Hello there .
I'm having some troubles exporting a movieClip made in Flash CS5 Professionnal to Flash Builder.
I created a simple movieclip name test : rectangle and textinput inside name "title", then command ->convert symbol for Flex. Everything looks good. I publish the .swc and import it in Flash Builder.
Everything is good when I just add the MovieClip :
xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600" xmlns:local="*">
<local:test />
</s:Application>
but when I try to set a value to the title <local:test title="Title" />, I get the following error : (sorry it's in french =O)
Description Resource Path Location Type
Initialiseur pour 'test' : les valeurs du type flash.text.TextField ne peuvent pas être représentées dans le texte. TestComponent.mxml /TestComponent/src line 5 Erreur Flex
Nevermind stupid question
title points on TextField and not on .text property... of course -.-
