1 Reply Latest reply on Nov 13, 2006 7:51 PM by sbryner
    simple variable values passed between .swf files
      I need to send three simple variable values from a mother movie to subsequent externally-loaded .swf files. I've been using loadMovieNum() to load the external .swf files to both replace the mother movie and also to sit on top of it and can't get the variable values to pass from one to the other. I don't need to load them from an external file, or do anything fancy. I just need the loaded movie to grab values from the mother movie that spawned it.
      Thanks in advance.
        • 1. simple variable values passed between .swf files
          sbryner Level 1
          I had a similar problem since I started learning AS.
          use _global.variableName = "whatever";
          let's say you need to pass the variable "tom" from movie to movie
          try this...
          _global.myName = "tom"
          in another movie use
          theText_txt.text = myName;
          it would set the dynamic text with instance name "theText_txt" equal to your global variable in this case "tom".
          I'd start here.
          try searching for passing variables or global variables and see what comes up in the forums previous posts.
          hope this helps.
