0 Replies Latest reply on Apr 19, 2011 3:17 AM by Dhwani_K_shah
    How to read xml file as shown below.
    Dhwani_K_shah Level 1
      Hello,
      I am using flash builder 4 and currently working on implementing AIR application.
      I need to read xml file data.
      Normal xml files are easy to read and i am much more aware of it.
      But can any one have idea how to read XML file which is given below.
      <node>
      <key>ID</key>
      <integer>1</integer>
      <key>Name</key>
      <string>Dhwani</string>
      <key>Postno</key>
      <integer>20</integer>
      <key>deskname</key>
      <string>flex</string>
      <key>empid</key>
      <integer>25</integer>
      <key>projectname</key>
      <string>abc</string>
      </node>
      Here i have xml file in form of key value pair. <key> node shows name of the key and after that <integer> or <string> node are the value for that specific key.
      if i select node.key then it shows me all the keys. and from that i cant make out what is the value for key ID.
      Is there any way to take first node and then second. i mean first i ll take value of key and store it into some arraycollection. and then value will be stored.
      Any help is appreciated.. Looking for positive reply.
      Dhwani
