Thread:  0  Dispatch queue: com.apple.main-thread
      Thread 0 Crashed:  Dispatch queue: com.apple.main-thread
      0   com.adobe.dvacore.framework   0x0018cebc dvacore::utility::ThreadSafeMessageDialog(char const*) + 380
      1   com.adobe.dvacore.framework   0x0009baab dvacore::debug::BreakAfterContractDialog(char const*, char const*, int) + 251
      2   ...adobe.UIFramework.framework 0x01186140 UIF::Static::Destroy() + 176
      3   ...HandlerMovieTheme.framework 0x0ba369d9 HandlerMovieTheme::MovieThemeEditOptionsView::DestroySelf() + 25
      4   ...adobe.UIFramework.framework 0x011dca96 UIF::OSWindow::DestroyWindow() + 22
      5   ...HandlerMovieTheme.framework 0x0ba37621 HandlerMovieTheme::MovieThemeAllOptionsView::DestroySelf() + 113
      6   ...adobe.UIFramework.framework 0x011dca96 UIF::OSWindow::DestroyWindow() + 22
      7   ...HandlerMovieTheme.framework 0x0ba68b6e HandlerMovieTheme::MovieThemeView::DestroySelf() + 158
      8   ...adobe.UIFramework.framework 0x011dca96 UIF::OSWindow::DestroyWindow() + 22
      9   ...HandlerMovieTheme.framework 0x0ba635de HandlerMovieTheme::MovieThemeHandler::~MovieThemeHandler() + 174
      10  ...adobe.premiere-elements.HSL 0x09394286 HSL::Handler::Terminate() + 246
      11  com.adobe.Frontend.framework  0x06091491 FE::HandlerManager::DestroyHandlers() + 17
      12  com.adobe.Frontend.framework  0x06067cb2 FE::Document::~Document() + 306
      13  com.adobe.Frontend.framework  0x06075733 FE::DocumentManager::CloseDocumentWithPrompt(bool, bool) + 1891
      14  com.adobe.Frontend.framework  0x06075f21 FE::DocumentManager::CloseDocument() + 33
      15  com.adobe.Frontend.framework  0x06090d92 FE::DocumentManager::ObeyCommand(UIF::Command const&) + 626
      16  ...adobe.UIFramework.framework 0x010a1d6c UIF::Commander::PostCommand(UIF::Command const&) + 44
      17  com.adobe.Frontend.framework  0x060a42d2 FE::MainFrameDefaultCommander::ObeyCommand(UIF::Command const&) + 194
      18  com.adobe.Frontend.framework  0x060c8686 FE::MainFrame::ObeyCommand(UIF::Command const&) + 262
      19  ...adobe.UIFramework.framework 0x010a1e7c UIF::Commander::PostCommand(int) + 60
      20  com.adobe.Frontend.framework  0x060c86c7 FE::MainFrame::ObeyCommand(UIF::Command const&) + 327
      21  ...adobe.UIFramework.framework 0x010a1d6c UIF::Commander::PostCommand(UIF::Command const&) + 44
      22  ...dobe.EUIFramework.framework 0x06aab420 UIF::ShortcutManagerImpl::TranslateKeyboardEvent(dvaui::ui::KeyboardEvent const&, bool) const + 304
      23  ...dobe.EUIFramework.framework 0x06aab687 UIF::ShortcutManagerImpl::DispatchKeyboardEvent(dvaui::ui::KeyboardEvent const&, bool) const + 167
      24  com.adobe.Frontend.framework  0x060adddb FE::ViewContainer::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 123
      25  ...adobe.UIFramework.framework 0x011da02e UIF::OSWindowImpl::UI_DoKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 46
      26  com.adobe.dvaui.framework     0x005395f3 dvaui::ui::UI_Node::UI_DispatchKeyboardEventToNode(dvaui::ui::UI_Node*, dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 115
      27  com.adobe.dvaui.framework     0x0053f457 dvaui::ui::UI_Node::UI_DispatchKeyboardEvent(dvaui::ui::UI_Node*, dvaui::ui::KeyboardEvent const&) + 375
      28  com.adobe.dvaui.framework     0x005a814f dvaui::ui::OS_Node::UI_DispatchKeyboardEventFromOS(dvaui::ui::OS_Event*) + 191
      29  com.adobe.dvaui.framework     0x005b1b89 dvaui::ui::OS_Window::UI_DispatchEvent(dvaui::ui::OS_Event*) + 73
      30  com.adobe.dvaui.framework     0x005c61e7 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<bool, boost::_mfi::mf1<bool, dvaui::ui::OS_Window, dvaui::ui::OS_Event*>, boost::_bi::list2<boost::_bi::value<dvaui::ui::OS_Window*>, boost::_bi::value<dvaui::ui::OS_Event*> > >, bool>::invoke(boost::detail::function::function_buffer&) + 55
      31  com.adobe.dvaui.framework     0x004c2d69 boost::function0<bool>::operator()() const + 41
      32  com.adobe.dvaui.framework     0x004c2fa1 int dvacore::config::ErrorManager::ExecuteFunction<bool>(boost::function0<bool>*, bool*) + 17
      33  com.adobe.dvaui.framework     0x004c1ea8 boost::detail::function::function_obj_invoker0<boost::_bi::bind_t<int, int (*)(boost::function0<bool>*, bool*), boost::_bi::list2<boost::_bi::value<boost::function0<bool>*>, boost::_bi::value<bool*> > >, int>::invoke(boost::detail::function::function_buffer&) + 24
      34  com.adobe.Frontend.framework  0x0605e199 FE::ApplicationErrorManager::ExecuteFunctionWithTopLevelExceptionHandler(boost::function0 <int>) + 41
      35  com.adobe.dvaui.framework     0x004c2870 bool dvacore::config::ErrorManager::ExecuteFunctionWithTopLevelExceptionHandler<bool>(boost::f unction0<bool>, bool*) + 160
      36  com.adobe.dvaui.framework     0x004c2eec bool dvacore::config::ExecuteTopLevelFunction<bool>(boost::function0<bool>, bool*) + 92
      37  com.adobe.dvaui.framework     0x005c0ef9 -[DVAMacPanelWindow performKeyEquivalent:] + 297
      38  com.apple.AppKit              0x95f511e1 -[NSApplication _handleKeyEquivalent:] + 211
      39  com.apple.AppKit              0x95e471f2 -[NSApplication sendEvent:] + 4858
      40  com.adobe.dvaui.framework     0x005afa98 -[DVAMacApplication sendEvent:] + 184
      41  com.apple.AppKit              0x95ddb2a7 -[NSApplication run] + 917
      42  com.adobe.Frontend.framework  0x060e8f66 FE::MacApplication::RunSelf(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 214
      43  com.adobe.Frontend.framework  0x06049a27 FE::Application::Run(std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&) + 1079
      44  com.adobe.Frontend.framework  0x060ec28a AppMain + 298
      45  com.adobe.Startup.framework   0x062cfd30 (anonymous namespace)::LaunchFrontendFramework(ASL::ObjectPtr<ASL::Module, ASL::AtomicValue> const&, std::basic_string<unsigned short, std::char_traits<unsigned short>, dvacore::utility::SmallBlockAllocator::STLAllocator<unsigned short> > const&, int, void*) + 176
      46  ...Premiere Elements.framework 0x000038c6 (anonymous namespace)::CallStartupFramework(int, char const* const*) + 246
      47  ...Premiere Elements.framework 0x00003e85 main + 229
      48  ...Premiere Elements.framework 0x00003736 start + 54
      Thread 1:  Dispatch queue: com.apple.libdispatch-manager
      0   libSystem.B.dylib             0x90141922 kevent + 10
      1   libSystem.B.dylib             0x9014203c _dispatch_mgr_invoke + 215
      2   libSystem.B.dylib             0x901414f9 _dispatch_queue_invoke + 163
      3   libSystem.B.dylib             0x9014129e _dispatch_worker_thread2 + 240
      4   libSystem.B.dylib             0x90140d21 _pthread_wqthread + 390
      5   libSystem.B.dylib             0x90140b66 start_wqthread + 30
      Thread 2:
      0   libSystem.B.dylib             0x90149046 __semwait_signal + 10
      1   libSystem.B.dylib             0x90148d02 _pthread_cond_wait + 1191
      2   libSystem.B.dylib             0x9014a998 pthread_cond_wait$UNIX2003 + 73
      3   ...ple.CoreServices.CarbonCore 0x92f1948e TSWaitOnCondition + 126
      4   ...ple.CoreServices.CarbonCore 0x92f04e15 TSWaitOnConditionTimedRelative + 202
      5   ...ple.CoreServices.CarbonCore 0x92f007e3 MPWaitOnQueue + 250
      6   com.adobe.dvacore.framework   0x000ee3da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      7   com.adobe.dvacore.framework   0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      8   com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      9   com.adobe.dvacore.framework   0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      10  com.adobe.dvacore.framework   0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      11  ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      12  libSystem.B.dylib             0x901487fd _pthread_start + 345
      13  libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 3:
      0   libSystem.B.dylib             0x9011b0e2 semaphore_wait_signal_trap + 10
      1   libSystem.B.dylib             0x90148c9c _pthread_cond_wait + 1089
      2   libSystem.B.dylib             0x9019145f pthread_cond_wait + 48
      3   com.adobe.amt.services        0x145774ba C_AMTUISwitchSuppressUpdates + 16864
      4   com.adobe.amt.services        0x1457049c C_EULA_SetState + 2166
      5   com.adobe.amt.services        0x14577520 C_AMTUISwitchSuppressUpdates + 16966
      6   libSystem.B.dylib             0x901487fd _pthread_start + 345
      7   libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 4:
      6   ...e.Frameworks.ASL.Foundation 0x014e364e ASL::(anonymous namespace)::TaskProc(void*) + 94
      7   ...ple.CoreServices.CarbonCore 0x92ee47ca PrivateMPEntryPoint + 68
      8   libSystem.B.dylib             0x901487fd _pthread_start + 345
      9   libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 5:
      1   libSystem.B.dylib             0x90174ec5 nanosleep$UNIX2003 + 188
      2   ScriptLayer                   0x0be9e17b ScObjects::Thread::sleep(unsigned int) + 59
      3   ScriptLayer                   0x0be86e13 ScObjects::BridgeTalkThread::run() + 163
      4   ScriptLayer                   0x0be9e288 ScObjects::Thread::go(void*) + 168
      5   libSystem.B.dylib             0x901487fd _pthread_start + 345
      6   libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 6:
      6   AdobeACE                      0x049b26f1 0x4978000 + 239345
      7   AdobeACE                      0x049b20ed 0x4978000 + 237805
      8   ...ple.CoreServices.CarbonCore 0x92ee47ca PrivateMPEntryPoint + 68
      9   libSystem.B.dylib             0x901487fd _pthread_start + 345
      10  libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 7:
      Thread 8:
      Thread 9:
      Thread 10:
      Thread 11:
      Thread 12:
      Thread 13:
      Thread 14:
      1   ...dobe.dvatransport.framework 0x0167e1e3 boost::asio::detail::kqueue_reactor<false>::run(bool) + 531
      2   ...dobe.dvatransport.framework 0x0167f409 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 489
      3   ...dobe.dvatransport.framework 0x0165b33e SkyConnectionEnv::MainLoop() + 94
      4   ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      Thread 15:
      3   ...dobe.dvatransport.framework 0x0167f6c2 boost::asio::detail::task_io_service<boost::asio::detail::kqueue_reactor<false> >::run(boost::system::error_code&) + 1186
      4   ...dobe.dvatransport.framework 0x01680133 boost::asio::detail::posix_thread::func<boost::asio::detail::resolver_service<boost::asio ::ip::tcp>::work_io_service_runner>::run() + 51
