29 Replies Latest reply on Jun 7, 2011 1:07 AM by Peter Grainge
    after compiling successfully, can't view
    luviola10 Level 1
      In RH8, I've compiled successfully, per the RH
      message, BUT in the Output View it says the following:
      Fatal Error: Unexpected error from Microsoft HTML compiler.
      Secondly, when I click on the View button to view the .chm, nothing happens.
        • 1. Re: after compiling successfully, can't view
          luviola10 Level 1
          This is the error I
          got when trying to open my .chm file
          • 2. Re: after compiling successfully, can't view
            luviola10 Level 1
            This issue has changed. After compiling, now I get no window that states it compiled the .chm successfully, do I want to view it, etc.? Plus when I go to where I've directed the .chm file to go, I get this message:
            This program cannot display the webpage
            Now I've tried the open the file again and I get the first error:
            • 3. Re: after compiling successfully, can't view
              My guess is you are generating to a network location. Generate to your hard drive.
              See http://www.grainge.org/pages/authoring/chm_mspatch/896358.htm for why you cannot generate to a network drive.
              @petergrainge
              • 4. Re: after compiling successfully, can't view
                luviola10 Level 1
                No, I am generating to my c: hard drive!!
                • 5. Re: after compiling successfully, can't view
                  RoboColum(n) Level 5
                  Can we go back a step? Can you compile any project successfully? If not, try running the HTML Help Diagnostics package available here. This can often find issues with the compiler and fix them.
                    The RoboColum(n)   @robocolumn   Colum McAndrew
                  • 6. Re: after compiling successfully, can't view
                    luviola10 Level 1
                    Okay, thanks, Colum.
                    I ran the diagnostics report and I'm copying it below. Can you help me interpret this?
                    MJ's Help ReportMJ's Help Report
                    A common problem with HTML Help 1.x is DLLs not correctly registered during
                    installation. This utility checks all components and registers DLLs if required.
                    We also report if the RoboHelp DLL is registered, and if MS Help 2 components
                    are installed and registered.
                    After running the report, try running your program again to see if the fault has
                    cleared.
                    General Info
                    Report EXE:            C:\Documents and Settings\ryangx\Local Settings\Temp\wz03a6\MJsDiag.exe
                    Report Run Date:       4/21/2011 9:41:13 AM
                    Report EXE Version:    2.7.2.0
                    Download URL:          http://helpware.net/downloads/ System:       Windows NT 5.1.2600
                    SysLocale.DefaultLCID:  0x0409 (1033)
                    SysLocale.PriLangID:    0x0009 (9)
                    SysLocale.SubLangID:    0x0001 (1)
                    DecimalSeparator:       .
                    Operating
                    HH Installed:           YES
                    HH Version:             5.2.3790.4110
                    HH Friendly Version:    > 1.4a
                    H2 Installed:           NO
                    H2 Version:
                    IE Installed:           YES
                    IE Version:             6.0.2900.6058
                    IE Friendly Version:    Internet Explorer 6 (Windows XP SP2)
                    NT Administrator
                    NT Admin Check: Current user has full administor privileges: YES
                    HTML Help Run-time Components
                    File Registered OK: C:\WINNT\system32\hhctrl.ocx (Version: 5.2.3790.4110)
                    File Registered OK: C:\WINNT\system32\itss.dll (Version: 5.2.3790.4186)
                    File Registered OK: C:\WINNT\system32\itircl.dll (Version: 5.2.3790.2453)
                    File Found: C:\WINNT\system32\hhctrl.ocx
                    Version = 5.2.3790.4110
                    Registry Info: {adb880a6-d8ff-11cf-9377-00aa003b7a11}
                       ClassName = HHCtrl Object
                       InProcServer32 = C:\WINNT\system32\hhctrl.ocx
                       ProgID = Internet.HHCtrl.1
                    DLL is Found and Registered OK = YES
