4 Replies Latest reply on Apr 20, 2011 10:55 AM by LeeVDuhl
    Sample Script Reqest
    LeeVDuhl
      Looking to get started doing some PS scripting and I'm looking for a sample that does the following to get me started.  I plan to take any sample provide and uses it as a basis for my final goal.
      Looking for a script that does the following:
      - Opens a series of documents (images) from a source folder
      - Performs the following on each document
           - Applying some filter (any filter would work, but my goal is to apply a Lens Correction filter)
           - Saving the modified document off in a target folder as a JPG
           - Renaming original.
      I have already used the default "ImageProcessing" script along with a Lens Correction Action I created and that worked, but I have to process "millions" of images and that is not really a vialble solution.
      My final solution is expected to process photos in batches from a single source, included logging and and additional image processing and be scaleable.  For now I'm just looking for some assistance to get me started.
      Lee.
        • 1. Re: Sample Script Reqest
          Your sample can be found here "C:\Program Files\Adobe\Adobe Photoshop CS5\Presets\Scripts\Image Processor.jsx"
          Others can be found here http://www.ps-scripts.com/bb/
          • 2. Re: Sample Script Reqest
            xbytor2 Level 4
            If you really have to process large amounts of images, I would not use JS in PS as your primary control software.
            I would use perl (my personal preference) to do all of the file management, logging, etc... and use a PS droplet
            called from the perl script to do whatever actual image processing needs to be done. I've written scripts that run
            for days at a time processing tens of thousands of images at a shot but getting this to work corrrectly and
            reliably purely in PS JS can be a daunting task. It's better now then back in CS2 days when the JS layer
            was not quite as robust as it is in CS5 but it still takes a good deal of effort to make it happen.
            • 3. Re: Sample Script Reqest
              LeeVDuhl Level 1
              Thanks for the info. I have actaully been looking at that script but it did not click to use that as the sample basis.
              Lee.
              • 4. Re: Sample Script Reqest
                LeeVDuhl Level 1
                Thanks for the info.  I don't have any experience with Perl, but I do with C# which I assume would work also.  Pearl is always an options should C# not work.
                Lee