      5   ...dobe.dvatransport.framework 0x01664fa7 asio_detail_posix_thread_function + 23
      Thread 16:
      0   libSystem.B.dylib             0x9011b09a mach_msg_trap + 10
      1   libSystem.B.dylib             0x9011b807 mach_msg + 68
      2   com.apple.CoreFoundation      0x9370637f __CFRunLoopRun + 2079
      3   com.apple.CoreFoundation      0x93705464 CFRunLoopRunSpecific + 452
      4   com.apple.CoreFoundation      0x93705291 CFRunLoopRunInMode + 97
      5   com.apple.audio.CoreAudio     0x92d0396e HALRunLoop::OwnThread(void*) + 162
      6   com.apple.audio.CoreAudio     0x92cef4a4 CAPThread::Entry(CAPThread*) + 140
      7   libSystem.B.dylib             0x901487fd _pthread_start + 345
      8   libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 17:
      0   libSystem.B.dylib             0x9011b0fa semaphore_timedwait_signal_trap + 10
      1   libSystem.B.dylib             0x90148c85 _pthread_cond_wait + 1066
      2   libSystem.B.dylib             0x90177aa8 pthread_cond_timedwait_relative_np + 47
      3   ...ple.CoreServices.CarbonCore 0x92f04e3d TSWaitOnConditionTimedRelative + 242
      4   ...ple.CoreServices.CarbonCore 0x92f007e3 MPWaitOnQueue + 250
      5   com.adobe.dvacore.framework   0x000ee3da dvacore::threads::(anonymous namespace)::ThreadedWorkQueue::WorkerMain(boost::shared_ptr<dvacore::threads::ThreadSafeD elayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&) + 154
      6   com.adobe.dvacore.framework   0x000ea26a boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, void (*)(boost::shared_ptr<dvacore::threads::ThreadSafeDelayQueue> const&, boost::shared_ptr<dvacore::threads::Gate> const&), boost::_bi::list2<boost::_bi::value<boost::shared_ptr<dvacore::threads::ThreadSafeDelayQu eue> >, boost::_bi::value<boost::shared_ptr<dvacore::threads::Gate> > > >, void>::invoke(boost::detail::function::function_buffer&) + 26
      7   com.adobe.dvacore.framework   0x00076c79 boost::function0<void>::operator()() const + 41
      8   com.adobe.dvacore.framework   0x000e6cdd dvacore::threads::(anonymous namespace)::LaunchThread(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&) + 109
      9   com.adobe.dvacore.framework   0x000e7bd0 boost::detail::thread_data<boost::_bi::bind_t<void, void (*)(std::string const&, boost::function0<void> const&, dvacore::threads::ThreadPriority, boost::function<void ()()> const&, boost::function<void ()()> const&), boost::_bi::list5<boost::_bi::value<std::string>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<dvacore::threads::ThreadPriority>, boost::_bi::value<boost::function<void ()()> >, boost::_bi::value<boost::function<void ()()> > > > >::run() + 64
      10  ...obe.boost_threads.framework 0x0002f6ed thread_proxy + 141
      11  libSystem.B.dylib             0x901487fd _pthread_start + 345
      12  libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 18:
      Thread 19:
      Thread 20:
      Thread 21:
      Thread 22:
      6   com.adobe.CameraRaw           0x40734158 0x40533000 + 2101592
      7   com.adobe.CameraRaw           0x40733a56 0x40533000 + 2099798
      Thread 23:
      3   com.adobe.CameraRaw           0x40578dca 0x40533000 + 286154
      4   com.adobe.CameraRaw           0x4089ecd4 EntryFM + 894068
      5   com.adobe.CameraRaw           0x40639606 0x40533000 + 1074694
      Thread 24:
      4   com.apple.CoreFoundation      0x9370b3a4 CFRunLoopRun + 84
      5   com.adobe.dvacore.framework   0x000d9867 dvacore::threads::RunPlatformEventLoop() + 103
      6   com.adobe.dvacore.framework   0x000df24a dvacore::threads::(anonymous namespace)::EventLoopExecutor::EventLoopMain(dvacore::threads::SyncPoint&) + 154
      7   com.adobe.dvacore.framework   0x000def27 boost::detail::function::void_function_obj_invoker0<boost::_bi::bind_t<void, boost::_mfi::mf1<void, dvacore::threads::(anonymous namespace)::EventLoopExecutor, dvacore::threads::SyncPoint&>, boost::_bi::list2<boost::_bi::value<dvacore::threads::(anonymous namespace)::EventLoopExecutor*>, boost::reference_wrapper<dvacore::threads::SyncPoint> > >, void>::invoke(boost::detail::function::function_buffer&) + 55
      Thread 25:
      0   libSystem.B.dylib             0x9011b0ee semaphore_timedwait_trap + 10
      1   ...ple.CoreServices.CarbonCore 0x92f16bb2 MPWaitOnSemaphore + 125
      2   com.adobe.ols.library         0x434d6737 OLSSemaphore::Wait(unsigned int) + 271
      3   com.adobe.ols.library         0x434b6502 OLSWorkerThreadTaskManager::ProcessTasks(OLSTaskThread*) + 1110
      4   com.adobe.ols.library         0x434b5037 OLSTaskThread::Run() + 27
      5   com.adobe.ols.library         0x434d7633 OLSThread::ThreadProc(void*) + 29
      6   ...ple.CoreServices.CarbonCore 0x92ee47ca PrivateMPEntryPoint + 68
      Thread 26:
      0   libSystem.B.dylib             0x901263e2 open$UNIX2003 + 10
      1   com.adobe.Frontend.framework  0x06098646 FE::(anonymous namespace)::waitformsg(void*) + 86
      Thread 27:
      Thread 28:
      3   com.adobe.adobeswfl           0x45d9d1af APXGetHostAPI + 2599055
      4   com.adobe.adobeswfl           0x45b36b0f APXGetHostAPI + 82415
      5   com.adobe.adobeswfl           0x45d9d29c APXGetHostAPI + 2599292
      6   com.adobe.adobeswfl           0x45d9d307 APXGetHostAPI + 2599399
      7   com.adobe.adobeswfl           0x45d9d426 APXGetHostAPI + 2599686
      Thread 29:
      Thread 30:
      3   com.adobe.adobeswfl           0x45d9d177 APXGetHostAPI + 2598999
      4   com.adobe.adobeswfl           0x45db80ee APXGetHostAPI + 2709454
      Thread 31:
      4   com.adobe.adobeswfl           0x45f144b8 APXGetHostAPI + 4135832
      Thread 32:
      2   ...ple.CoreServices.CarbonCore 0x92facaac TS_exception_listener_thread + 160
      3   libSystem.B.dylib             0x901487fd _pthread_start + 345
      4   libSystem.B.dylib             0x90148682 thread_start + 34
      Thread 33:  com.apple.CFSocket.private
      0   libSystem.B.dylib             0x9013a066 select$DARWIN_EXTSN + 10
      1   com.apple.CoreFoundation      0x93745c83 __CFSocketManager + 1091
      Thread 34:
      3   com.apple.audio.CoreAudio     0x92cef3c7 CAGuard::WaitFor(unsigned long long) + 219
      4   com.apple.audio.CoreAudio     0x92cf23f9 CAGuard::WaitUntil(unsigned long long) + 289
      5   com.apple.audio.CoreAudio     0x92cefcf6 HP_IOThread::WorkLoop() + 1892
      6   com.apple.audio.CoreAudio     0x92cef58d HP_IOThread::ThreadEntry(HP_IOThread*) + 17
      7   com.apple.audio.CoreAudio     0x92cef4a4 CAPThread::Entry(CAPThread*) + 140
      Thread 35:
      0   libSystem.B.dylib             0x901409b2 __workq_kernreturn + 10
      1   libSystem.B.dylib             0x90140f48 _pthread_wqthread + 941
      2   libSystem.B.dylib             0x90140b66 start_wqthread + 30
      Thread 36:
      Thread 0 crashed with X86 Thread State (32-bit):
        eax: 0x00000001  ebx: 0x0018cd4b  ecx: 0x00413440  edx: 0x00000001
        edi: 0x001ff648  esi: 0x001ff648  ebp: 0xbfffe568  esp: 0xbfffe120
         ss: 0x0000001f  efl: 0x00000246  eip: 0x0018cebc   cs: 0x00000017
         ds: 0x0000001f   es: 0x0000001f   fs: 0x00000000   gs: 0x00000037
        cr2: 0x01aac000
      Binary Images:
          0x1000 -     0x3ff3 +com.adobe.Adobe Premiere Elements.framework N224.08092010.240488 (9.0) <CB8EC92E-5E07-E764-529D-21859A900BF3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/Adobe Premiere Elements
          0xa000 -     0xeffc +com.adobe.AdobeCrashReporter 3.0 (3.0.20100302) <E6437929-0E69-8A56-E69F-F64305E82DD9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeCrashReporter.framework/Versions/A/AdobeCrashReport er
         0x15000 -    0x1bfef +com.adobe.boost_date_time.framework boost_date_time version 8.0.0 (8.0.0.0) <16B587FC-3B88-3CAC-EA49-49C8530A2284> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_date_time.framework/Versions/A/boost_date_time
         0x2d000 -    0x34ff2 +com.adobe.boost_threads.framework boost_threads version 8.0.0 (8.0.0.0) <52458199-9BBE-EA78-70CE-C078622684DE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_threads.framework/Versions/A/boost_threads
         0x44000 -   0x1c1fef +com.adobe.dvacore.framework dvacore version 8.0.0 (8.0.0.0) <DFED1A19-6BB6-A397-64DB-0D803AE2A846> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvacore.framework/Versions/A/dvacore
        0x343000 -   0x65dff7 +com.adobe.dvaui.framework dvaui version 8.0.0 (8.0.0.0) <84648108-9211-3A28-8B3F-A37CD997DFDF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaui.framework/Versions/A/dvaui
        0x9c3000 -   0xa70fff +com.adobe.dvaworkspace.framework dvaworkspace version 8.0.0 (8.0.0.0) <8F322FAB-F0B4-89C5-5138-F9AD91704D3A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaworkspace.framework/Versions/A/dvaworkspace
        0xb43000 -   0xbe8fff +com.adobe.exo.framework exo version 8.0.0 (8.0.0.0) <94AB2A24-AFD5-25DB-EF10-260F1883A98B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/exo.framework/Versions/A/exo
        0xcde000 -   0xdc2fef +com.adobe.dvaeve.framework dvaeve version 8.0.0 (8.0.0.0) <B9C18986-07F5-D9F7-0A6B-1CAA9467E65A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvaeve.framework/Versions/A/dvaeve
        0xec5000 -   0xf0efff +com.adobe.dvatemporalxmp.framework dvatemporalxmp version 8.0.0 (8.0.0.0) <0806FC8B-9321-3C1E-4B94-E505FF1BC157> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvatemporalxmp.framework/Versions/A/dvatemporalxmp
        0xf2f000 -   0xf87ff7 +AdobeXMP ??? (???) <73329999-C364-2451-6574-4D0277057D19> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeXMP.framework/Versions/A/AdobeXMP
        0xf96000 -  0x1022fef +AdobeXMPFiles ??? (???) <A72BD678-CAD0-0C2A-0989-11E87B154AB5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeXMPFiles.framework/Versions/A/AdobeXMPFiles
      0x1059000 -  0x124efef +com.adobe.UIFramework.framework ??? (1.0) <3CFEED6B-BFA2-2EEC-E57B-E62C1AD5E2C7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UIFramework.framework/Versions/A/UIFramework
      0x1458000 -  0x1479ff7 +com.adobe.dvamediatypes.framework dvamediatypes version 8.0.0 (8.0.0.0) <0FE20B37-7CEE-8FDE-573D-3EA193C705CB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvamediatypes.framework/Versions/A/dvamediatypes
      0x149a000 -  0x149affb +PRM ??? (???) <383A4352-5FE9-0D73-8E23-06A12D83E7B4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PRM.framework/Versions/A/PRM
      0x14a1000 -  0x150bff1 +com.adobe.MediaCore.Frameworks.ASL.Foundation 1.0 (1.0) <72B48D53-00DF-8C82-C7AA-01A9C282EAE0> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLFoundation.framework/Versions/A/ASLFoundation
