2 Replies Latest reply on Apr 21, 2011 7:04 AM by Ned Murphy
    Sum
    sensiblemind Level 1
      hi all
      i made 8 input txt  and one Dynamic to collect all the input in it
      here is the code
      ///////////// Dynamic text
      var GF_w:Number = 0;
      //////////////////////////// input texts
      var w_1:Number = 0;
      var w_2:Number = 0;
      var w_3:Number = 0;
      var w_4:Number = 0;
      var w_5:Number = 0;
      var w_6:Number = 0;
      var w_7:Number = 0;
      var w_8:Number = 0;
      ////////////// BUTTON
      collect__mc.onPress = function()
      GF_w = w_2+ w_1+ w_3 + w_4 + w_5 + w_6 + w_7 + w_8;
      BUT it seems like there is something wrong
        • 1. Re: Sum
          you should be using the text property of your textfields, not their associated variables.  and, you need to cast those strings as numbers:
          var w_1:Number = 0;
          var w_2:Number = 0;
          var w_3:Number = 0;
          var w_4:Number = 0;
          var w_5:Number = 0;
          var w_6:Number = 0;
          var w_7:Number = 0;
          var w_8:Number = 0;
          GF_w = Number(w_2)+ Number(w_1)+Number( w_3) + Number(w_4) + Number(w_5) + Number(w_6) + Number(w_7) + Number(w_8);
          • 2. Re: Sum
            How can you tell something seems wrong?
            You are probably using the variable (var) property of the textfield, which is not a recommended practice (likely why it no longer exists in newer Flash versions).  It is unreliable at best.  You should just assign instance names to the textfields and work with the text property of the textfield, converting to Number values as needed.
