1 Reply Latest reply on Apr 20, 2011 1:30 AM by Lifebelt
    dragging doesn't work in AIR
    christoferek
      I have an application that works correctly in Flash.
      When I'm trying to make it to work in AIR environment it doesn't work.
      There are no errors. Just doesn't drag the canvas.
      What could cause to stop it working in AIR?
      I use Flex 4.1 SDK.
      Below you find the complete code that you can copy and paste to newly created project as AIR application.
      Chris
      <mx:WindowedApplication xmlns:mx="http://www.adobe.com/2006/mxml" layout="absolute" width="780"
          creationComplete="creationCompleteHandler()">
          <mx:Canvas id="invisible_holder" width="100%" height="100%" backgroundColor="#ff0000" backgroundAlpha="0"  />
          <mx:Canvas id="BlueCanvas" x="97" y="263" width="300" height="300" backgroundColor="blue" backgroundAlpha="0.1">
              <mx:Canvas id="RedCanvas"     x="26" y="38" width="200" height="200"  mouseDown="childMouseDown(event)"
                   backgroundColor="red">
                   <mx:Label id="dd" text="labe lll">
                   </mx:Label>
              </mx:Canvas>
          </mx:Canvas>
          <mx:Script>
              <![CDATA[
                  import mx.core.DragSource;
                  import mx.core.UIComponent;
                  import mx.events.DragEvent;
                  import mx.managers.DragManager;
                  //Variables used to hold the image's location
                  public var xOff:Number;
                  public var yOff:Number;
                  public var xThisBefore:Number;
                  public var yThisBefore:Number;
                  public var xThisAfter:Number;
                  public var yThisAfter:Number;
                  //Create the event listeners for the drag operations.
                  private function creationCompleteHandler():void
                      BlueCanvas.addEventListener(DragEvent.DRAG_DROP,dropEnter);
                      BlueCanvas.addEventListener(DragEvent.DRAG_ENTER, applicationDragEnter);
                  private function dropEnter(event:DragEvent):void{
                      xThisAfter = this.mouseX;
                      yThisAfter = this.mouseY;
                      RedCanvas.x = xOff + (xThisAfter - xThisBefore);
                      RedCanvas.y = yOff + (yThisAfter - yThisBefore);
                      changeZIndex(1);
                      RedCanvas.addEventListener(DragEvent.DRAG_DROP,dropEnter);
                      RedCanvas.addEventListener(DragEvent.DRAG_ENTER, applicationDragEnter);
                  private function changeZIndex( direction:int ): void {
                      var newIndex:int = BlueCanvas.getChildIndex(RedCanvas) + direction;
                      if( newIndex >= 0 && newIndex < BlueCanvas.numChildren ) {
                      BlueCanvas.setChildIndex(RedCanvas, newIndex );
                  //The application accepts the drag drop.
                  //(except when the user drags the red canvas over the blue canvas)
                  private function applicationDragEnter(event:DragEvent):void
                      if (event.dragSource.hasFormat("data"))
                          DragManager.acceptDragDrop(event.currentTarget as UIComponent);
                  //Start the drag drop operation
                  private function childMouseDown(event:MouseEvent):void
                      xThisBefore = this.mouseX;
                      yThisBefore = this.mouseY;
                      xOff = RedCanvas.x;
                      yOff = RedCanvas.y;
                      var data:String = "data";
                      var source:DragSource= new DragSource();
                      source.addData(data, "data");
                      DragManager.doDrag(event.currentTarget as UIComponent, source, event);
          </mx:Script>
      </mx:WindowedApplication>
        • 1. Re: dragging doesn't work in AIR
          Lifebelt
          if you need only to drag a canvas you could use startdrag and stopdrag
          something like:
                         <mx:Canvas id="BlueCanvas" x="97" y="263" width="300" height="300" backgroundColor="blue">
                         </mx:Canvas>
               <mx:Script>
                    <![CDATA[
                              BlueCanvas.addEventListener(MouseEvent.MOUSE_DOWN,startdrag);
                              BlueCanvas.addEventListener(MouseEvent.MOUSE_UP, stopdrag);
                         private function startdrag(e:MouseEvent):void
                              BlueCanvas.startDrag();
                         private function stopdrag(e:MouseEvent):void
                              BlueCanvas.stopDrag();
               </mx:Script>
          hope this help
