5 Replies Latest reply on Apr 18, 2011 7:48 PM by Flex harUI
    DataGrid is getting columns at the run time (Flex 4.5)
    Zolotoj Level 3
      Initially my DataGrid which has the following columns:
      person_id, name, wroknumber
      is set to have dataProvider to this:
      <item>
        <id>0</id>
      </item>
      At the running time the grid shows an empty row.
      Using a custom item renderer I am executing the following code on Change event:
      DataGrid(owner).dataProvider[rowIndex][column.dataField] = "somevalue";
      What is happening at this point is that dataProvider is getting a new column. If I trace it then it looks like this:
      <item>
        <id>0</id>
        <worknum>6593</worknum>
      </item>
      It is probably right but I want to know what are mechanics behind that.
        • 1. Re: DataGrid is getting columns at the run time (Flex 4.5)
          Flex harUI Adobe Employee
          Post a 20-line test case.
          • 2. Re: DataGrid is getting columns at the run time (Flex 4.5)
            Zolotoj Level 3
            Hope that will help:
                              xmlns:s="library://ns.adobe.com/flex/spark" creationComplete="init()"
                              xmlns:mx="library://ns.adobe.com/flex/mx" minWidth="955" minHeight="600">
                 <fx:Declarations>
                      <!-- Place non-visual elements (e.g., services, value objects) here -->
                      <fx:XMLList id="personnelData" xmlns="">
                           <consistpersonnel>
                                <id>0</id>
                           </consistpersonnel>
                      </fx:XMLList>
                      <fx:XMLList id="crew" xmlns="">
                           <item>
                                <person>Conductor</person>
                                <person_id>1</person_id>
                           </item>
                           <item>
                                <person>Engineer</person>
                                <person_id>2</person_id>
                           </item>
                           <item>
                                <person>Helper</person>
                                <person_id>3</person_id>
                           </item>
                      </fx:XMLList>
                 </fx:Declarations>
                 <fx:Script>
                      <![CDATA[
                           import mx.collections.ArrayCollection;
                           import mx.collections.ICollectionView;
                           import mx.collections.IList;
                           import mx.collections.XMLListCollection;
                           import mx.events.CollectionEvent;
                           import mx.events.DataGridEvent;
                           import mx.events.DynamicEvent;
                           import mx.events.ListEvent;
                           import spark.events.GridItemEditorEvent;
                           private function init():void
                                personnel.dataProvider = new XMLListCollection(personnelData);
                                personnel.validateNow();
                                var PersonnelPerson:ClassFactory = new ClassFactory(dropdownRendererDataGrid);
                                PersonnelPerson.properties = {labelField : "person", dataProvider :
                                new XMLListCollection(crew)};
                                var col:GridColumn = GridColumn(personnel.columns.getItemAt(0));
                                col.itemRenderer = PersonnelPerson;
                 </fx:Script>
                 <s:VGroup>
                 <s:Button click="{trace(personnel.dataProvider)}" label="Trace DP"/>
                 <s:DataGrid requestedRowCount="4" fontSize="11" sortableColumns="false"
                                id="personnel" rowHeight="22" height="100%">
                      <s:columns>
                           <s:ArrayList>
                                <s:GridColumn dataField="person_id" headerText="Person" width="95">
                                     <s:itemRenderer>
                                          <fx:Component>
                                               <s:GridItemRenderer>
                                                    <s:layout>
                                                         <s:VerticalLayout paddingLeft="2"
        verticalAlign="middle"/>
                                                    </s:layout>
                                               </s:GridItemRenderer>
                                          </fx:Component>
                                     </s:itemRenderer>
                                </s:GridColumn>
                           </s:ArrayList>
                      </s:columns>
                 </s:DataGrid>
                 </s:VGroup>
            </s:Application>
            and package with custom renderer:
            package
                 import flash.events.Event;
                 import flash.events.KeyboardEvent;
                 import flash.events.MouseEvent;
                 import spark.components.DataGrid;
                 import spark.components.DropDownList;
                 import spark.components.Grid;
                 import spark.components.List;
                 import spark.components.gridClasses.GridColumn;
                 import spark.components.gridClasses.IGridItemRenderer;
                 import spark.events.DropDownEvent;
                 import spark.skins.spark.DropDownListSkin;
                 public class dropdownRendererDataGrid extends DropDownList implements IGridItemRenderer
                      private var _columnIndex:int;
                      private var _data:Object;
                      private var _column:GridColumn;
                      private var bSelectedValueSet:Boolean = false;
                      private var _rowIndex:int;
                      public function dropdownRendererDataGrid()
                           super();
                           addEventListener("change", onDataChange);
                      public function get rowIndex():int
                           return _rowIndex;
                      public function set rowIndex(value:int):void
                           _rowIndex = value;
                      public function get dragging():Boolean
                           return false;
                      public function set dragging(value:Boolean):void
                      public function get hovered():Boolean
                           return false;
                      public function set hovered(value:Boolean):void
                      public function get label():String
                           return null;
                      public function set label(value:String):void
                      public function get selected():Boolean
                           return false;
                      public function set selected(value:Boolean):void
                      public function get showsCaret():Boolean
                           return false;
                      public function set showsCaret(value:Boolean):void
                      public function get column():GridColumn
                           return _column;
                      public function set column(value:GridColumn):void
                           _column = value;
                      public function get grid():Grid
                           return null;
                      public function set grid(value:Grid):void
                      public function prepare(willBeRecycled:Boolean):void
                      public function discard(hasBeenRecycled:Boolean):void
                      public function get data():Object
                           return null;
                      public function set data(value:Object):void
                           _data = value;
                           for (var i:int=0;i<dataProvider.length;i++)
                                // Check if is selectedValue
                                if(dataProvider[i][column.dataField] == value[column.dataField])
                                     if(selectedIndex != i)
                                          selectedIndex = i;
                                     break;
                           if (i == dataProvider.length)
                                selectedIndex = -1;
                      override public function stylesInitialized():void
                           super.stylesInitialized();
                           setStyle("skinClass", DropDownListSkin);
                      protected function onDataChange(event:Event):void
                           if (DataGrid(owner).selectedIndex != rowIndex)
                                DataGrid(owner).selectedIndex = rowIndex;
                           DataGrid(owner).dataProvider[rowIndex][column.dataField] = selectedItem[column.dataField];
                      public function get columnIndex():int
                           return _columnIndex;
                      public function set columnIndex(value:int):void
                           _columnIndex = value;
                      public function get down():Boolean
                           return false;
                      public function set down(value:Boolean):void
            Click Print DP then select something from the dropdown and click Print DP again. You should see something like this:
            <consistpersonnel>
              <id>0</id>
            </consistpersonnel>
            <consistpersonnel>
              <id>0</id>
            </consistpersonnel>
            Thank you for help.
            • 3. Re: DataGrid is getting columns at the run time (Flex 4.5)
              I didn't run the test case but I noticed that the onDataChange handler is
              modifying the dataprovider objects
              • 4. Re: DataGrid is getting columns at the run time (Flex 4.5)
                Zolotoj Level 3
                Yes, correct. It's my understanding that I have to do that in order to have the grid carrying newly entered data. Althought having full data binding is probably better.
                • 5. Re: DataGrid is getting columns at the run time (Flex 4.5)
                  Typically, modifications to the data are done via itemEditors.  See the doc.
                  Renderers generally should not modify the data, especially on the dataChange
                  event.
