1 Reply Latest reply on Apr 17, 2011 8:13 PM by BennyB23
    Tooltips for Datagrid text
    learner_doug Level 1
      Can you make datagrid text have tooltips?  I'm planning on feeding the text from an XML file.
      Thanks.
        • 1. Re: Tooltips for Datagrid text
          BennyB23
          I think you use dataTip for the dataProvider and you could set up an xml file with a node for the dataTip that coincides with the column's datafield, using the fx:Model in the declarations...
          xml file with repeating "item" tags in a folder "data" inside the src folder
          fx:Model id="itemModel" source="data/datagrid.xml" />
          <s:ArrayList id="itemList" source="{itemModel.item}" />
          Hope that helps...
          ~B