      0x15c9000 -  0x15defff +ASLMessaging ??? (???) <1425780D-FF58-9F45-8357-86E2344A8F7F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLMessaging.framework/Versions/A/ASLMessaging
      0x15fd000 -  0x15fefff +com.adobe.MediaCore.Frameworks.Memory 1.0 (1.0) <ECBE5E96-AC61-6338-B7D8-80222B691F7E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Memory.framework/Versions/A/Memory
      0x1605000 -  0x1615ffd +ASLUnitTesting ??? (???) <1701C314-AEE9-7836-C783-3E8C97E3813E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ASLUnitTesting.framework/Versions/A/ASLUnitTesting
      0x162f000 -  0x1630ffb +com.adobe.boost_system.framework boost_system version 8.0.0 (8.0.0.0) <47EE4594-75B3-D887-7E1D-C47921C41436> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_system.framework/Versions/A/boost_system
      0x1638000 -  0x16a8fff +com.adobe.dvatransport.framework dvatransport version 8.0.0 (8.0.0.0) <D309BA02-0882-82AE-3B18-171E24E6CE8E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvatransport.framework/Versions/A/dvatransport
      0x1728000 -  0x1762ffb +com.adobe.dvamarshal.framework dvamarshal version 8.0.0 (8.0.0.0) <A478730D-8D42-AA39-A941-E9D72DDB9CE5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvamarshal.framework/Versions/A/dvamarshal
      0x17d8000 -  0x199dfe7 +com.adobe.dynamiclink.framework dynamiclink version 8.0.0 (8.0.0.0) <5167C3EA-0399-2029-DA70-9945BB53D9C2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dynamiclink.framework/Versions/A/dynamiclink
      0x1ac1000 -  0x1af5fe7 +com.adobe.MediaFoundation ??? (1.0) <60AC246A-218B-87F9-C52F-7C4AD0072191> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaFoundation.framework/Versions/A/MediaFoundation
      0x1b37000 -  0x1ba9ff7 +com.adobe.MediaCore.Frameworks.AudioRenderer ??? (1.0) <E042D5B6-B5AD-8CCB-6D91-9F29D2DBC04A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioRenderer.framework/Versions/A/AudioRenderer
      0x1c3a000 -  0x2762fe7 +com.adobe.MediaCore.Frameworks.Backend ??? (1.0) <54EA6B9C-A74A-9FA5-8CAB-97F540A84D4F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Backend.framework/Versions/A/Backend
      0x3402000 -  0x358effd +com.adobe.MediaCore.Frameworks.ImageRenderer ??? (1.0) <089DE64B-D83A-2FCE-23C6-C96B0B1B1C04> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ImageRenderer.framework/Versions/A/ImageRenderer
      0x367b000 -  0x36b3ff3 +com.adobe.MediaCore.Frameworks.MLFoundation 1.0 (1.0) <F8B76FB9-D7BA-67A9-6512-E55CC33BDA17> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MLFoundation.framework/Versions/A/MLFoundation
      0x3700000 -  0x374bff7 +com.adobe.MediaCore.VideoFrame 1.0 (1.0) <B4B640A4-7579-758A-F8FD-F7E0DE667776> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoFrame.framework/Versions/A/VideoFrame
      0x3794000 -  0x37cdfff +com.adobe.MediaCore.Frameworks.PluginSupport 1.0 (1.0) <4771E7E4-21D9-BE94-6392-4D5A96C11DD7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PluginSupport.framework/Versions/A/PluginSupport
      0x380c000 -  0x3845fff +com.adobe.MediaCore.Frameworks.SweetPeaSupport 1.0 (1.0) <2BC72003-AF23-F10E-A351-12288F540EC1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SweetPeaSupport.framework/Versions/A/SweetPeaSupport
      0x3895000 -  0x38dafef +com.adobe.MediaCore.Frameworks.AudioSupport 1.0 (1.0) <71378A35-591C-30DC-4612-C956B07B07B0> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioSupport.framework/Versions/A/AudioSupport
      0x3922000 -  0x3924ff3 +com.adobe.MediaCore.Frameworks.MediaUtils 1.0 (1.0) <01A20771-3B4B-5B32-B063-CE3B49B1FDC2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaUtils.framework/Versions/A/MediaUtils
      0x392b000 -  0x3944ff3 +com.adobe.MediaCore.Frameworks.AudioFilterHost 1.0 (1.0) <5C442959-81F1-F837-5314-4B741851585D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioFilterHost.framework/Versions/A/AudioFilterHost
      0x396b000 -  0x399efef +com.adobe.MediaCore.Frameworks.AudioFilters ??? (1.0) <2BE91FC6-0427-17B0-A14C-EEE21058AF7D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioFilters.framework/Versions/A/AudioFilters
      0x39fd000 -  0x3b16fff +com.adobe.MediaCore.Frameworks.VideoRenderer 1.0 (1.0) <2684671C-0FF5-7F68-7286-6F61A6A321E1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoRenderer.framework/Versions/A/VideoRenderer
      0x3c71000 -  0x3e0afff +com.adobe.MediaCore.Frameworks.ImporterHost 1.0 (1.0) <D5DC90DB-0C0B-C816-7220-E1614B45727A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ImporterHost.framework/Versions/A/ImporterHost
      0x3fb7000 -  0x4083fff +com.adobe.MediaCore.Frameworks.VideoFilterHost 1.0 (1.0) <309D712C-3663-F041-D848-A7C6D38EAECE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VideoFilterHost.framework/Versions/A/VideoFilterHost
      0x4139000 -  0x41d3ff3 +com.adobe.MediaCore.Frameworks.TimeWarpFilter 1.0 (1.0) <E88D632C-8F60-BE3B-1905-4D3C27920E6C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TimeWarpFilter.framework/Versions/A/TimeWarpFilter
      0x4238000 -  0x42fcfff +com.adobe.MediaCore.Frameworks.ExporterHost 1.0 (1.0) <6F6A034B-CC8D-718A-2657-F8EB2A2DDF03> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ExporterHost.framework/Versions/A/ExporterHost
      0x440c000 -  0x4481fff +com.adobe.MediaCore.Frameworks.PlayerHost 1.0 (1.0) <794A5DD8-FE64-6261-D575-A810CE87E711> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PlayerHost.framework/Versions/A/PlayerHost
      0x4514000 -  0x4583ff7 +com.adobe.MediaCore.Frameworks.RecorderHost 1.0 (1.0) <CB8C425E-AD82-BD69-FC27-3DF2FF3E7E5F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/RecorderHost.framework/Versions/A/RecorderHost
      0x45fc000 -  0x4608ff7 +com.adobe.MediaCore.Frameworks.ProjectConverterHost 1.0 (1.0) <079087AB-3AAD-C1EC-72DA-08118629F791> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ProjectConverterHost.framework/Versions/A/ProjectConvert erHost
      0x461b000 -  0x4628ff3 +com.adobe.MediaCore.Frameworks.ProjectSupport 1.0 (1.0) <213D4CF3-E724-A46C-B63B-0FEFC9F7526D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ProjectSupport.framework/Versions/A/ProjectSupport
      0x463c000 -  0x4653fff +com.adobe.AMEAppFoundation.framework ??? (1.0) <E0CCB9E9-76EA-B8AD-FC20-472E14BCB1DB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMEAppFoundation.framework/Versions/A/AMEAppFoundation
      0x4674000 -  0x4695ffd +com.adobe.PostEncodeHost.framework ??? (1.0) <37AA1110-24C5-AC18-1909-26E1B0978560> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PostEncodeHost.framework/Versions/A/PostEncodeHost
      0x46c1000 -  0x46dcfff +AdobeBIB ??? (???) <6E3DC6A9-066C-B736-6465-7F91D18860FB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeBIB.framework/Versions/A/AdobeBIB
      0x46e6000 -  0x4773ff7 +com.adobe.AdobeScCore ScCore 4.1.23 (4.1.23.7471) <491BB523-30A6-E426-1C5D-799578012E33> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeScCore.framework/Versions/A/AdobeScCore
      0x47b8000 -  0x4850fff +com.adobe.AdobeExtendScript ExtendScript 4.1.23 (4.1.23.7471) <ADBFBE50-AFEC-FFFE-B1C2-08EA2B3BE434> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeExtendScript.framework/Versions/A/AdobeExtendScript
      0x48af000 -  0x4902ff2 +com.adobe.MediaCore.Frameworks.BravoInitializer 1.0 (1.0) <633C71E4-B4D6-40D9-3DFE-F9C508149808> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/BravoInitializer.framework/Versions/A/BravoInitializer
      0x4978000 -  0x4a8cfff +AdobeACE ??? (???) <DD291A17-ECF4-FE20-5837-AC1F5BC76940> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeACE.framework/Versions/A/AdobeACE
      0x4aaf000 -  0x4dbeff7 +AdobeAGM ??? (???) <202752CE-8950-5114-DD17-D5B087297A1F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeAGM.framework/Versions/A/AdobeAGM
      0x4e74000 -  0x5166ff7 +AdobeCoolType ??? (???) <AEC9EB8F-2122-1708-3207-2A8BE3308FFA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeCoolType.framework/Versions/A/AdobeCoolType
      0x51ee000 -  0x52b2fff +AMEWrapper ??? (???) <D78F3EA9-0CBE-0A29-B22C-865792530CE1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMEWrapper.framework/Versions/A/AMEWrapper
      0x5367000 -  0x5479fff +com.adobe.EncoderHost.framework ??? (1.0) <D19AC057-A2B1-D223-F601-9E816AECC162> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/EncoderHost.framework/Versions/A/EncoderHost
      0x5571000 -  0x5bb5fff +com.adobe.Mezzanine.framework ??? (1.0) <B44A1811-D89D-0CD9-AAF5-7BE707AFC401> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Mezzanine.framework/Versions/A/Mezzanine
      0x6041000 -  0x6180ffb +com.adobe.Frontend.framework ??? (1.0) <147702DE-20F1-47F6-8741-F698C8CCC5E2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Frontend.framework/Versions/A/Frontend
      0x62cb000 -  0x62f8fef +com.adobe.Startup.framework ??? (1.0) <FC6A40F0-A58B-38DC-B905-5791B340CF9F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Startup.framework/Versions/A/Startup
      0x6316000 -  0x6356ff7  com.apple.vmutils 4.2 (106) <834EA6B0-C91B-4CF1-ED3C-229C26459578> /System/Library/PrivateFrameworks/vmutils.framework/Versions/A/vmutils
      0x636f000 -  0x6379ffd +com.adobe.boost_signals.framework boost_signals version 8.0.0 (8.0.0.0) <39CDA60E-525C-5D5D-F8B5-C0874C9210BF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/boost_signals.framework/Versions/A/boost_signals
      0x638c000 -  0x661afec +libxerces-c-3.0.dylib ??? (???) <CDE6FF46-6D9A-55B9-7DF8-CEB48EBB54B9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libxerces-c-3.0.dylib
      0x679d000 -  0x679dff7  libmx.A.dylib 315.0.0 (compatibility 1.0.0) <01401BF8-3FC7-19CF-ACCE-0F292BFD2F25> /usr/lib/libmx.A.dylib
      0x67a0000 -  0x67caff3  com.apple.carbonframeworktemplate 1.0 (1.0) <19F5963C-F6A9-8012-A9DD-E26B1E10AF7C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amefoundation.framework/Versions/A/amefoundation
      0x6806000 -  0x682dfff +ameproperties ??? (???) <8E495A98-DA0B-DFF1-2FF6-D681C37620C8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ameproperties.framework/Versions/A/ameproperties
      0x686e000 -  0x688fff7 +AdobeBIBUtils ??? (???) <5CD3EBDF-A36B-D8E4-587B-AE297DEB32AA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeBIBUtils.framework/Versions/A/AdobeBIBUtils
      0x689b000 -  0x689effc +com.adobe.AppServices.framework ??? (1.0) <4F73A218-468F-900C-2312-F7CA04DA0945> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AppServices.framework/Versions/A/AppServices
