3 Replies Latest reply on Apr 28, 2011 4:22 AM by AbhilashBenz
    Newbie Question: Please Help
    AbhilashBenz
      Hi, I am Abhilash A newbee for FlexFramework and LiveCycle Data Services.
      I tried to connect to a java class Hello through RemoteObject.
      Hello.java
      class Hello
          public String sayHello()
              return "Hello From LCDS";
      RemotingIntro.mxml
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     width="100%" height="100%">
          <fx:Script>
              <![CDATA[
                  import mx.rpc.events.FaultEvent;
                  import mx.rpc.events.ResultEvent;
                  private function echo():void
                      /* var text:String = ti.text; */
                      remoteObject.sayHello();
                  protected function remoteObject_resultHandler(event:ResultEvent):void
                      // TODO Auto-generated method stub
                      ta.text = "Server Responded: " + event.result + "\n";
                  protected function remoteObject_faultHandler(event:FaultEvent):void
                      ta.text = "Received Fault: " + event.fault + "\n";
          </fx:Script>
          <fx:Declarations>
              <!-- Place non-visual elements (e.g., services, value objects) here -->
              <s:RemoteObject id="remoteObject"
                              destination="hello"
                              result="remoteObject_resultHandler(event)"
                              fault="remoteObject_faultHandler(event)"/>
          </fx:Declarations>
          <!-- UI Elemets -->
          <s:Label text="Enter a text for the server to echo" x="10" y="35"/>
          <s:TextInput x="196" y="30" id="ti" text="Hello World!"/>
          <s:Button x="367" y="31" label="Send" click="echo()"/>
          <s:TextArea x="9" y="73" id="ta" width="100%" height="80%"/>
      </s:Application>
      I have created a destination like:
      <destination id="hello" channels="my-amf">
      <properties>
          <source>Hello</source>
      </properties>
      </destination>
      I have defined the my-amf channel as:
      <channel-definition id="my-amf" class="mx.messaging.channels.AMFChannel">
                  <endpoint url="http://localhost:8400/lcds-samples/messagebroker/amf" class="flex.messaging.endpoints.AMFEndpoint"/>
                  <properties>
                      <polling-enabled>false</polling-enabled>
                  </properties>
              </channel-definition>
      After changing the configuration I restarted the LCDS Data Services Server and tried to execute the application which gave me the following error:
      Received Fault: [RPC Fault faultString="Bad version number in .class file (unable to load class Hello)" faultCode="Server.Processing" faultDetail="null"]
      I have installed LiveCycle DataServices 3.1 with integrated tomcat(C:\lcds)
      When I executed the version.bat from C:\lcds\tomcat\bin directory it provided me this information:
      Using CATALINA_BASE:   C:\lcds\tomcat
      Using CATALINA_HOME:   C:\lcds\tomcat
      Using CATALINA_TMPDIR: C:\lcds\tomcat\temp
      Using JRE_HOME:        c:\lcds/UninstallerData/jre
      Server version: Apache Tomcat/6.0.20
      Server built:   May 14 2009 01:13:50
      Server number:  6.0.20.0
      OS Name:        Windows Vista
      OS Version:     6.0
      Architecture:   x86
      JVM Version:    1.5.0_14-b03
      JVM Vendor:     Sun Microsystems Inc.
      Please can anybody help me so make this simple call happen..........!
      I have istalled java_ee_sdk-6u1-jdk-windows and configured the classapth and path environment variable so that javac works with this version. I have compiled the Hello.java
      file with this version of java. If this is not the required version. Which version should I use?
