I am building a DVD in Encore CS4 and have two issues. The DVD consists of a main menu with one button linked to the main timeline (3 min 45 sec) and a video(1 min 2 sec 21 frames) linked for the menu to have motion along with an audio clip with the same run time. The video and audio were exported from Encore CS4 as MPEG2-DVD.The loop point is set to 9 sec 11 frames and is set to forever.
Issue 1- When I try to preview the project in Encore before burning it starts as it should but stops at the loop point (9 sec 11 frames into it) and plays from the beginning. When I burn the DVD the loop works properly but I can not see it in the preview prior to burning. I wasted a couple of discs lining up the loop point due to no preview. I should also note that
Issue 2- When the DVD is burned and played it loads the menu which plays as it should. At the 9 second mark a button appears signifying the loop point which when selected begins the actual video, as it should. After the video finishes and it loops back to the 9 second mark the button vanishes. The only way to navigate at this point is to hit the top menu button which starts it from scratch.
I went back to a test burn I made and the button remained continuously after looping. What could I have hit that is now making the button vanish? And what can I do to get a full preview before going to build?
Thanks for any thoughts.
Cole
1 is a problem. Encore's preview capabilities have never been flawless. Use rewritable disks to avoid coasters.
2 is new, but I can't think of anythjing off hand to explain it.