      0x68a9000 -  0x68ffffb +com.adobe.headlights.LogSessionFramework ??? (2.0.1.013) <0AD52D68-CDB5-CB04-2CDD-1FCF5CF6CABE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/LogSession.framework/Versions/A/LogSession
      0x6948000 -  0x69fdfe7  libcrypto.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <0B69B1F5-3440-B0BF-957F-E0ADD49F13CB> /usr/lib/libcrypto.0.9.7.dylib
      0x6a43000 -  0x6b7efff +com.adobe.EUIFramework.framework ??? (1.0) <974AA901-74E7-833E-A18D-4F8AE5223C13> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/EUIFramework.framework/Versions/A/EUIFramework
      0x6cd8000 -  0x6ec2fff +com.adobe.SettingsUI.framework ??? (1.0) <3D9B681B-D5B0-42A5-896D-832C991B423B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SettingsUI.framework/Versions/A/SettingsUI
      0x70d9000 -  0x70eafff +com.adobe.DVDStructures.framework ??? (1.0) <093FD84B-330C-94B7-989A-936F12297C08> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/DVDStructures.framework/Versions/A/DVDStructures
      0x7107000 -  0x752cfef +com.adobe.AMocWrapper.framework ??? (1.0) <34ECBBFF-68ED-E7A3-F6C6-50A49178D7F6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AMocWrapper.framework/Versions/A/AMocWrapper
      0x7750000 -  0x7757ff3 +com.adobe.ContentAnalysisDBCache.framework ??? (1.0) <78003AB9-2CF4-53CB-8EFB-FDDE0F069082> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisDBCache.framework/Versions/A/ContentAnaly sisDBCache
      0x7763000 -  0x77a6ff3 +com.adobe.ContentAnalysisData.framework ??? (1.0) <BCC67E4C-03C9-D29D-B039-C73FF039A85F> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisData.framework/Versions/A/ContentAnalysis Data
      0x7808000 -  0x7838fff +com.adobe.ContentAnalysisHost.framework ??? (1.0) <09852D0F-1F7A-DBD4-B2AD-66F66B8444B6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ContentAnalysisHost.framework/Versions/A/ContentAnalysis Host
      0x786b000 -  0x786ffff +com.adobe.BackendLegacyLib.framework ??? (1.0) <5850830D-48A5-27DA-EAD1-7A5A0E666471> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/BackendLegacyLib.framework/Versions/A/BackendLegacyLib
      0x7877000 -  0x7992fef +com.adobe.TitlerCreator.framework ??? (1.0) <AE329D7B-9784-C7FD-E261-612F3BE2F1EE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitlerCreator.framework/Versions/A/TitlerCreator
      0x7b14000 -  0x7e61ffb +com.adobe.premiere.TitleLayout 1.0 (1.0) <0CFBA6BD-2A55-FF49-D2A6-53B238E2E931> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleLayout.framework/Versions/A/TitleLayout
      0x840d000 -  0x8422fff +CAFilterUtils ??? (???) <1815CB67-8E4C-4792-1422-FE381D7AA2DA> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/CAFilterUtils.framework/Versions/A/CAFilterUtils
      0x8437000 -  0x843dfff +com.adobe.IPLibrary.framework ??? (1.0) <D115D2C7-F6C9-3026-38D4-BC4524E00186> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/IPLibrary.framework/Versions/A/IPLibrary
      0x8446000 -  0x84f7ff3 +com.adobe.Descriptors.framework ??? (1.0) <0954EF40-080C-B04D-5EEC-32F4D8D075E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Descriptors.framework/Versions/A/Descriptors
      0x8572000 -  0x8577ff3 +com.adobe.HeadlightsWrapper.framework ??? (1.0) <6E564A2A-A4E4-67A8-413F-02A34A97E971> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HeadlightsWrapper.framework/Versions/A/HeadlightsWrapper
      0x8581000 -  0x85dcfff +com.adobe.dvametadata.framework dvametadata version 8.0.0 (8.0.0.0) <AD79F718-1249-D410-5A37-59E0699390A7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvametadata.framework/Versions/A/dvametadata
      0x865c000 -  0x86e7fff +com.adobe.dvametadataUI.framework dvametadataUI version 8.0.0 (8.0.0.0) <404F7BE8-8D03-35CD-2137-A00FD6CAC071> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/dvametadataUI.framework/Versions/A/dvametadataUI
      0x877b000 -  0x891cfcf +AdobeOwl ??? (???) <710491D7-AD6A-47C5-92A0-E90151B60C9A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeOwl.framework/Versions/A/AdobeOwl
      0x8982000 -  0x89f1ff7 +FileInfo ??? (???) <CED115CA-FEEE-9DEF-5759-72D9B9FEA892> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FileInfo.framework/Versions/A/FileInfo
      0x8a0e000 -  0x8a11ff8 +com.adobe.ape.shim adbeape version 3.1.65.7508 (3.1.65.7508) <FFDDAB7A-220F-7344-F12B-010CA0C41DAB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adbeape.framework/Versions/A/adbeape
      0x8a17000 -  0x8a4bfe7 +com.adobe.TitlerUI.framework ??? (1.0) <4CACDAAE-001C-F5A1-898F-2B14D98FFFE3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitlerUI.framework/Versions/A/TitlerUI
      0x8a9d000 -  0x8afefff +com.adobe.premiere.FontEngine 1.0 (1.0) <FB2D387A-0F0E-013F-92E6-2E5E6084F787> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FontEngine.framework/Versions/A/FontEngine
      0x8b89000 -  0x8bb7ffd +com.adobe.premiere.TitleLayer 1.0 (1.0) <3D047AD6-39F7-B440-0D39-D316D66B6ED4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleLayer.framework/Versions/A/TitleLayer
      0x8da2000 -  0x8ed1fef +com.adobe.premiere.TitleCG 1.0 (1.0) <E015D8AD-C3A1-C861-748F-DEF0763C5413> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleCG.framework/Versions/A/TitleCG
      0x8f8f000 -  0x9036fe0 +com.adobe.premiere.TitleCharacterFactory 1.0 (1.0) <34DB2D94-8F74-7613-16FF-01AE4431BBBF> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleCharacterFactory.framework/Versions/A/TitleCharacte rFactory
      0x9091000 -  0x909dffb +com.adobe.premiere.TitleImageManager 1.0 (1.0) <C3F9477B-3A3A-EDEF-E8E3-12B025877DE5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/TitleImageManager.framework/Versions/A/TitleImageManager
      0x90b4000 -  0x911effb +com.adobe.amtlib amtlib 3.5.0.20 (3.5.0.20) <0B8E82C2-3FAA-8E81-CEEA-BBFE29706530> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amtlib.framework/Versions/A/amtlib
      0x9135000 -  0x91befff +com.adobe.MediaCore.Frameworks.UI 1.0 (1.0) <0C5E995C-DA90-1F0E-B142-B5C3FC4CC906> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/MediaCoreUI.framework/Versions/A/MediaCoreUI
      0x9232000 -  0x9817ff7 +com.adobe.premiere-elements.HSL ??? (1.0) <36197EE0-650B-886D-4CE0-07AB5783AE58> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HSL.framework/Versions/A/HSL
      0x9d48000 -  0x9ed6ffb +com.adobe.DVDCreator.framework ??? (1.0) <E643C53A-E360-6E54-E103-DB58EC502932> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/DVDCreator.framework/Versions/A/DVDCreator
      0xa053000 -  0xa109fff +com.adobe.HandlerAudioMixer.framework ??? (1.0) <A7F0782D-C13D-24C3-21D2-D7BEFBBD0156> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerAudioMixer.framework/Versions/A/HandlerAudioMixer
      0xa1d2000 -  0xa1f6fff +com.adobe.HandlerAudioNarration.framework ??? (1.0) <AE6F7955-9C19-50AC-AD2B-EC2E02DEE615> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerAudioNarration.framework/Versions/A/HandlerAudioN arration
      0xa230000 -  0xa334fff +com.adobe.HandlerCapture.framework ??? (1.0) <ACA5E6D1-8430-F514-3365-0A4A65400480> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerCapture.framework/Versions/A/HandlerCapture
      0xa446000 -  0xa77cff7 +com.adobe.HandlerEffectControls.framework ??? (1.0) <9378443B-038F-3A05-12CF-7086DFEA6EA4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerEffectControls.framework/Versions/A/HandlerEffect Controls
      0xaa72000 -  0xaa80fff +com.adobe.HandlerEvents.framework ??? (1.0) <310A6DF6-0220-DF2C-EC3B-30814F5C9849> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerEvents.framework/Versions/A/HandlerEvents
      0xaa9b000 -  0xaaaeffb +com.adobe.HandlerGetProperties.framework ??? (1.0) <941E8984-CC74-F069-1188-3F05E8B38CB1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerGetProperties.framework/Versions/A/HandlerGetProp erties
      0xaad0000 -  0xaae8ff7 +com.adobe.HandlerHistory.framework ??? (1.0) <15E02F92-25A5-2A61-B915-FD9C3A1FA23D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerHistory.framework/Versions/A/HandlerHistory
      0xab13000 -  0xab48fff +com.adobe.HandlerInfo.framework ??? (1.0) <FD3317AB-F623-E1A0-C088-CEBBFC58ED41> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerInfo.framework/Versions/A/HandlerInfo
      0xab80000 -  0xad32ff7 +com.adobe.HandlerMonitor.framework ??? (1.0) <4FC26F38-0E0E-489E-59C0-6A7988091956> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerMonitor.framework/Versions/A/HandlerMonitor
      0xaede000 -  0xb1bdff6 +com.adobe.HandlerProject.framework ??? (1.0) <E22BE716-3E82-5CF0-C62B-9F797BDE9590> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerProject.framework/Versions/A/HandlerProject
      0xb4e3000 -  0xb743fff +com.adobe.HandlerTimeline.framework ??? (1.0) <1EE62095-F280-6C7A-49CF-94B565A29F1E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerTimeline.framework/Versions/A/HandlerTimeline
      0xb96b000 -  0xb9c4ff7 +com.adobe.HandlerDVDLayout.framework ??? (1.0) <495EEB8D-9C35-927D-DD02-10A9F65E2195> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerDVDLayout.framework/Versions/A/HandlerDVDLayout
      0xba34000 -  0xba84fff +com.adobe.HandlerMovieTheme.framework ??? (1.0) <792629C8-A4D8-5187-69A5-E64FC9AC1587> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerMovieTheme.framework/Versions/A/HandlerMovieTheme
      0xbadc000 -  0xbc78fff +com.adobe.HandlerOrganizer.framework ??? (1.0) <C792AD1B-3F95-AAB6-D471-7F371265999A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerOrganizer.framework/Versions/A/HandlerOrganizer
      0xbe05000 -  0xbe24fff +com.adobe.HandlerSharingCenter.framework ??? (1.0) <8F4249BC-6E58-615A-D907-C707394E9209> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/HandlerSharingCenter.framework/Versions/A/HandlerSharing Center
      0xbe52000 -  0xbec5ffb +ScriptLayer ??? (???) <FFB6FD43-10B0-627D-A717-E5698FF141A6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ScriptLayer.framework/Versions/A/ScriptLayer
      0xbf1e000 -  0xbf40ff3 +com.adobe.PreRegistration.framework ??? (1.0) <94C61A84-5F2A-B564-AD2C-3FD5236DFD7E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PreRegistration.framework/Versions/A/PreRegistration
      0xbf5d000 -  0xbfc3ffb +com.adobe.OLS.framework ??? (1.0) <3E252689-2567-E85F-6F2F-61CC069DBD8A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/OLS.framework/Versions/A/OLS
      0xc01b000 -  0xc031ff7 +com.adobe.ARA.framework ??? (1.0) <FBD9EBC7-2A02-3F99-BC04-626A5AA7AD62> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ARA.framework/Versions/A/ARA
