0 Replies Latest reply: Apr 14, 2011 8:59 PM by chaocanha RSS
    problem with passing xml data from flash(actionscript 3) to asp.net
    chaocanha Community Member
      i have code in flash (as3):
      function xacnhanclick(evt:Event):void
                     var bookedXML:XML=<data/>;
                     for(var i:uint=0;i<hang;i++)
                          for(var j:uint=0;j<cot;j++)
                               if(ghearray[i][j]._check==1)
                                    bookedXML.data+=
                                    <ghe>
                       <maghe>{i + '' + j}</maghe>
                       <hangindex>{i}</hangindex>
                       <cotindex>{j}</cotindex>
                     </ghe>;
                                    //trace(i+" "+j);
                     sendxml(bookedXML);
                public function sendxml(xml:XML):void
                     var req:URLRequest = new URLRequest("Chonphong.aspx");
                  req.method = URLRequestMethod.POST;
                  req.contentType = "text/xml";
                  req.data = "<?xml version='1.0' encoding='utf-8' ?>\n" + xml;
                  sendToURL(req);
                     trace(req.data);
      and i try to get xml data in aspx, but but it has an error: "Data at the root level is invalid. Line 1, position 1." i've checked the format of xml data in flash. it's correct. please help me
      XmlDocument myXmlDoc = new XmlDocument();
          myXmlDoc.PreserveWhitespace = true;
          myXmlDoc.Load(Request.InputStream);
          Response.Write(myXmlDoc.InnerXml);
