0 Replies Latest reply on Apr 20, 2011 9:40 AM by digitlman
    CS5.03 PNG still export broken and pixelated
    digitlman Level 1
      I just did a couple hours of testing on this and have determined that you can't export a proper PNG still from a DV NTSC sequence.
      The picture is pixelated like it is half rez or one field.
      I used a resolution chart for testing and it doesnt matter if i have gpu on or off, or previews rendered or not it still is pixelated.
      i can render out a tiff,bmp, or targa file with lower field first setting and they all look perfect. if i try upper field or progressive they all look bad,
      there are no field settings for PNG so apparently it only does one field it seems?
      With that thought i made a desktop editing sequence, 720x480 with no fields and put my rez chart in it and it exported perfectly to png.
      the issue for me is i need the alpha channel from the PNG file. I have a collection of premiere titles that i need to put in our chyron for a live production.
      Making a desktop sequence is a functional workaround for this but i thought you should know this seems to be a legit bug that should be fixed by Adobe.
      thanks
