5 Replies Latest reply on Apr 20, 2011 7:27 AM by kglad
    Sound class problem
    Captain825
      Hi
      I have a Flash 8 site that plays music in the background.  When I click on one of the menu choices, the timeline jumps to another frame where the selected page is.  Once at that page, I want the background music to stop and the page's music to start.  Here is what I have:
      attached to frame 1:
      var s:Sound=new Sound();  // to initialize a sound instance s
      then attached to each page keyframe:
      stopAllSounds();
      s.attachSound("thelinkageidofthesoundthatcorrespondstothispage");
      s.start();
      When the timeline jumps to the page frame, the background music stops but the page's music doesn't start.
      Can someone tell me what I'm doing wrong?
      Thank you
      Adrian
        • 1. Re: Sound class problem
          are you assigning a linkage id to your sounds?  you need to use those linkage ids in the attachSound argument.
          that is, in your library one of your sounds sound have linkage id = "sound1". then use:
          s.attachSound("sound1");
          s.start()
          • 2. Re: Sound class problem
            Captain825 Level 1
            Thought that when a thread is marked Answered, I had to start a new one.  Know better now.
            What I did was imported a .wav file into the library, right clicked on it and selected Linkage.  In the linkage box I gave it a name "music1" and checked the Export For Actionscript and Export in First Frame options.
            Then I attached this code to frame 1: var s:Sound=new Sound();
            Then I attached this code to a keyframe on the page where the new music is to play:
            stopAllSounds();
            s.attachSound("music1");
            s.start();
            When I test the movie, the background music stops when I get to the page but the new music doesn't start.
            Thanks again for any help.
            Adrian
            • 3. Re: Sound class problem
              click your library sound.  at the top of the library panel will be a graphic representation of your sound with a play button.  click the play button.  if you hear your sound:
              right click that library sound, click properties and take a screen shot of that panel showing you have "music1" assigned as the linkage id.
              • 4. Re: Sound class problem
                Captain825 Level 1
                Here you go...
                • 5. Re: Sound class problem
                  your linkage id is incorrect.   it should be "music1", not "music1.wav".