                    File Found: C:\WINNT\system32\itss.dll
                    Version = 5.2.3790.4186
                    Registry Info: {5D02926A-212E-11D0-9DF9-00A0C922E6EC}
                       ClassName = Microsoft InfoTech IStorage System
                       InProcServer32 = C:\WINNT\system32\itss.dll
                       ProgID = MSITFS1.0
                    File Found: C:\WINNT\system32\itircl.dll
                    Version = 5.2.3790.2453
                    Registry Info: {4662DAA5-D393-11D0-9A56-00C04FB68BF7}
                       ClassName =
                       InProcServer32 = C:\WINNT\system32\itircl.dll
                       ProgID = ITIR.WordWheelBuild.4
                    For HH Version Info See: http://helpware.net/htmlhelp/hh_info.htm
                    HTML Help 1.x Registry Settings
                    Description: If present this Key can disable HH Shortcuts and HH WinHelp commands on the local PC
                    Reference: KB 810687, KB 323180
                      Key: HKEY_LOCAL_MACHINE\SOFTWARE\Policies\Microsoft\Windows\System\
                      Value: HelpQualifiedRootDir (string value) =
                      -> Report: Policy is not enabled. HH Shortcuts are not restricted on local machine.
                    Description: This key can be used to enable Hhctrl.ocx ActiveX Visual controls on servers
                    Reference: KB 892675
                      Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\HHRestrictions
                      Value: UrlAllowList (string value) =
                      Value: MaxAllowedZone (string value) = 2
                      -> Report: Settings reported for information only.
                    Description: This key allows MS programs such as iexplore.exe to open ITS file that do not have a .CHM file extension
                    Reference: KB 873343
                      Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\HelpRestrictions\AllowedExtensions
                      -> Report: No special file extensions have been enabled on this PC.
                    Description: This key can be used to allow access to remote ITS files
                    Reference: Win 2003 SP1, KB 896054
                      Key: HKEY_LOCAL_MACHINE\SOFTWARE\Microsoft\HTMLHelp\1.x\ItssRestrictions
                      Value: NestedProtocolList (string value) =
                    For HH Registry Info See: http://helpware.net/htmlhelp/hh_info.htm#hh14
                    HTML Help 1.x Workshop Components
                    *** HH Workshop not found or not installed correctly. Try reinstalling.
                    File not found: C:\Program Files\itcc.dll
                    File Found: C:\WINNT\system32\hha.dll (Version: 4.74.8702.0)
                    KeyHelp OCX by Keyworks.net - KeyHelp.ocx
                    This is for information only. KeyHelp is a 3rd party DLL.
                    *** KeyHelp.ocx is not registered or not installed!
                    *** You can register your KeyHelp.ocx using the "Register a DLL" button.
                    *** KeyHelp.ocx could be installed anywhere on your PC by normally resides in the Windows System folder.
                    For More Info See: http://keyworks.net/
                    RoboHelp DLL by eHelp/Macromedia - HHActiveX.dll
                    Registration Info: {399CB6C4-7312-11D2-B4D9-00105A0422DF}
                       Version = 8.0.0.203
                       ClassName = HHComponentActivator Class
                       InProcServer32 = C:\Program Files\Adobe\Adobe RoboHelp 8\RoboHTML\HHActiveX.dll
                       ProgID = HHActiveX.HHComponentActivator.1
                    Dll Found and Registered = YES
                    For More Info See: http://www.macromedia.com/
                    MS Help 2 Run-time Components
                    *** MS Help 2 NOT installed on this PC
                    Advert: Sick of spending $1000's of dollars every year on Authoring Tools?
                          Shareware program FAR replaces MS Help 1.x and 2.x Workshops, and contains
                          many HTML time saving tools. Go to http://helpware.net/FAR/
                    • 7. Re: after compiling successfully, can't view
                      Jeff_Coatsworth Adobe Community Professional & MVP
                      Looks like you're missing or have a damaged copy of Microsoft's HTML Workshop - try uninstalling it & re-download it from MS's website.