      0xc04d000 -  0xc061fff +UpdateManager ??? (???) <116FF8CB-8C96-FA63-F3A2-217093ADB095> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UpdateManager.framework/Versions/A/UpdateManager
      0xc069000 -  0xc07cffb +com.adobe.About.framework ??? (1.0) <5EE9AEF7-00EA-1E42-4CEF-B3969229AF5C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/About.framework/Versions/A/About
      0xc09c000 -  0xc0a4ffe +com.adobe.RoyaltyActivation.framework ??? (1.0) <2A936511-3BAD-5996-BEBC-6D41B685AED2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/RoyaltyActivation.framework/Versions/A/RoyaltyActivation
      0xc0b3000 -  0xc110ff7 +com.adobe.MediaCore.Frameworks.Utilities.QT32Client 1.0 (1.0) <68E6C383-CD4C-E602-8D48-EB2112D05B96> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/QT32Client.framework/Versions/A/QT32Client
      0xc17e000 -  0xc1a4fff  libssl.0.9.7.dylib 0.9.7 (compatibility 0.9.7) <32607000-7573-6D51-ABC3-420B4A0D6629> /usr/lib/libssl.0.9.7.dylib
      0xc1b3000 -  0xc79dff7 +com.sonic.AS_Storage 4.26.7 (compatibility 1.0.0) <025EFB44-885B-5F07-70F2-3E382EE15EA4> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AS_Storage.framework/Versions/A/AS_Storage
      0xcb04000 -  0xdb06fff +com.sonic.AuthorScriptHDMV 7.8.5 (1) <66242DA4-6A78-B73D-DDF8-9696CCF5B66D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AuthorScriptHDMV.framework/Versions/A/AuthorScriptHDMV
      0xf3a2000 - 0x100e6fff +com.adobe.psl AdobePSL 12.0.0.7524 (12.0.0.7524) <0A73AB2A-D09F-2F18-E2D1-BC35A8EED2A5> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePSL.framework/Versions/A/AdobePSL
      0x10425000 - 0x1193efe3 +com.adobe.AuthorScriptAPI.framework ??? (1.0) <B3F15D32-7B34-2F22-0505-008B74C313F3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AuthorScriptAPI.framework/Versions/A/AuthorScriptAPI
      0x12b96000 - 0x12bbcff6 +AdobeAXE8SharedExpat ??? (???) <62F48740-7712-3F35-BB04-D3B117F7CA64> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeAXE8SharedExpat.framework/Versions/A/AdobeAXE8Share dExpat
      0x12bcd000 - 0x12d05fe7 +WRServices ??? (???) <87183F9D-17F4-6BDC-66A9-8FD34F320118> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/WRServices.framework/Versions/A/WRServices
      0x12d47000 - 0x12daffcb +libDataCDUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libDataCDUtf8.dylib
      0x12e3a000 - 0x12ebbfd3 +libhpCDEUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libhpCDEUtf8.dylib
      0x12f59000 - 0x12f8dfd7 +libhpTAPEUtf8.dylib 2.2.1 (compatibility 2.2.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libhpTAPEUtf8.dylib
      0x12fe6000 - 0x13024fcf +libVideoDVDUtf8.dylib 2.0.1 (compatibility 2.0.1) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/MacOS/libVideoDVDUtf8.dylib
      0x1307e000 - 0x130cdff7 +com.adobe.SCCommon.framework ??? (1.0) <043B40C7-A6DA-4CCF-66BC-905500658C59> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCCommon.framework/Versions/A/SCCommon
      0x1311c000 - 0x13168fff +com.adobe.SCFlashDVD.framework ??? (1.0) <3E1C2A14-176C-8E07-E71C-0001C50BED07> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCFlashDVD.framework/Versions/A/SCFlashDVD
      0x131c3000 - 0x131fefff +com.adobe.SCDisc.framework ??? (1.0) <81352B65-189D-01D4-195C-456D71CFE639> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCDisc.framework/Versions/A/SCDisc
      0x13240000 - 0x1326bff7 +com.adobe.SCPC.framework ??? (1.0) <2AD4939C-F8E3-DB0D-90B3-7AA8B8CF776C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCPC.framework/Versions/A/SCPC
      0x13297000 - 0x132c0ff3 +com.adobe.SCMobile.framework ??? (1.0) <89DD9494-47EA-EDCE-3858-B6F4EAC08E49> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCMobile.framework/Versions/A/SCMobile
      0x132ec000 - 0x1334dff7 +com.adobe.SCWeb.framework ??? (1.0) <A3956DA8-00FD-093E-1D4F-FC3BA4F6A127> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/SCWeb.framework/Versions/A/SCWeb
      0x133b0000 - 0x133defff +com.adobe.PresetManager.framework ??? (1.0) <BD52C2A7-3400-1821-EEA7-B122C904CAA1> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/PresetManager.framework/Versions/A/PresetManager
      0x134bf000 - 0x134c0ff7  com.apple.textencoding.unicode 2.3 (2.3) <78A61FD5-70EE-19EA-48D4-3481C640B70D> /System/Library/TextEncodings/Unicode Encodings.bundle/Contents/MacOS/Unicode Encodings
      0x134e1000 - 0x134e9fff +com.adobe.asneu.framework asneu version 1.7.0.1 (1.7.0.1) <80195B5C-2C67-D841-232C-74FCAB79D304> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/asneu.framework/Versions/A/asneu
      0x137c4000 - 0x137e8fe7  GLRendererFloat ??? (???) <0C6A1BCF-97F0-F7D6-C840-2991681BB67C> /System/Library/Frameworks/OpenGL.framework/Resources/GLRendererFloat.bundle/GLRendererFl oat
      0x14300000 - 0x14478fe7  GLEngine ??? (???) <0E1DF3E4-0EEE-9FD8-8F52-FFFCF0DF23A7> /System/Library/Frameworks/OpenGL.framework/Resources/GLEngine.bundle/GLEngine
      0x14552000 - 0x145b7fe7 +com.adobe.amt.services AMTServices 3.5.0.20 (BuildVersion: 3.5; BuildDate: Fri Jul 23 2010 21:49:00) (3.5.0.20) <9763F77A-D3BB-602B-E9B9-2C664CA32269> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/amtservices.framework/Versions/A/amtservices
      0x145d3000 - 0x14643feb +com.adobe.adobe_caps adobe_caps 3.5.4.0 (3.5.4.0) <36D53A2C-0DAB-34C6-48C7-49D2ECF52D0D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adobe_caps.framework/Versions/A/adobe_caps
      0x25d5a000 - 0x2615ffe7  libclh.dylib 3.1.1 C  (3.1.1) <04502F95-931E-0AAF-7296-4624C7F8DE8B> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/libclh.dylib
      0x28755000 - 0x2878effb +com.adobe.AAM.AdobeUpdaterNotificationFramework UpdaterNotifications 1.5.0.13 (1.5.0.13) <4F8229DD-D239-3773-1A53-51ECFA787463> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/UpdaterNotifications.framework/Versions/A/UpdaterNotific ations
      0x287b4000 - 0x287c6fff +com.adobe.pip ??? (5.0.0.2021) <5251926B-C2C0-282C-B3A9-94A9FEF0FCB8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePIP.framework/AdobePIP
      0x2b94a000 - 0x2b94eff3  com.apple.audio.AudioIPCPlugIn 1.1.6 (1.1.6) <F402CF88-D96C-42A0-3207-49759F496AE8> /System/Library/Extensions/AudioIPCDriver.kext/Contents/Resources/AudioIPCPlugIn.bundle/C ontents/MacOS/AudioIPCPlugIn
      0x2b966000 - 0x2b96cffb  com.apple.audio.AppleHDAHALPlugIn 1.9.9 (1.9.9f12) <82BFF5E9-2B0E-FE8B-8370-445DD94DA434> /System/Library/Extensions/AppleHDA.kext/Contents/PlugIns/AppleHDAHALPlugIn.bundle/Conten ts/MacOS/AppleHDAHALPlugIn
      0x2bc08000 - 0x2bc0efef +libtbbmalloc.dylib ??? (???) <12F9EB2C-C80A-6170-E088-7DBDE36511E3> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libtbbmalloc.dylib
      0x2c09d000 - 0x2c0abfe7  libSimplifiedChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <07211458-FD06-9FEF-3DF4-2E5F0304D4BC> /System/Library/CoreServices/Encodings/libSimplifiedChineseConverter.dylib
      0x2c928000 - 0x2c94cff1 +com.mainconcept.mc_dec_dv 8.5 (8.5.0.24499) <38CCE568-A850-87C4-E9F7-E58787D658D2> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_dv.framework/mc_dec_dv
      0x2c966000 - 0x2c987ff1 +com.mainconcept.mc_enc_dv 8.5 (8.5.0.24499) <AFB082F8-C0A3-AEF0-795A-602ED161B259> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_enc_dv.framework/mc_enc_dv
      0x2c99c000 - 0x2c9b6fff  com.apple.carbonframeworktemplate 1.0 (1.0) <32C18346-63D3-40A8-CE94-4FC8D0B42759> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/VXMLPresetReader.framework/vxmlpresetreader
      0x2cb39000 - 0x2cb5fff3 +com.adobe.MediaCore.ExporterQuickTimeHost 1.0 (1.0) <ED4D25C9-22EF-C39D-CF9C-229AC6A2A55A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ExporterQuickTimeHost.bundle/Contents/MacOS/Exporte rQuickTimeHost
      0x2cbc3000 - 0x2cbd9fff +com.adobe.MediaCore.Frameworks.QTParser 1.0 (1.0) <304D1A7D-199A-9D91-8F64-24D34118854B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/QTParser.framework/Versions/A/QTParser
      0x2cc18000 - 0x2cc33fff +com.adobe.MediaCore.ImporterPSA 1.0 (1.0) <D513F20E-C7D5-7587-E2B9-FEF7040307D6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterPSA.bundle/Contents/MacOS/ImporterPSA
      0x2cdfe000 - 0x2ce34fff +com.adobe.MediaCore.ImporterQuickTime 1.0 (1.0) <777F7F6D-ED06-AFB5-9463-79B84293920D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/ImporterQuickTime.bundle/Contents/MacOS/ImporterQui ckTime
      0x2ce68000 - 0x2cee2ff7 +com.adobe.MediaCore.PlayerMediaCore 1.0 (1.0) <51B4B720-6D18-5858-7F3E-24433AAD1A2C> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PlayerMediaCore.bundle/Contents/MacOS/PlayerMediaCo re
      0x2cf4e000 - 0x2cf68ff7 +image_runtime ??? (???) <8D487FD0-02CF-C361-67CB-4D613BE64322> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/image_runtime.framework/Versions/A/image_runtime
      0x2cf84000 - 0x2cf90ff7 +com.adobe.SceneDetectCAFilter.framework ??? (1.0) <589D349F-7048-8DDA-689A-124D0D6E3779> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/SceneDetectCAFilter.sd/SceneDetectCAFilter
      0x2d070000 - 0x2d0a1ff2  com.apple.AVCVideoServices 1.0 (42) <8E8CFE8F-9877-45EB-8E6A-A47376F209FD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AVCVideoServices.framework/Versions/A/AVCVideoServices
      0x2d0ce000 - 0x2d0ddfe8 +com.adobe.MediaCore.PremiereFiltersMetaPlugin 1.0 (1.0) <32340239-6068-936B-6D9B-315772F73D51> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PremiereFiltersMetaPlugin.prmp/Contents/MacOS/Premi ereFiltersMetaPlugin
      0x2d200000 - 0x2d279fe7 +com.adobe.MediaCore.Frameworks.Display ??? (1.0) <F71E47B3-C7D1-4C41-CED4-6F54439EF979> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/Display.framework/Versions/A/Display
      0x2d32a000 - 0x2d3deffa +com.adobe.PremiereElements.PhotoshopAdapter 1.0 (1.0) <D4D185C2-85C4-89BD-B10A-376EACF31538> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/PSA/Photoshop Adapter.plugin/Contents/MacOS/Photoshop Adapter
      0x2d509000 - 0x2d52bff7 +libtbb.dylib ??? (???) <AAA2AFA2-789A-41B8-D03D-C03861305060> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libtbb.dylib
      0x2d57b000 - 0x2d5d8fef +aif_core ??? (???) <AF9EC89D-F9B4-E6A6-B55D-D61CE910B3CD> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/aif_core.framework/Versions/A/aif_core
      0x2d5f5000 - 0x2d610fff +com.adobe.MediaCore.AudioVideoIO 1.0 (1.0) <06DFAEC5-EB7B-0707-59DD-AE6DC73F9DB7> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AudioVideoIO.framework/Versions/A/AudioVideoIO
      0x2d633000 - 0x2d679ff7  com.apple.glut 3.4.4 (GLUT-3.4.4) <DF15FD36-E1F5-D745-1BF6-DD3AEA2897E4> /System/Library/Frameworks/GLUT.framework/Versions/A/GLUT
