4 Replies Latest reply on Apr 15, 2011 6:50 AM by ledroff
    My FlexPMD report is empty at "target/site/flexpmd.html", why?
    Gentle Zhou
      After executed "mvn site", the page "target/flexpmd.html" shows content correctly, while the page "target/site/flexpmd.html" shows nothing!
      Any body could help me ? Thanks !
      Here is my pom.xml :
        <build>
          <sourceDirectory>src/main/flex</sourceDirectory>
          <testSourceDirectory>src/test/flex</testSourceDirectory>
          <plugins>
            <plugin>
              <groupId>org.sonatype.flexmojos</groupId>
              <artifactId>flexmojos-maven-plugin</artifactId>
              <version>4.0-pre-alpha-1</version>
              <extensions>true</extensions>
            </plugin>
            <plugin>
              <groupId>org.apache.maven.plugins</groupId>
              <artifactId>maven-site-plugin</artifactId>
              <version>3.0-beta-3</version>
            </plugin>
          </plugins>
        </build>
        <dependencies>
          <dependency>
            <groupId>com.adobe.flex.framework</groupId>
            <artifactId>flex-framework</artifactId>
            <version>4.0.0.13875</version>
            <type>pom</type>
          </dependency>
          <dependency>
            <groupId>com.adobe.flexunit</groupId>
            <artifactId>flexunit</artifactId>
            <version>0.85</version>
            <type>swc</type>
            <scope>test</scope>
          </dependency>
        </dependencies>
        <reporting>
          <plugins>
            <plugin>
              <groupId>com.adobe.ac</groupId>
              <artifactId>flex-pmd-maven-plugin</artifactId>
              <version>${flexpmd.version}</version>
              <configuration>
                <failOnError>true</failOnError>
              </configuration>
            </plugin>
          </plugins>
        </reporting>
        • 1. Re: My FlexPMD report is empty at "target/site/flexpmd.html", why?
          Gentle Zhou Level 1
          I forget to post the output:
          [INFO] Scanning for projects...
          [INFO]
          [INFO] ------------------------------------------------------------------------
          [INFO] Building zxvc Flex 1.0-SNAPSHOT
          [INFO]
          [INFO] --- maven-site-plugin:3.0-beta-3:site (default-site) @ zxvc ---
          [INFO] configuring report plugin com.adobe.ac:flex-pmd-maven-plugin:1.2
          [INFO]
          [INFO] >>> flex-pmd-maven-plugin:1.2:check (report:check) @ zxvc >>>
          [INFO]
          [INFO] --- flex-pmd-maven-plugin:1.2:report (report) @ zxvc ---
          [INFO] FlexPmdMojo starts
          [INFO]    failOnError     false
          [INFO]    ruleSet         null
          [INFO]    sourceDirectory D:\Maven\flexProjects\zxvc\src\main\flex
          [INFO]    ruleSetURL      null
          [INFO] getting RuleSet from URL
          [INFO] Ruleset URL is not set
          2011-4-15 16:54:31 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine loadRuleset
          信息: Ruleset: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\default_flex7239989773905659246.xml
          信息: Rules number in the ruleSet: 107
          2011-4-15 16:54:31 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine computeViolations
          信息: It took 110ms to compute violations
          2011-4-15 16:54:31 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine computeViolationNumber
          信息: Violations number found: 6
          2011-4-15 16:54:31 com.adobe.ac.pmd.engines.FlexPmdXmlEngine writeReport
          信息: Creating report in <D:\Maven\flexProjects\zxvc\target\pmd.xml>
          2011-4-15 16:54:31 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine writeAnyReport
          信息: It took 0ms to write the Xml report
          信息: Ruleset: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\default_flex8880975809880234001.xml
          2011-4-15 16:54:32 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine writeAnyReport
          信息: It took 79ms to write the Html report
          [INFO]
          [INFO] <<< flex-pmd-maven-plugin:1.2:check (report:check) @ zxvc <<<
          [WARNING] Error loading report com.adobe.ac.pmd.maven.FlexPmdMojo - AbstractMethodError: canGenerateReport()
          [WARNING] Error loading report com.adobe.ac.pmd.maven.FlexPmdReportMojo - AbstractMethodError: canGenerateReport()
          [WARNING] Report plugin org.apache.maven.plugins:maven-project-info-reports-plugin has an empty version.
          [WARNING]
          [WARNING] It is highly recommended to fix these problems because they threaten the stability of your build.
          [WARNING]
          [WARNING] For this reason, future Maven versions might no longer support building such malformed projects.
          [INFO] configuring report plugin org.apache.maven.plugins:maven-project-info-reports-plugin:2.3.1
          [WARNING] No URL defined for the project - decoration links will not be resolved
          [INFO] Rendering site with org.apache.maven.skins:maven-default-skin:jar:1.0 skin.
          [INFO] Skipped "Flex PMD Report" report, file "flexpmd.html" already exists forthe English version.
          [INFO] Generating "Flex PMD Report" report    --- flex-pmd-maven-plugin:1.2
          [INFO]    failOnError     true
          [INFO]    ruleSet         null
          2011-4-15 16:54:34 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine loadRuleset
          INFO: Ruleset: C:\DOCUME~1\ADMINI~1\LOCALS~1\Temp\default_flex6737166268885457111.xml
          INFO: Rules number in the ruleSet: 107
          2011-4-15 16:54:34 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine computeViolations
          INFO: It took 32ms to compute violations
          2011-4-15 16:54:34 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine computeViolationNumber
          INFO: Violations number found: 6
          2011-4-15 16:54:34 com.adobe.ac.pmd.engines.FlexPmdXmlEngine writeReport
          INFO: Creating report in <D:\Maven\flexProjects\zxvc\target\pmd.xml>
          2011-4-15 16:54:34 com.adobe.ac.pmd.engines.AbstractFlexPmdEngine writeAnyReport
          INFO: It took 0ms to write the Xml report
          [INFO] Generating "Continuous Integration" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Dependencies" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Distribution Management" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "About" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Issue Tracking" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Project License" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Mailing Lists" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Plugin Management" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Project Plugins" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Project Team" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Source Repository" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] Generating "Project Summary" report    --- maven-project-info-reports-plugin:2.3.1
          [INFO] BUILD SUCCESS
          [INFO] Total time: 13.032s
          [INFO] Finished at: Fri Apr 15 16:54:38 CST 2011
          [INFO] Final Memory: 11M/36M
          • 2. Re: My FlexPMD report is empty at "target/site/flexpmd.html", why?
            ledroff Adobe Employee
            It looks like a bug to me.
            please report it there :
            https://bugs.adobe.com/jira/browse/CGM/component/11381
            specifiy the version of flex-mojos and maven you are using
            and eventually a sample project.
            François
            • 3. Re: My FlexPMD report is empty at "target/site/flexpmd.html", why?
              Gentle Zhou Level 1
              It's a link to Cairngorm.
              Are you sure I should report the flexPMD bug there?
              • 4. Re: My FlexPMD report is empty at "target/site/flexpmd.html", why?
                my bad... (I'm bad at task switching )
                yes use the flexpmd jira space instead
                here you go :
                https://bugs.adobe.com/jira/browse/FLEXPMD
