2 Replies Latest reply on Apr 20, 2011 3:53 AM by Tauqeer_QAU
    Squiggly with UITextfield
    Tauqeer_QAU Level 1
      Hi All
      I am using Squiggly allright with textarea but unable to do with UITextfield
      because SpellUI.enableSpelling(); takes UIComponent as an argument
      Can anyone give me an idea . how to use squiggly with UITextfield.???
        • 1. Re: Squiggly with UITextfield
          mssrivatsa
          Hi
          The following may help you:
          1.Download the squibbly package.
          2.It has src, lib and example folders.
          3. Open a flex project and in libs folder copy all the contents of squibbly/libs folder
          4. Similarly copy all the contents of squibbly/src to your src folder in flex application
          Now in your flex application try this code
          <mx:Application xmlns:mx="http://www.adobe.com/2006/mxml" layout="vertical"
          creationComplete="application1_creationCompleteHandler(event)">
          <mx:Script>
          <![CDATA[
          import com.adobe.linguistics.spelling.SpellUI;
          import mx.events.FlexEvent;
          protected function application1_creationCompleteHandler(event:FlexEvent):void
          // TODO Auto-generated method stub
          SpellUI.enableSpelling(textArea, "en_US");
          </mx:Script>
          <mx:TextArea id="textArea" width="20%" height="20%" fontSize="20" text="Test Speling in TextArea "/>
          </mx:Application>
          Hope this Helped You
          Regards,
          M.S.Srivatsa
          • 2. Re: Squiggly with UITextfield
            Tauqeer_QAU Level 1
            I have done all this, it is working with textarea.
            But I am not able to use Squiggly with UITextfield
