Thanks for the response, Colum.
>> There is no way I can think of to do this with
snippets
Maybe in RH9 ...
I thought that this is the typical sort of thing that Single
Sourcing should do.
>> but you could use variables. Just change the
variable value for the text as required.
Ummm ... can 't see how that would work. I need all the
different topics (identical except for a few words) in the same
project at once.
>> Alternatively, I'd be tempted to have a dummy
project with all the instances of the text in seperate topics which
you could then import as and when required.
Not sure this would help me. I have three topics, which are
almost identical, except for a few words.
I have a very simple, "square, vanilla" idea that would do
it. Just have a dummy topic with all the material, but where the
words differ, I would substitute searchable place holders, one or
more as needed, for the word instances,
e.g.,"!<feature_name>!" . Then I can import or copy-paste
that material section as needed and then do a Find-Replace on
"!<feature_name>!" to insert the words I need for the
specific topic. But this is very lo-tech. I would have expected
something better in 2009.
Maybe you meant the same thing, but in different words.
- avi