      0x2d6e9000 - 0x2d703ffb +com.adobe.MediaCore.RecorderHDVMac 1.0 (1.0) <A0B52854-01A3-F2BC-40BF-2CE8341F7FC6> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderHDVMac.bundle/Contents/MacOS/RecorderHDVMac
      0x2d721000 - 0x2d754fff +com.adobe.MediaCore.RecorderQTKit 1.0 (1.0) <60CF5F61-EB52-12B9-2A62-4D6104B5F5EB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderQTKit.bundle/Contents/MacOS/RecorderQTKit
      0x2d77e000 - 0x2d791fe4 +com.adobe.MediaCore.TransitionsMetaPlugin 1.0 (1.0) <F483C239-B9FF-D716-13C4-E61183FE464A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/TransitionsMetaPlugin.prmp/Contents/MacOS/Transitio nsMetaPlugin
      0x2db28000 - 0x2db45feb +AudioCAFilter ??? (???) <B1686B6C-01DF-4529-9D6B-E46A8B33ED2A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/AudioCAFilter.framework/AudioCAFilter
      0x2db57000 - 0x2db67fff +BlurCAFilter ??? (???) <F891B2EA-5208-8F6D-F144-78563BBBD59A> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/BlurCAFilter.framework/BlurCAFilter
      0x2de42000 - 0x2df08fef +com.adobe.MediaCore.IPPMPEGDecoder 1.0 (1.0) <ACB0B3C1-3B22-D9D7-8F9A-8E20313651ED> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/IPPMPEGDecoder.framework/Versions/A/IPPMPEGDecoder
      0x2e174000 - 0x2e1a9fe3 +com.adobe.MediaCore.RecorderWebCamQTKit 1.0 (1.0) <287BB18E-5C7E-C902-4297-EFCF4EB771BC> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Plug-ins/Common/RecorderWebCamQTKit.bundle/Contents/MacOS/RecorderW ebCamQTKit
      0x2e1d5000 - 0x2e1e3fff +BrightnessContrastCAFilter ??? (???) <F4A5859D-E651-4BC2-6D46-5AF0FCE83276> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/BrightnessContrastCAFilter.framework/BrightnessContrastCAFilter
      0x3fce1000 - 0x3ff12ffb +aif_ogl ??? (???) <A5F168B4-8DCC-37BF-0DA3-D51E0D287360> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/aif_ogl.framework/Versions/A/aif_ogl
      0x40000000 - 0x400d1fe7 +AdobeJP2K ??? (???) <2ABF10A7-540A-06C8-21FA-186263931DF9> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeJP2K.framework/Versions/A/AdobeJP2K
      0x40533000 - 0x40d84fe7 +com.adobe.CameraRaw 6.1 (250) (6.1.0f250) <3A299A4B-A870-ED39-01E7-BC3B8CF56198> /Library/Application Support/Adobe/Plug-Ins/Elements 9/File Formats/Camera Raw.plugin/Contents/MacOS/Camera Raw
      0x41105000 - 0x41131ff7 +FaceDetectionCAFilter ??? (???) <A232DEA3-AD5D-50AF-750F-DFEB84A8BB93> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/FaceDetectionCAFilter.framework/FaceDetectionCAFilter
      0x41161000 - 0x41177fff +MotionCAFilter ??? (???) <6BD6EE6A-1580-9A9A-2579-D47877ACA255> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/MotionCAFilter.framework/MotionCAFilter
      0x4118b000 - 0x4119eff7 +ShakeCAFilter ??? (???) <8B112F2F-9FA8-FEC1-DF66-EE530520C976> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/ShakeCAFilter.framework/ShakeCAFilter
      0x41300000 - 0x413a5ffb +FaceDetector ??? (???) <1275F007-B8A7-CA23-8F89-570E182FCBA8> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/FaceDetector.framework/Versions/A/FaceDetector
      0x414c4000 - 0x41511fff +ObjTrackCAFilter ??? (???) <2981BC3B-1014-6B92-38AF-37E50435D226> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/CAFilters/ObjTrackCAFilter.framework/ObjTrackCAFilter
      0x4160e000 - 0x41c42feb +com.adobe.PDFL 9.9.0 (9.9.0.7414) <49D6D58A-1EBB-424A-4CB0-8F9691E0991D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobePDFL.framework/AdobePDFL
      0x41d6e000 - 0x41dffff7 +libicucnv.dylib.36.0 36.0.0 (compatibility 36.0.0) <581475CC-C039-1B42-49BA-71811D8B4E15> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ICUConverter.framework/Versions/3.6/libicucnv.dylib.36.0
      0x41e1e000 - 0x427cefff +libicudata.dylib.36.0 36.0.0 (compatibility 36.0.0) <02108DEA-3DD2-14BE-DAEB-BE522B619C1D> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ICUData.framework/Versions/3.6/libicudata.dylib.36.0
      0x428b3000 - 0x428c5ff7  libTraditionalChineseConverter.dylib 49.0.0 (compatibility 1.0.0) <8D606435-1A3C-FE0B-824A-1386809FFFF5> /System/Library/CoreServices/Encodings/libTraditionalChineseConverter.dylib
      0x43204000 - 0x432f0ffb +com.yourcompany.ems 1.0 (1) <2BD7FA47-A217-48B7-4F02-20E86E02A40E> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ems.framework/ems
      0x43381000 - 0x433aeff3 +libcurl ??? (???) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/libcurl.framework/libcurl
      0x433ba000 - 0x433e3feb +com.adobe.ape adbeapecore version 3.1.70.10055 (3.1.70.10055) <F3239526-C171-AD3C-835E-FC9998EEFB28> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/adbeapecore
      0x433f3000 - 0x43535fe7 +com.adobe.ols.library 4.0 (4.0) <4BC1EDD1-F363-2845-36E1-36692B624FCB> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/AdobeOLS.framework/AdobeOLS
      0x45ac8000 - 0x45ae3ffb +com.adobe.adobe_oobe_launcher Adobe OOBE Launcher 1.5.0.20 (BuildVersion: 1.5; BuildDate: Fri Jul 23 2010 21:49:00) (1.5.0.20) <A93685BA-E1C2-2277-AEBA-99C3722C8DDE> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/adobe_oobe_launcher.framework/Versions/A/adobe_oobe_laun cher
      0x45af2000 - 0x4694cfeb +com.adobe.adobeswfl ??? (2.0.0.10053) <D591B8C9-2C4A-CF9E-0FCE-B80A844270E0> /Library/Application Support/Adobe/APE/3.1/adbeapecore.framework/Resources/AdobeSWFL.bundle/Contents/MacOS/Ado beSWFL
      0x8f0c7000 - 0x8f811ff7  com.apple.GeForceGLDriver 1.6.26 (6.2.6) <90BBC89A-6A56-C4B7-F848-432908CDE14D> /System/Library/Extensions/GeForceGLDriver.bundle/Contents/MacOS/GeForceGLDriver
      0x8fe00000 - 0x8fe4162b  dyld 132.1 (???) <A4F6ADCC-6448-37B4-ED6C-ABB2CD06F448> /usr/lib/dyld
      0x9003b000 - 0x9006effb  libTrueTypeScaler.dylib ??? (???) <574C2C51-65EC-7D2A-086D-C9312287DE22> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libTrueTypeScaler.dylib
      0x9006f000 - 0x90119fe7  com.apple.CFNetwork 454.11.12 (454.11.12) <BE832CCE-B692-F55F-F5F8-3973649AFEA1> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CFNetwork.framewo rk/Versions/A/CFNetwork
      0x9011a000 - 0x902c1ff7  libSystem.B.dylib 125.2.10 (compatibility 1.0.0) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
      0x90321000 - 0x90325ff7  IOSurface ??? (???) <D849E1A5-6B0C-2A05-2765-850EC39BA2FF> /System/Library/Frameworks/IOSurface.framework/Versions/A/IOSurface
      0x90326000 - 0x9061ffef  com.apple.QuickTime 7.6.6 (1756.15) <C2567783-4EAC-6803-522B-D701B95C4DAE> /System/Library/Frameworks/QuickTime.framework/Versions/A/QuickTime
      0x90620000 - 0x90647ff7  com.apple.quartzfilters 1.6.0 (1.6.0) <879A3B93-87A6-88FE-305D-DF1EAED04756> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzFilters.framework /Versions/A/QuartzFilters
      0x906a4000 - 0x90708ffb  com.apple.htmlrendering 72 (1.1.4) <4D451A35-FAB6-1288-71F6-F24A4B6E2371> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HTMLRendering.framework /Versions/A/HTMLRendering
      0x90709000 - 0x90b40ff3  com.apple.RawCamera.bundle 3.6.4 (561) <DBA5D7C1-CD82-CE7F-5AE5-A0E4E128236F> /System/Library/CoreServices/RawCamera.bundle/Contents/MacOS/RawCamera
      0x90b41000 - 0x90d6cff3  com.apple.QuartzComposer 4.2 ({156.28}) <08AF01DC-110D-9443-3916-699DBDED0149> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuartzComposer.framewor k/Versions/A/QuartzComposer
      0x90f63000 - 0x90f67ff7  libGIF.dylib ??? (???) <447BC6E8-4C56-3D5D-983B-6BEA0D26F319> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libGIF.dylib
      0x90f68000 - 0x910a4ff7  com.apple.audio.toolbox.AudioToolbox 1.6.6 (1.6.6) <781018FB-474B-E09C-D419-5BFF80590A10> /System/Library/Frameworks/AudioToolbox.framework/Versions/A/AudioToolbox
      0x910a5000 - 0x910d5ff7  com.apple.MeshKit 1.1 (49.2) <ECFBD794-5D36-4405-6184-5568BFF29BF3> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/MeshKit
      0x91101000 - 0x91127ffb  com.apple.DictionaryServices 1.1.2 (1.1.2) <43E1D565-6E01-3681-F2E5-72AE4C3A097A> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/DictionaryService s.framework/Versions/A/DictionaryServices
      0x91128000 - 0x911c5fe3  com.apple.LaunchServices 362.2 (362.2) <F3952CAB-322F-A12F-57AF-8B91B1D76DDE> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/LaunchServices.fr amework/Versions/A/LaunchServices
      0x91586000 - 0x9158dff3  com.apple.print.framework.Print 6.1 (237.1) <F5AAE53D-5530-9004-A9E3-2C1690C5328E> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Print.framework/Version s/A/Print
      0x915d4000 - 0x9169ffef  com.apple.CoreServices.OSServices 359 (359) <EC340F74-8192-C9DD-40B3-AE4E519A38D7> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/OSServices.framew ork/Versions/A/OSServices
      0x916a0000 - 0x916bfff7  com.apple.CoreVideo 1.6.2 (45.6) <EB53CAA4-5EE2-C356-A954-5775F7DDD493> /System/Library/Frameworks/CoreVideo.framework/Versions/A/CoreVideo
      0x916c0000 - 0x916c0ff7  com.apple.Accelerate.vecLib 3.6 (vecLib 3.6) <1DEC639C-173D-F808-DE0D-4070CC6F5BC7> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/vecLib
      0x916c1000 - 0x916cdff7  libkxld.dylib ??? (???) <F0E915AD-6B32-0D5E-D24B-B188447FDD23> /usr/lib/system/libkxld.dylib
      0x916f4000 - 0x91732ff7  com.apple.QuickLookFramework 2.3 (327.6) <66955C29-0C99-D02C-DB18-4952AFB4E886> /System/Library/Frameworks/QuickLook.framework/Versions/A/QuickLook
      0x91733000 - 0x9173bff7  com.apple.DisplayServicesFW 2.3.0 (283) <48D94761-7340-D029-99E3-9BE0262FAF22> /System/Library/PrivateFrameworks/DisplayServices.framework/Versions/A/DisplayServices
      0x91839000 - 0x91919fe7  com.apple.vImage 4.1 (4.1) <D029C515-08E1-93A6-3705-DD062A3A672C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vImage.framework/Ve rsions/A/vImage
      0x9191a000 - 0x91d4fff7  libLAPACK.dylib 219.0.0 (compatibility 1.0.0) <5E2D2283-57DE-9A49-1DB0-CD027FEFA6C2> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libLAPACK.dylib
      0x91d97000 - 0x91ffcfeb  com.apple.security 6.1.1 (37594) <251BA05D-6F3D-F687-77C2-15E52539F308> /System/Library/Frameworks/Security.framework/Versions/A/Security
      0x9210b000 - 0x921c2feb  libFontParser.dylib ??? (???) <DDBBB503-5289-2E2B-AD35-F3BA00D00D5F> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontParser.dylib
      0x921c3000 - 0x921dbff7  com.apple.CFOpenDirectory 10.6 (10.6) <F9AFC571-3539-6B46-ABF9-46DA2B608819> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/Frameworks/CFOpenDirectory. framework/Versions/A/CFOpenDirectory
