This content has been marked as final.
Show 4 replies
1. Re: Merge two query results
monkey_woo_too Nov 14, 2006 5:35 AM (in response to kruse)You will most likely find trying to use Query of Query very problematic. I reccommend that you actually write a SQL statement to do the union at the DB end.
I know that it seems a bit crappy, but i think it will help you maintain your sanity. -
2. Re: Merge two query results
Dan Bracuk Nov 14, 2006 5:45 AM (in response to kruse)The best way to achieve your goal depends on what it is. Your question is very general. -
3. Re: Merge two query results
Newsgroup_User Nov 14, 2006 1:38 PM (in response to kruse)UNION could be the way to go. the query results will have to match up
between the 2 queries (field data types need to match for both queries)
<cfquery name="qryMergedQueries" dbtype="query">
SELECT * FROM query1
UNION
SELECT * FROM query2
</cfquery>
kruse wrote:
> Is it possible to merge 2 query results?
> I have a function that returns a querey result.
> < CFSET temp = query1>
> <CFSET FNCTransfers = temp>
> Now I want to change the query to return a merged query result
> <CFSET temp2 = query2>
> Is it possible to merge the two results?
> Some thing like this (I know that it cannot be done like this)
> <CFSET FNCTransfers = temp1 & temp2>
> Maby it should be a union and query of query?
4. Re: Merge two query results
kruse Nov 14, 2006 11:10 PM (in response to kruse)I had two different queryes getting internal transgers in a company and external transfers in/out of a company and then I would show a merged list of this two results.
The two queryes vere very complex and therfore I would not merge the two queryes into one query.
The query of query aproach worked very well.
