3 Replies Latest reply on Apr 17, 2011 8:59 AM by Jim_Simon
    Exporting Progressive Footage
    spookyuk@yahoo.com
      Hi There.
      I have a Sony Z5 and have played with the 25P HDV setting. I like the effect and wish to use it on shoots. When I started to edit the footage, it dawned on me that I had no real true idea of how to import it and then export it.
      I bought into PP CS5 as HDV 1080 2p5 but not sure If I should be usuing this one (I am in the UK where PAL is used).
      Once I had edited I wanted to export out and not sure which settings I should use. I have tested a few using "Match Source" and them playing around. The source would say 25fps Prog but the output shows as Upper with no room to change.
      I may be causing myself more headaches than I should but wonder if it makes much difference and if someone with more experiince that I could offer a workflow?
      Thanks in advance
        • 1. Re: Exporting Progressive Footage
          hdv 1080p25 is just fine. If you do not know which settings to choose drag a file into the New Item icon.
          Don't use Match Sequence Settings it does not work quite correct. Choose a preset or set everything manually.
          What is the final destination of your footage?
          • 2. Re: Exporting Progressive Footage
            spookyuk@yahoo.com Level 1
            Thanks for the help.
            Final destination of footage will be mixed, sometimes Blu-ray, other times (when less that 25mins) a regular DVD as AVCHD using Encore to build a Blu-ray image and ImgBurn to create the DVD.
            Which preset would you suggest for the export? I noticed there are some HDTV ones... would one of these be best and if so which? I think chosing a preset would more than likely mean I would have to tweak something or other and therefor making a custom one. It would be useful to know though if a Preset would work for my needs and that i was getting the best output possible.
            Just as a matter for the look of the film. I have heard a lot about the Programme 6 preset on the Sony Z5 and used this along with the 25P setting. I think the footage looks good but doesn't soften much or give the yellowish tint you kinda associate with Film. If anyone has a better experience with the presets within the camera, be good to know.
            Thanks again for your help
            • 3. Re: Exporting Progressive Footage
              Jim_Simon Level 9
              Blu-ray cannot handle 25p at any resolution.  If you wish to shoot at 25 fps, shoot interlaced.  If you wish to shoot progressive, shoot 720p/50.
