1 Reply Latest reply on Apr 20, 2011 11:48 AM by NMorkar
    Error while installing Flex Builder 4
    NMorkar
      While installing Flash Builder 4 I am getting following error.
      I am installing on Windows XP
      Exit Code: 7
      -------------------------------------- Summary --------------------------------------
      - 0 fatal error(s), 25 error(s), 0 warning(s)
      ERROR: 15080 Unable to create directory "\\cssan002\home\nmorkar\..\Adobe Flash Builder 4\.metadata
      ERROR: 15080 Command ARKCreateDirectoryV2Command failed.
      ERROR: 15080 Unable to delete directory "\\cssan002\home\nmorkar\..\Adobe Flash Builder 4\.metadata". Error 2 The system cannot find the file specified.
      ERROR: 15080 Error rolling back command ARKCreateDirectoryV2Command
      ERROR: 15078 Unable to delete file copy at "C:\Program Files\Adobe\Adobe Flash Builder 4\configuration\config.ini" Error 3 The system cannot find the path specified.
      ERROR: 15078 Error rolling back command ARKMoveFileCommand
      ERROR: 15077 Unable to delete directory "C:\Program Files\Adobe\Adobe Flash Builder 4\configuration". Error 2 The system cannot find the file specified.
      ERROR: 15077 Error rolling back command ARKCreateDirectoryCommand
      ERROR: 15015 Unable to delete file copy at "C:\Program Files\Adobe\Adobe Flash Builder 4\AMT\application.xml" Error 3 The system cannot find the path specified.
      ERROR: 15015 Error rolling back command ARKMoveFileCommand
      ERROR: 15014 Unable to delete file copy at "C:\Program Files\Adobe\Adobe Flash Builder 4\AMT\application.sif" Error 3 The system cannot find the path specified.
      ERROR: 15014 Error rolling back command ARKMoveFileCommand
      ERROR: 15013 Unable to delete directory "C:\Program Files\Adobe\Adobe Flash Builder 4\AMT". Error 2 The system cannot find the file specified.
      ERROR: 15013 Error rolling back command ARKCreateDirectoryCommand
      ERROR: 23 Deleting Registry Key - failure. Error 5
      ERROR: 4 Unable to delete file copy at "C:\Program Files\Adobe\Adobe Flash Builder 4\FlashBuilder.exe" Error 3 The system cannot find the path specified.
      ERROR: 4 Error rolling back command ARKMoveFileCommand
      ERROR: 3 Unable to delete file copy at "C:\Program Files\Adobe\Adobe Flash Builder 4\artifacts.xml" Error 3 The system cannot find the path specified.
      ERROR: 3 Error rolling back command ARKMoveFileCommand
      ERROR: 2 Unable to delete file copy at "C:\Program Files\Adobe\Adobe Flash Builder 4\.eclipseproduct" Error 3 The system cannot find the path specified.
      ERROR: 2 Error rolling back command ARKMoveFileCommand
      ERROR: 1 Unable to delete directory "C:\Program Files\Adobe\Adobe Flash Builder 4". Error 2 The system cannot find the file specified.
      ERROR: 1 Error rolling back command ARKCreateDirectoryCommand
      ERROR: The following payload errors were found during install:
      ERROR:  - Adobe Flash Builder: Install failed