                      • 8. Re: after compiling successfully, can't view
                        luviola10 Level 1
                        Colum,
                        In response to your question whether another project was able to compile successfully, yes I was able to compile another project and view the .chm without a problem.
                        • 9. Re: after compiling successfully, can't view
                          Try as Jeff said. Download and install the Microsoft HTML Workshop from here. If this doesn't work, there must be something in your project that is causing the issue. Have you added some content recently? Take a copy of your project, remove half the content and compile. If it works you know the problem is with the other half. Repeat the process until you find the topic at fault.
                          • 10. Re: after compiling successfully, can't view
                            luviola10 Level 1
                            thank you , Jeff. I will try that. but first, since I was able to compile and view another project chm file, I feel the problem with the first project may be somewhere in the project files. what about that? For one thing, I inherited these two projects from another writer who set up the projects. I have not had the opportunity to discuss anything with this writer, so I'm trying to just follow and add material.
                            • 11. Re: after compiling successfully, can't view
                              luviola10 Level 1
                              okay, I ran the HTMLhelp.exe, and I got the message: It's already installed on this machine. So, after looking back at the Report, this also looked like an error:
                              what do you think?
                              • 12. Re: after compiling successfully, can't view
                                Probably an issue with the project - try Colum's advice to find the offending topic.
                                • 13. Re: after compiling successfully, can't view
                                  luviola10 Level 1
                                  I've found a topic with a red x and wouldn't allow me to vi
                                  ew. Then RH shut down.
                                  Advice? should I delete it?
                                  • 14. Re: after compiling successfully, can't view
                                    Assuming you've made a backup of the project; sure, go ahead & see if that's your problem topic.
                                    • 15. Re: after compiling successfully, can't view
                                      luviola10 Level 1
                                      okay, I deleted it and another topic that
                                      was red. I recompiled and got the same message about Fatal Error. But the screen saying it compiled successfully appeared, I tried to view the chm but nothing. Same problem..
                                      • 16. Re: after compiling successfully, can't view
                                        luviola10 Level 1
                                        okay, I've fixed all the issue I could find in all my topics. I still get the message when I compile:
                                        and my question is: what is mk:@MSITStore: in the path name?
                                        • 17. Re: after compiling successfully, can't view
                                          You could try these links that have solutions.
                                          http://www.robworley.com/2005/03/what-does-cannot-open-the-file-mkmsitstore-mean/
                                          http://www.tomshardware.co.uk/forum/55394-35-open-files-cannot-open-file-msitstore
                                          I'm not sure they will work though as they involve registering certain DLLs and I would have thought that if that is the problem, it would affect all CHMs.
                                          After preparing the above I looked through the second thread and found something that seems to fit your scenario as it would apply to just one CHM being affected. Your path has brackets in it, something I would always discourage.
                                          Give this a try first.
                                          I finally found out that the error was caused because the name of the directory containing the .chm files had non-English characters. After changing the directory's name to simple English - everything works.
                                          @petergrainge
                                          • 18. Re: after compiling successfully, can't view
                                            luviola10 Level 1
                                            Hi Peter,
                                            yes, do you mean the parentheses around the words NERC Restricted?  (NERC_Restricted)?  If so, I have renamed the file removing these and replacing them with underscores, that is, _NERC_Restricted_. After renaming, I tried to open the file but got the error "This program can't display the web page."
                                            • 19. Re: after compiling successfully, can't view
                                              MergeThis Level 4
                                              Is it simply the total length of the path?
                                              If you copy this file to the C:\ drive root and rename it to callout_notnerc.chm, will it open then?
                                              Leon
                                              • 20. Re: after compiling successfully, can't view
                                                luviola10 Level 1
                                                okay. I've copied below what I see at the bottom of the output file:
                                                Warning: The size of stop file has to be limited in 512 bytes.
