1 Reply Latest reply on Apr 15, 2011 10:42 AM by ssardar
    adanced datagrid column selector idea..??
    jahnvi25 Level 1
      so i have this requirement where i have many columns in advanced Datagrid with reasonable width, but i can not enable horizontal scrollbar at bottom.
      instead what our department wants is.. to have some radio button (number is dynamic based on how many columns are visible at a time) and user can select a particular radio button to make some columns visible , for example.. if i have first 3 columns visible, and i click on 2nd radio button then column 4,5,6 should be visible and so on... what is the better way to achieve this .. any idea how can i implement is best possible way ??
        • 1. Re: adanced datagrid column selector idea..??
          ssardar
          If I understand you correctly I think you want to use checkbox and not radio button.
          You also probably want to write a function to resize the column "width" based on how many are visible and the width of your ADG.
          But this is the easiest way to do this.
          <mx:Application
          xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute">
          <mx:Script>
          <![CDATA[
          </mx:Script>
          <mx:AdvancedDataGrid id="adg1" x="87" y="197" id="adg1" designViewDataType="tree" width="533" height="257">
          <mx:columns>
          <mx:AdvancedDataGridColumn headerText="Column 1" dataField="col1" visible="{cb1.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 2" dataField="col2" visible="{cb1.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 3" dataField="col3" visible="{cb1.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 4" dataField="col1" visible="{cb2.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 5" dataField="col2" visible="{cb2.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 6" dataField="col3" visible="{cb2.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 7" dataField="col1" visible="{cb3.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 8" dataField="col2" visible="{cb3.selected}"/>
          <mx:AdvancedDataGridColumn headerText="Column 9" dataField="col3" visible="{cb3.selected}"/>
          </mx:columns>
          </mx:AdvancedDataGrid>
          <mx:CheckBox id="cb1" x="87" y="98" label="Checkbox"/>
          <mx:CheckBox id="cb2" x="87" y="128" label="Checkbox"/>
          <mx:CheckBox id="cb3" x="87" y="158" label="Checkbox"/>
          </mx:Application>