      0x921dc000 - 0x921dcff7  com.apple.Cocoa 6.6 (???) <EA27B428-5904-B00B-397A-185588698BCC> /System/Library/Frameworks/Cocoa.framework/Versions/A/Cocoa
      0x921dd000 - 0x921e7fe7  com.apple.audio.SoundManager 3.9.3 (3.9.3) <5F494955-7290-2D91-DA94-44B590191771> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CarbonSound.framework/V ersions/A/CarbonSound
      0x9221f000 - 0x92240fe7  com.apple.opencl 12.3.6 (12.3.6) <B4104B80-1CB3-191C-AFD3-697843C6BCFF> /System/Library/Frameworks/OpenCL.framework/Versions/A/OpenCL
      0x92259000 - 0x9225eff7  com.apple.OpenDirectory 10.6 (10.6) <C1B46982-7D3B-3CC4-3BC2-3E4B595F0231> /System/Library/Frameworks/OpenDirectory.framework/Versions/A/OpenDirectory
      0x9225f000 - 0x92363fe7  libcrypto.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <BDEFA030-5E75-7C47-2904-85AB16937F45> /usr/lib/libcrypto.0.9.8.dylib
      0x92364000 - 0x923bcfe7  com.apple.datadetectorscore 2.0 (80.7) <A40AA74A-9D13-2A6C-5440-B50905923251> /System/Library/PrivateFrameworks/DataDetectorsCore.framework/Versions/A/DataDetectorsCor e
      0x923bd000 - 0x923f4fe7  libssl.0.9.8.dylib 0.9.8 (compatibility 0.9.8) <7DCB5938-3140-E71A-92BD-8C242F30C8F5> /usr/lib/libssl.0.9.8.dylib
      0x923f5000 - 0x92402ff7  com.apple.NetFS 3.2.2 (3.2.2) <DDC9C397-C35F-8D7A-BB24-3D1B42FA5FAB> /System/Library/Frameworks/NetFS.framework/Versions/A/NetFS
      0x92403000 - 0x92454ff7  com.apple.HIServices 1.8.2 (???) <F6EAC2D1-902A-9374-FC4B-43B50E054416> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/HIServices .framework/Versions/A/HIServices
      0x924a3000 - 0x9265dfeb  com.apple.ImageIO.framework 3.0.4 (3.0.4) <C96F11A7-2569-3037-C4C3-0342708FA3CB> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/ImageIO
      0x9265e000 - 0x92b17ffb  com.apple.VideoToolbox 0.484.20 (484.20) <E7B9F015-2569-43D7-5268-375ED937ECA5> /System/Library/PrivateFrameworks/VideoToolbox.framework/Versions/A/VideoToolbox
      0x92b26000 - 0x92b7cff7  com.apple.MeshKitRuntime 1.1 (49.2) <F1EAE9EC-2DA3-BAFD-0A8C-6A3FFC96D728> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitRuntime. framework/Versions/A/MeshKitRuntime
      0x92ccf000 - 0x92d49fff  com.apple.audio.CoreAudio 3.2.6 (3.2.6) <F7C9B01D-45AD-948B-2D26-9736524C1A33> /System/Library/Frameworks/CoreAudio.framework/Versions/A/CoreAudio
      0x92d4a000 - 0x92d8cff7  libvDSP.dylib 268.0.1 (compatibility 1.0.0) <3F0ED200-741B-4E27-B89F-634B131F5E9E> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvDSP.dylib
      0x92d8d000 - 0x92d93fe7  com.apple.CommerceCore 1.0 (9) <928FCA4F-1366-AE18-CF67-87C79F5DAC21> /System/Library/PrivateFrameworks/CommerceKit.framework/Versions/A/Frameworks/CommerceCor e.framework/Versions/A/CommerceCore
      0x92d94000 - 0x92de1feb  com.apple.DirectoryService.PasswordServerFramework 6.1 (6.1) <136BFA48-D456-B677-3B5D-40A6946C3A09> /System/Library/PrivateFrameworks/PasswordServer.framework/Versions/A/PasswordServer
      0x92de2000 - 0x92ebcffb  com.apple.DesktopServices 1.5.10 (1.5.10) <2BA08DD4-35A2-A0FF-ADEA-B381F0CEEB81> /System/Library/PrivateFrameworks/DesktopServicesPriv.framework/Versions/A/DesktopService sPriv
      0x92ebd000 - 0x92ebdff7  com.apple.ApplicationServices 38 (38) <8012B504-3D83-BFBB-DA65-065E061CFE03> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/ApplicationServices
      0x92ebe000 - 0x931deff3  com.apple.CoreServices.CarbonCore 861.34 (861.34) <3DA9098F-B71B-4BDE-5DE5-4B76C49158EB> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/CarbonCore.framew ork/Versions/A/CarbonCore
      0x931df000 - 0x931dfff7  liblangid.dylib ??? (???) <B99607FC-5646-32C8-2C16-AFB5EA9097C2> /usr/lib/liblangid.dylib
      0x931e0000 - 0x9354bff7  com.apple.QuartzCore 1.6.3 (227.36) <8E927524-EB0A-D5BA-C2E4-FA26FE4C428A> /System/Library/Frameworks/QuartzCore.framework/Versions/A/QuartzCore
      0x9354c000 - 0x9358cff3  com.apple.securityinterface 4.0.1 (40418) <26D84A83-F5B9-93CF-71BB-0712698181EE> /System/Library/Frameworks/SecurityInterface.framework/Versions/A/SecurityInterface
      0x93594000 - 0x936c0ffb  com.apple.MediaToolbox 0.484.20 (484.20) <D67788A2-B772-C5DB-B12B-173B2F8EE40B> /System/Library/PrivateFrameworks/MediaToolbox.framework/Versions/A/MediaToolbox
      0x936c9000 - 0x93844fe7  com.apple.CoreFoundation 6.6.4 (550.42) <C78D5079-663E-9734-7AFA-6CE79A0539F1> /System/Library/Frameworks/CoreFoundation.framework/Versions/A/CoreFoundation
      0x93845000 - 0x93886ff7  libRIP.A.dylib 545.0.0 (compatibility 64.0.0) <95079B56-0B7B-F114-5C43-5220DBE0FBB1> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libRIP.A.dylib
      0x93902000 - 0x93903ff7  com.apple.audio.units.AudioUnit 1.6.6 (1.6.6) <253E9552-5CEA-0D5A-1EDA-3B8F669B79EA> /System/Library/Frameworks/AudioUnit.framework/Versions/A/AudioUnit
      0x93904000 - 0x93b02ff3  com.apple.JavaScriptCore 6533.20 (6533.20.20) <011E271D-4CA4-FFB0-2EDD-13C31C239899> /System/Library/Frameworks/JavaScriptCore.framework/Versions/A/JavaScriptCore
      0x93b03000 - 0x93b0aff7  com.apple.agl 3.0.12 (AGL-3.0.12) <6877F0D8-0DCF-CB98-5304-913667FF50FA> /System/Library/Frameworks/AGL.framework/Versions/A/AGL
      0x93b0b000 - 0x93b1ffe7  libbsm.0.dylib ??? (???) <14CB053A-7C47-96DA-E415-0906BA1B78C9> /usr/lib/libbsm.0.dylib
      0x93b21000 - 0x93b90ff7  libvMisc.dylib 268.0.1 (compatibility 1.0.0) <2FC2178F-FEF9-6E3F-3289-A6307B1A154C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libvMisc.dylib
      0x93b91000 - 0x93b94ffb  com.apple.help 1.3.1 (41) <67F1F424-3983-7A2A-EC21-867BE838E90B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Help.framework/Versions /A/Help
      0x93c52000 - 0x93c8fff7  com.apple.CoreMedia 0.484.20 (484.20) <105DDB24-E45F-5473-99E1-B09FDEAE4500> /System/Library/PrivateFrameworks/CoreMedia.framework/Versions/A/CoreMedia
      0x93c90000 - 0x93d91fe7  libxml2.2.dylib 10.3.0 (compatibility 10.0.0) <C75F921C-F027-6372-A0A1-EDB8A6234331> /usr/lib/libxml2.2.dylib
      0x93e0b000 - 0x93f17ff7  libGLProgrammability.dylib ??? (???) <2D172B4E-432F-D18E-EA99-3BD56DBE7649> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLProgrammability.dyl ib
      0x93f18000 - 0x93f1cff7  libGFXShared.dylib ??? (???) <4F2199F0-320F-0B59-0380-D3131D644CBA> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGFXShared.dylib
      0x93f5e000 - 0x93f61fe7  libmathCommon.A.dylib 315.0.0 (compatibility 1.0.0) <1622A54F-1A98-2CBE-B6A4-2122981A500E> /usr/lib/system/libmathCommon.A.dylib
      0x93f62000 - 0x9400ffe7  libobjc.A.dylib 227.0.0 (compatibility 1.0.0) <DF8E4CFA-3719-3415-0BF1-E8C5E561C3B1> /usr/lib/libobjc.A.dylib
      0x94010000 - 0x94024ffb  com.apple.speech.synthesis.framework 3.10.35 (3.10.35) <57DD5458-4F24-DA7D-0927-C3321A65D743> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/SpeechSynt hesis.framework/Versions/A/SpeechSynthesis
      0x94025000 - 0x94168fef  com.apple.QTKit 7.6.6 (1756.15) <32C49374-14BC-53E7-FBFF-E11B42A41F56> /System/Library/Frameworks/QTKit.framework/Versions/A/QTKit
      0x94169000 - 0x941b0ffb  com.apple.CoreMediaIOServices 134.0 (1160) <4CD78557-3CDA-A4B5-33CB-BBB876B4463D> /System/Library/PrivateFrameworks/CoreMediaIOServices.framework/Versions/A/CoreMediaIOSer vices
      0x94202000 - 0x9426cfe7  libstdc++.6.dylib 7.9.0 (compatibility 7.0.0) <411D87F4-B7E1-44EB-F201-F8B4F9227213> /usr/lib/libstdc++.6.dylib
      0x9426d000 - 0x94270ff7  libCGXType.A.dylib 545.0.0 (compatibility 64.0.0) <B84D7376-EE9C-2B7F-04FA-D622E2C10CA6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCGXType.A.dylib
      0x94381000 - 0x943b9ff7  com.apple.LDAPFramework 2.0 (120.1) <001A70A8-3984-8E19-77A8-758893CC128C> /System/Library/Frameworks/LDAP.framework/Versions/A/LDAP
      0x943ba000 - 0x943fefe7  com.apple.Metadata 10.6.3 (507.15) <A23633F1-E913-66C2-A073-E2B174C09B18> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/Metadata.framewor k/Versions/A/Metadata
      0x94562000 - 0x945f4fe7  com.apple.print.framework.PrintCore 6.3 (312.7) <7410D1B2-655D-68DA-D4B9-2C65747B6817> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/PrintCore. framework/Versions/A/PrintCore
      0x945f5000 - 0x945f5ff7  com.apple.Carbon 150 (152) <9252D5F2-462D-2C15-80F3-109644D6F704> /System/Library/Frameworks/Carbon.framework/Versions/A/Carbon
      0x945f6000 - 0x9461eff7  libxslt.1.dylib 3.24.0 (compatibility 3.0.0) <769EF4B2-C1AD-73D5-AAAD-1564DAEA77AF> /usr/lib/libxslt.1.dylib
      0x9462f000 - 0x94a45ff7  libBLAS.dylib 219.0.0 (compatibility 1.0.0) <C4FB303A-DB4D-F9E8-181C-129585E59603> /System/Library/Frameworks/Accelerate.framework/Versions/A/Frameworks/vecLib.framework/Ve rsions/A/libBLAS.dylib
      0x94a46000 - 0x94a51ff7  libCSync.A.dylib 545.0.0 (compatibility 64.0.0) <4560936D-7730-5DD2-BFD7-95270DDC210A> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/Resources/libCSync.A.dylib
      0x94a7c000 - 0x94a8cff7  libsasl2.2.dylib 3.15.0 (compatibility 3.0.0) <C8744EA3-0AB7-CD03-E639-C4F2B910BE5D> /usr/lib/libsasl2.2.dylib
      0x94a8d000 - 0x94aa8ff7  libPng.dylib ??? (???) <65E824F7-523A-CC34-ABDD-2A3B12DE1CA9> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libPng.dylib
      0x94aa9000 - 0x94ab4ff7  libGL.dylib ??? (???) <4425B9AA-B494-A336-EABB-6BBC9FF4EC4F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGL.dylib
      0x94cbd000 - 0x954ac557  com.apple.CoreGraphics 1.545.0 (???) <8A4CB0D9-1001-0F62-4DA4-B8AB3B45E226> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreGraphi cs.framework/Versions/A/CoreGraphics
      0x954ad000 - 0x954aeff7  com.apple.MonitorPanelFramework 1.3.0 (1.3.0) <0EC4EEFF-477E-908E-6F21-ED2C973846A4> /System/Library/PrivateFrameworks/MonitorPanel.framework/Versions/A/MonitorPanel
      0x95622000 - 0x95665ff7  com.apple.NavigationServices 3.5.4 (182) <753B8906-06C0-3AE0-3D6A-8FF5AC18ED12> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/NavigationServices.fram ework/Versions/A/NavigationServices
      0x95666000 - 0x95676ff7  com.apple.DSObjCWrappers.Framework 10.6 (134) <81A0B409-3906-A98F-CA9B-A49E75007495> /System/Library/PrivateFrameworks/DSObjCWrappers.framework/Versions/A/DSObjCWrappers
      0x95677000 - 0x956e5ff7  com.apple.QuickLookUIFramework 2.3 (327.6) <74706A08-5399-24FE-00B2-4A702A6B83C1> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/QuickLookUI.framework/V ersions/A/QuickLookUI
      0x957be000 - 0x95859ff7  com.apple.ApplicationServices.ATS 4.4 (???) <FD63F92B-8DDE-4DBA-A7A5-0294E3607083> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/ATS
      0x9585a000 - 0x9589eff3  com.apple.coreui 2 (114) <29F8F1A4-1C96-6A0F-4CC2-9B85CF83209F> /System/Library/PrivateFrameworks/CoreUI.framework/Versions/A/CoreUI