                                                Warning: Data loss in converting Topic of Contents data using choosen language.
                                                C:\Documents and Settings\ryangx\My RoboHelp Projects\Adobe RoboHelp 8\Callout Guide\!SSL!\Microsoft_HTML_Help\!chm_tmp_folder_0\Callout_Guide_(NERC_Restricted).hhp
                                                Microsoft HTML Help Compiler 4.74.8702
                                                Compiling c:\Documents and Settings\ryangx\My RoboHelp Projects\Adobe RoboHelp 8\Callout Guide\!SSL!\Microsoft_HTML_Help\Callout_Guide_(NERC_Restricted).chm
                                                Callout_Guide_(NERC_Restricted).hhc
                                                Finished compiling HTMLHELP in 54 sec(s)
                                                Compilation complete.
                                                any suggestions?
                                                • 21. Re: after compiling successfully, can't view
                                                  I think your folder length is way too long - try putting the project in your c:\projects\ folder off the root.
                                                  • 22. Re: after compiling successfully, can't view
                                                    Three things.
                                                    Ignore. You will always get that.
                                                    Could be relevant but I don't know what language settings you have applied. I would be surprised if multiple languages are supported in CHMs but I don't work with them much and then only in English.
                                                    Path
                                                    Two people have mentioned the length and I have mentioned the brackets that are still there.
                                                    @petergrainge
                                                    • 23. Re: after compiling successfully, can't view
                                                      luviola10 Level 1
                                                      SUCCESS!  I removed one folder from the path and Voila! Compiled, was able to view .chm and was able to open .chm.
                                                      Peter, I don't know what you refer to as "brackets." do you mean the parentheses around "NERC_Restricted?" I did not remove the parentheses and it compiled fine. Also, looking over the project files, there are many, many topics with parens () in them.
                                                      thanks to everyone who helped me through this.
                                                      • 24. Re: after compiling successfully, can't view
                                                        You asked that in an earlier post and indicated you had worked out what I meant by brackets.
                                                        That was when you stopped getting the dialog in your second post in this thread but, as far as I can make out, you then started getting Page Cannot be Displayed messages. That seems to have stopped now that you have shortened the path length.
                                                        Are you saying that the brackets () are back in and that ONLY the path length is shorter? If so I am puzzled as if that was the sole problem, why did the message change when you removed them?
                                                        @petergrainge
                                                        • 25. Re: after compiling successfully, can't view
                                                          luviola10 Level 1
                                                          Well, when I removed the parens the system allowed me to do
                                                          it, but when I compiled, they were back. I don't know why. I inherited the project files from another writer who initially put the parens in. I am still trying to sort it all out, truthfully!
                                                          • 26. Re: after compiling successfully, can't view
                                                            Look in the first field of the layout. That is where the brackets are coming from.
                                                            @petergrainge
                                                            • 27. Re: after compiling successfully, can't view
                                                              luviola10 Level 1
                                                              Peter, thank you. I was able to go to the Layout pod, open properties of the primary layout (MS HTML here) and I took out the parens around Nerc Restricted.
                                                              • 28. Re: after compiling successfully, can't view
        hsb3852 Level 1
        Hi Peter,
        Despite the the message "Warning: The size of stop file has to be limited in 512 bytes." in the Output View pod, the compilation of my RH9 HTML project completed successfully, and my CHM file works properly as far as I have checked.
        In your post of Apr 25, 2011 11:18 AM you say to ignore the message as it will always appear. Why is that? What is the significance of this warning?
        best regards,
        Hylton
        • 29. Re: after compiling successfully, can't view
        It's an annoying bit of logic in the Microsoft Compiler. The stop file does have that limit but it displays it whether your file has 1 byte or way over 512 bytes. Think of it as a speed restriction sign, it's there whether or not you are speeding.
        @petergrainge
