12 Replies Latest reply on Feb 13, 2013 3:30 AM by Velprakash
    Export Epub in InDesign CS5
    Oviya... Level 1
      Hi Friends,
      How can i export epub[Digital Editions] in InDesign CS5 java script...?
      Divya.
        • 1. Re: Export Epub in InDesign CS5
          Oviya... Level 1
          ExportFormat.epsType
          ExportFormat.inCopy
          ExportFormat.pdfType
          ExportFormat.rtf
          ExportFormat.svg
          ExportFormat. svgCompressed
          ExportFormat. taggedText
          ExportFormat.textType
          ExportFormat.xml
          Which type for EPub[Digital Editions]...?
          • 2. Re: Export Epub in InDesign CS5
            csm_phil Level 4
            Hi Ovi,
            You will use this js line;
            #targetengine "digital editions"
            OEBExportMenuItem.exportDocuments(app.activeDocument);
            thx
            csm_phil,
            • 3. Re: Export Epub in InDesign CS5
              Oviya... Level 1
              var fileNam = app.activeDocument.name
              fileNam = fileNam.replace(".indd",".epub");
              var myEpub = new File(FilePath+fileNam);
              app.activeDocument.exportFile(ExportFormat.pdfType,myEpub,false,undefined);
              I am trying code like this... In this where I have to add your line...?
              • 4. Re: Export Epub in InDesign CS5
                Oviya... Level 1
                Very Urgent Friends...
                If anybody help me Java script code for export ePub.....
                • 5. Re: Export Epub in InDesign CS5
                  Kasyan Servetsky Level 5
                  This feature is implemented via scripting so you can't export it as usual. Read this thread — it may help you to solve your problem.
                  Kas
                  • 6. Re: Export Epub in InDesign CS5
                    And that will change to "normal" scripting in InDesign CS5.5.
                    See Marc Autrets "en_ID-CS55-DOM-WhatsNewObjects.pdf", page 12 at www.indiscript.com.
                    Uwe
                    • 8. Re: Export Epub in InDesign CS5
                      Green4ever Level 3
                      Try this post.....
                      http://forums.adobe.com/message/1924584#1924584
                      I have copied the code from  this post.... Check is this helpful for you...
                      app.scriptPreferences.version = 5.0;
                      var outputFile = File("D:\\test.xhtml");
                      var document = app.activeDocument;
                      var scriptPath = Folder.startup + '/Scripts/Export as XHTML/';
                      var scriptFile = File(scriptPath + 'XHTMLExport.jsxbin');
                      if (scriptFile.exists) {
                       scriptFile.open();
                       var script = scriptFile.read();
                       scriptFile.close();
                       eval(script);
                       var opts = new XHTMLExportOptions();
                       opts.styleHandling = XHTMLExportOptions.extStyleSheet;
                       opts.styleSheet = 'template.css';
                       opts.formatted = true;
                       app.exportForWebPreferences.gifOptionsInterlaced = true;
                       var exporter = new XHTMLExporter(scriptFile);
                       var success = exporter.doExport(document, undefined, opts, outputFile);  // check the results:
                       if(success)
                       /*if(exporter.outOfDateLinks.length > 0)
                       alert('Exporting ' + document.name + ' succeeded\nHowever ' + exporter.outOfDateLinks.length + ' links were out of date.');
                       else
                       alert('Exporting ' + document.name + ' failed with this error message:\n' + exporter.error.message);
                      Green4ever
                      • 9. Re: Export Epub in InDesign CS5
                        Oviya... Level 1
                        Hi All,
                        I have copied the code which i had tried in InDesign CS5 java script for export Epub..
                        But I got the error as "Uncaught Javascript Exception Cannot Export ABCD.indd" and "Interpreter: CS3 (5.0)".
                        Please give solution friends........
                        function digitalEditionsExport()
                            var outputFile = File("/Desktop/18042011/ABCD.epub");
                            var documentToExport = File("/Desktop/18042011/ABCD.indd");
                            var source = app.open(documentToExport, false);
                            var scriptFile = File("/Adobe InDesign CS5/Scripts/XHTML For Digital Editions/OEBExport.jsxbin");
                                scriptFile.open();
                                scriptFile.close();
                                eval(script);
                                var xhtmlscript = File("/Adobe InDesign CS5/Scripts/Export As XHTML/XHTMLExport.jsxbin");
                                xhtmlscript.open();
                                var otherScript = xhtmlscript.read();
                                xhtmlscript.close();
                                eval(otherScript);
                                var opts = new OEBExportOptions();
                                opts.imageConversion = ImageConversion.automatic;
                                opts.gifOptionsPalette = GIFOptionsPalette.adaptivePalette;
                                opts.jpegOptionsQuality = JPEGOptionsQuality.medium;
                                opts.jpegOptionsFormat = JPEGOptionsFormat.baselineEncoding;
                                var exporter = new OEBExporter("/Adobe InDesign CS5/Scripts/XHTML For Digital Editions/","ABCD", undefined);
                                var success = exporter.doExport(source, opts, outputFile);
                                if(success)
                                        alert("Exporting " + document.name + " succeeded\nHowever " + exporter.outOfDateLinks.length + " links were out of date.");
                                else
                                    alert("Exporting " + document.name + " failed with this error message:\n" + exporter.error.message);
                            source.close(SaveOptions.no);
                            return success;
                        var result = digitalEditionsExport();
                        var message = "Digital Editions Export ";
                        message += result?"did ":"did not ";
                        message += "export the file.";
                        message;
                        • 10. Re: Export Epub in InDesign CS5
                          Oviya... Level 1
                          Right script for Export Epub
                                  scriptFile.open();
                                  scriptFile.close();
                                  eval(script);
                                  xhtmlscript.open();
                                  eval(otherScript);
                                  if(success)
                                  else
                              return success;
                          message;
                          • 11. Re: Export Epub in InDesign CS5
                            Oviya... Level 1
                            Thanks a lot Green4ever.............
                            • 12. Re: Export Epub in InDesign CS5
                              Velprakash Level 1
                              Hi Ms. Oviya,
                                      I used your above codes to export ePub. But I'm getting an error. It's shown  below. Plz have a look at it.
                              Even I looked for swf_template.html file in resources. It's there. But I can't guess abt the error. Can Any Expertise Advice..
                              Thanks and Regards,
                              Vel.