      0x9589f000 - 0x9591afff  com.apple.AppleVAFramework 4.10.23 (4.10.23) <57B7C626-F344-AB15-8556-00425FA765DE> /System/Library/PrivateFrameworks/AppleVA.framework/Versions/A/AppleVA
      0x95a34000 - 0x95a56fef  com.apple.DirectoryService.Framework 3.6 (621.11) <CA979EAC-9537-43B6-CD69-C144ACB75E09> /System/Library/Frameworks/DirectoryService.framework/Versions/A/DirectoryService
      0x95a57000 - 0x95ad9ffb  SecurityFoundation ??? (???) <3670AE8B-06DA-C447-EB14-79423DB9C474> /System/Library/Frameworks/SecurityFoundation.framework/Versions/A/SecurityFoundation
      0x95ada000 - 0x95ae8ff7  com.apple.opengl 1.6.12 (1.6.12) <81AEF74E-E33A-B021-9CDB-6199104105FF> /System/Library/Frameworks/OpenGL.framework/Versions/A/OpenGL
      0x95ae9000 - 0x95b2cff7  libGLU.dylib ??? (???) <2C7B2727-26F6-F29D-9D15-33044E87359F> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLU.dylib
      0x95b2d000 - 0x95c2ffef  com.apple.MeshKitIO 1.1 (49.2) <34322CDD-E67E-318A-F03A-A3DD05201046> /System/Library/PrivateFrameworks/MeshKit.framework/Versions/A/Frameworks/MeshKitIO.frame work/Versions/A/MeshKitIO
      0x95c30000 - 0x95cecfff  com.apple.ColorSync 4.6.6 (4.6.6) <D00B95AE-2379-CB8E-B18C-FF5B66741C23> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ColorSync. framework/Versions/A/ColorSync
      0x95ced000 - 0x95cefff7  libRadiance.dylib ??? (???) <B83179D4-E41C-D2BA-1E4C-A64CB45C15E6> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libRadiance.dylib
      0x95cf0000 - 0x95cf0ff7  com.apple.CoreServices 44 (44) <51CFA89A-33DB-90ED-26A8-67D461718A4A> /System/Library/Frameworks/CoreServices.framework/Versions/A/CoreServices
      0x95cf1000 - 0x95d52fe7  com.apple.CoreText 3.151.8 (???) <6F5D6C49-4693-B9B7-6612-832E8F155747> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/CoreText.f ramework/Versions/A/CoreText
      0x95d53000 - 0x95d55ff7  com.apple.securityhi 4.0 (36638) <38D36D4D-C798-6ACE-5FA8-5C001993AD6B> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SecurityHI.framework/Ve rsions/A/SecurityHI
      0x95d56000 - 0x95d89ff7  com.apple.AE 496.4 (496.4) <7F34EC47-8429-3077-8158-54F5EA908C66> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/AE.framework/Vers ions/A/AE
      0x95daa000 - 0x95dabff7  com.apple.TrustEvaluationAgent 1.1 (1) <FEB55E8C-38A4-CFE9-A737-945F39761B4C> /System/Library/PrivateFrameworks/TrustEvaluationAgent.framework/Versions/A/TrustEvaluati onAgent
      0x95dac000 - 0x95dd0ff7  libJPEG.dylib ??? (???) <A50127EB-C202-0436-E62D-41E2E893E436> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libJPEG.dylib
      0x95dd1000 - 0x966b1ff7  com.apple.AppKit 6.6.7 (1038.35) <ABC7783C-E4D5-B848-BED6-99451D94D120> /System/Library/Frameworks/AppKit.framework/Versions/C/AppKit
      0x966b2000 - 0x96702ff7  com.apple.framework.familycontrols 2.0.2 (2020) <C96C8A99-A40C-8B9C-1FBA-A0F46AC92F17> /System/Library/PrivateFrameworks/FamilyControls.framework/Versions/A/FamilyControls
      0x96703000 - 0x9674cfe7  libTIFF.dylib ??? (???) <5CE284EC-F637-EDBB-FDB3-61E86407CBB8> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ImageIO.fr amework/Versions/A/Resources/libTIFF.dylib
      0x96963000 - 0x9699bfe7  libcurl.4.dylib 6.1.0 (compatibility 6.0.0) <242954AD-3BE1-29E8-E2E0-08063201F105> /usr/lib/libcurl.4.dylib
      0x9699f000 - 0x9699fff7  com.apple.quartzframework 1.5 (1.5) <CEB78F00-C5B2-3B3F-BF70-DD6D578719C0> /System/Library/Frameworks/Quartz.framework/Versions/A/Quartz
      0x969f1000 - 0x96bd3fff  com.apple.imageKit 2.0.3 (1.0) <B4DB05F7-01C5-35EE-7AB9-41BD9D63F075> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/ImageKit.framework/Vers ions/A/ImageKit
      0x96bd4000 - 0x96bdeffb  com.apple.speech.recognition.framework 3.11.1 (3.11.1) <EC0E69C8-A121-70E8-43CF-E6FC4C7779EC> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/SpeechRecognition.frame work/Versions/A/SpeechRecognition
      0x96da5000 - 0x96dc5fe7  libresolv.9.dylib 41.0.0 (compatibility 1.0.0) <751955F3-21FB-A03A-4E92-1F3D4EFB8C5B> /usr/lib/libresolv.9.dylib
      0x96dc6000 - 0x96dccfff  com.apple.CommonPanels 1.2.4 (91) <2438AF5D-067B-B9FD-1248-2C9987F360BA> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/CommonPanels.framework/ Versions/A/CommonPanels
      0x96e78000 - 0x96ffafe7  libicucore.A.dylib 40.0.0 (compatibility 1.0.0) <D375C1CF-C88D-C5F6-3C49-CD429023FBAC> /usr/lib/libicucore.A.dylib
      0x96ffb000 - 0x97058ff7  com.apple.framework.IOKit 2.0 (???) <A769737F-E0D6-FB06-29B4-915CF4F43420> /System/Library/Frameworks/IOKit.framework/Versions/A/IOKit
      0x97059000 - 0x97094feb  libFontRegistry.dylib ??? (???) <4FB144ED-8AF9-27CF-B315-DCE5575D5231> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/ATS.framew ork/Versions/A/Resources/libFontRegistry.dylib
      0x9802c000 - 0x980fdfe3  ColorSyncDeprecated.dylib 4.6.0 (compatibility 1.0.0) <41417F73-42C5-FFC3-E7A1-EF94602CDCD6> /System/Library/Frameworks/ApplicationServices.framework/Frameworks/ColorSync.framework/V ersions/A/Resources/ColorSyncDeprecated.dylib
      0x98109000 - 0x98112ff7  com.apple.DiskArbitration 2.3 (2.3) <E9C40767-DA6A-6CCB-8B00-2D5706753000> /System/Library/Frameworks/DiskArbitration.framework/Versions/A/DiskArbitration
      0x98154000 - 0x981fcffb  com.apple.QD 3.36 (???) <FA2785A4-BB69-DCB4-3BA3-7C89A82CAB41> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/QD.framewo rk/Versions/A/QD
      0x98335000 - 0x98366ff7  libGLImage.dylib ??? (???) <1AF72191-087A-5D75-B3B9-3F537315F635> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libGLImage.dylib
      0x98367000 - 0x98379ff7  com.apple.MultitouchSupport.framework 207.10 (207.10) <E1A6F663-570B-CE54-0F8A-BBCCDECE3B42> /System/Library/PrivateFrameworks/MultitouchSupport.framework/Versions/A/MultitouchSuppor t
      0x9837a000 - 0x9837aff7  com.apple.Accelerate 1.6 (Accelerate 1.6) <BC501C9F-7C20-961A-B135-0A457667D03C> /System/Library/Frameworks/Accelerate.framework/Versions/A/Accelerate
      0x9837b000 - 0x983f4ff7  com.apple.PDFKit 2.5.1 (2.5.1) <CEF13510-F08D-3177-7504-7F8853906DE6> /System/Library/Frameworks/Quartz.framework/Versions/A/Frameworks/PDFKit.framework/Versio ns/A/PDFKit
      0x983f5000 - 0x98435ff7  com.apple.ImageCaptureCore 1.0.4 (1.0.4) <CE815114-CEFA-4AF4-7365-7908428AB733> /System/Library/Frameworks/ImageCaptureCore.framework/Versions/A/ImageCaptureCore
      0x98461000 - 0x984bbfe7  com.apple.CorePDF 1.3 (1.3) <696ADD5F-C038-A63B-4732-82E4109379D7> /System/Library/PrivateFrameworks/CorePDF.framework/Versions/A/CorePDF
      0x984bc000 - 0x9872ffe7  com.apple.Foundation 6.6.6 (751.53) <C73FDD37-000B-C505-FD8D-80D1C9D17965> /System/Library/Frameworks/Foundation.framework/Versions/C/Foundation
      0x9875a000 - 0x987a0ff7  libauto.dylib ??? (???) <29422A70-87CF-10E2-CE59-FEE1234CFAAE> /usr/lib/libauto.dylib
      0x991f4000 - 0x99202fe7  libz.1.dylib 1.2.3 (compatibility 1.0.0) <3CE8AA79-F077-F1B0-A039-9103A4A02E92> /usr/lib/libz.1.dylib
      0x99203000 - 0x99283feb  com.apple.SearchKit 1.3.0 (1.3.0) <9E18AEA5-F4B4-8BE5-EEA9-818FC4F46FD9> /System/Library/Frameworks/CoreServices.framework/Versions/A/Frameworks/SearchKit.framewo rk/Versions/A/SearchKit
      0x99284000 - 0x992c1ff7  com.apple.SystemConfiguration 1.10.5 (1.10.2) <362DF639-6E5F-9371-9B99-81C581A8EE41> /System/Library/Frameworks/SystemConfiguration.framework/Versions/A/SystemConfiguration
      0x992ee000 - 0x9941cfe7  com.apple.CoreData 102.1 (251) <E6A457F0-A0A3-32CD-6C69-6286E7C0F063> /System/Library/Frameworks/CoreData.framework/Versions/A/CoreData
      0x9941d000 - 0x99432fff  com.apple.ImageCapture 6.0.2 (6.0.2) <E9F4B952-27A1-5BFC-CA8D-DADA055D30E9> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/ImageCapture.framework/ Versions/A/ImageCapture
      0x99433000 - 0x99433ff7  com.apple.vecLib 3.6 (vecLib 3.6) <7362077A-890F-3AEF-A8AB-22247B10E106> /System/Library/Frameworks/vecLib.framework/Versions/A/vecLib
      0x99434000 - 0x99758fef  com.apple.HIToolbox 1.6.5 (???) <21164164-41CE-61DE-C567-32E89755CB34> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/HIToolbox.framework/Ver sions/A/HIToolbox
      0x99759000 - 0x997f1fe7  edu.mit.Kerberos 6.5.11 (6.5.11) <F36DB665-A88B-7F5B-6244-6A2E7FFFF668> /System/Library/Frameworks/Kerberos.framework/Versions/A/Kerberos
      0x998f9000 - 0x998fcff7  libCoreVMClient.dylib ??? (???) <12EF6056-7AC7-6691-75A2-BD0675C56A35> /System/Library/Frameworks/OpenGL.framework/Versions/A/Libraries/libCoreVMClient.dylib
      0x998fd000 - 0x9990eff7  com.apple.LangAnalysis 1.6.6 (1.6.6) <97511CC7-FE23-5AC3-2EE2-B5479FAEB316> /System/Library/Frameworks/ApplicationServices.framework/Versions/A/Frameworks/LangAnalys is.framework/Versions/A/LangAnalysis
      0x9990f000 - 0x999c8fe7  libsqlite3.dylib 9.6.0 (compatibility 9.0.0) <52438E77-55D1-C231-1936-76F1369518E4> /usr/lib/libsqlite3.dylib
      0x999c9000 - 0x99a02ff7  libcups.2.dylib 2.8.0 (compatibility 2.0.0) <90C5DE81-1BEF-D807-A898-0FC19BDD14EC> /usr/lib/libcups.2.dylib
      0x99a03000 - 0x99ab1ff3  com.apple.ink.framework 1.3.3 (107) <57B54F6F-CE35-D546-C7EC-DBC5FDC79938> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/Ink.framework/Versions/ A/Ink
      0x99ab2000 - 0x99acefe3  com.apple.openscripting 1.3.1 (???) <DA16DE48-59F4-C94B-EBE3-7FAF772211A2> /System/Library/Frameworks/Carbon.framework/Versions/A/Frameworks/OpenScripting.framework /Versions/A/OpenScripting
      0xb0000000 - 0xb0010ff8 +com.adobe.ahclientframework 1.6.0.5 (1.6.0.5) <8F89CE47-10C1-AE43-AB78-7BB2D24BA50B> /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/ahclient.framework/Versions/A/ahclient
      0xba300000 - 0xba301fe7  libCyrillicConverter.dylib 49.0.0 (compatibility 1.0.0) <917C387A-1F4E-F72C-514D-862CF11A822C> /System/Library/CoreServices/Encodings/libCyrillicConverter.dylib
      0xba900000 - 0xba916ff7  libJapaneseConverter.dylib 49.0.0 (compatibility 1.0.0) <B339B85B-1B6D-81D8-1281-7B8C8A517329> /System/Library/CoreServices/Encodings/libJapaneseConverter.dylib
      0xbab00000 - 0xbab21fe7  libKoreanConverter.dylib 49.0.0 (compatibility 1.0.0) <EF3E3210-927F-DB9F-4CD4-4039A2AE2F84> /System/Library/CoreServices/Encodings/libKoreanConverter.dylib
      0xcc000000 - 0xcc186fef +com.mainconcept.mc_dec_mp2v 8.5 (8.5.0.24499) /Applications/Adobe Premiere Elements 9/Adobe Premiere Elements.app/Contents/Frameworks/mc_dec_mp2v.framework/Versions/8.5/mc_dec_mp2v
      0xffff0000 - 0xffff1fff  libSystem.B.dylib ??? (???) <ADF8138B-2384-2FC0-CCBF-C4721B53568A> /usr/lib/libSystem.B.dylib
