1 Reply Latest reply on Apr 20, 2011 7:16 PM by Frustrated in AZ
    transfeering to Kobo
    Walt.Agnes
      I am having difficulty transferring a book from my pc to my Kobo. A Kobo online chat did not solve the problem. He suggested that I come here. The Adobe Digital Editon is authorized. My Kobo was set to 'Manage Library' but nothing happened.
        • 1. Re: transfeering to Kobo
          Level 4
          Ah, but is your Kobo reader activated with Kobo's website?  That's the first
          thing.
          You didn't say what the 'problem' was, so my response might cover some
          ground you have been over before....
          Once your Kobo ereader is activated with Kobo's website, you can plug it
          into your computer as a USB drive.  When your computer recognizes it and
          assigns it a drive letter, then start ADE.  When ADE comes up, it will
          recognize your Kobo ereader, and it should show your Kobo ereader in the
          left hand panel of its Library view.  It's simple after that: drag and drop
          the book from the right hand library onto your Kobo.
          After you've loaded your Kobo up, you need to close ADE, and eject the Kobo
          ereader from yor computer.  Leave the Kobo plugged in until it tells you
          it's finished updating itself with the new content.  Then you can pull the
          plug and you're set to read.
          There are some catches.  The books you're downloading will have certain
          permissions granted by the publisher.  If you get an error message during
          your drag and drop that tells you you can't do that, it may be that the
          publisher has not authorized copying it to an ereader.  That's the main
          one.  Others might crop up during the linkup and relate to the way the Kobo
          is authorized.  If that happens, come back here and search the Forum for
          those particular error messages.
          Hopefully, it will be straightforward and no problems.
          Hope this helps!
