12 Replies Latest reply on Jul 2, 2011 11:38 AM by Jooni Oy
    Photoshop CS5 Applescript
    Sympa-Inspir
      Hi there. I am trying to figure out whit this script works with CS4 however using the same action and the exact same script with CS5 it no longer works. Help?
      This is the script.
      on adding folder items to thisFolder after receiving theseFiles
      tell application "Finder"
      -- move psd files to temp folder
      repeat with thisFile in theseFiles
      if name extension of thisFile is "psd" then
      move thisFile to folder "temp" of thisFolder
      end if
      end repeat
      set thePSDFiles to every file of folder "temp" of thisFolder as alias list
      set saveFolder to (folder "save" of thisFolder) as text
      end tell
      tell application "Adobe Photoshop CS5"
      launch
      repeat with thisFile in thePSDFiles
      open thisFile showing dialogs never
      tell current document
      do action "CROPFLATTEN" from "SYMPA" -- action and set name, case sensitive
      save in (saveFolder & name) as PNG with copying
      close saving no
      end tell
      end repeat
      end tell
      -- move .psd files left in temp folder to save folder
      move thePSDFiles to folder saveFolder
      end tell
      end adding folder items to
        • 1. Re: Photoshop CS5 Applescript
          Tom Ruark Adobe Employee
          This is a known problem and here is a workaround for your CS5 version. From my colleague Jon...
          In CS5, the interpretation of "alias/file/folder" object was broken. We have to ask the user to change the object from alias/file/folder to text/string outside Photoshop, then cast the text/string as file/alias in PS.
          If this user change a little bit of the script, it should work for him:
          Change
          to
            set myFolder to (path to folder "temp" of thisFolder) as string
            set thePSDFiles to name of every file of folder "temp" of thisFolder
          Change
          to
             open alias (myFolder & thisFile) showing dialogs never
          Change
          to
              save in (saveFolder & thisFile) as PNG with copying
          Change
          to
            move (every file of folder "temp" of thisFolder) whose name extension is "psd" to folder saveFolder
          This should work. But I haven't tried it myself. Might need some tweak.
          • 2. Re: Photoshop CS5 Applescript
            Sympa-Inspir Level 1
            I modified the script to this - as you suggested.
                           end if
                      end repeat
                 end tell
                      launch
                                close saving no
                           end tell
                      end repeat
                 end tell
                      move ((every file of folder "temp" of thisFolder) whose name extension is "psd") to folder saveFolder
                 end tell
            However it doesnt open the files within photoshop CS5. It will move the files from the main folder to the temp folder located within the main folder. Nothing further happens though.
            • 3. Re: Photoshop CS5 Applescript
              Muppet Mark-QAl63s Level 4
              -- Make sure sub folder exists
              if not (exists folder "temp" of thisFolder) then
              set tempFolder to make new folder at thisFolder ¬
              with properties {name:"temp"}
              else
              set tempFolder to folder "temp" of thisFolder as alias
              end if
              -- Ditto here…
              if not (exists folder "save" of thisFolder) then
              set saveFolder to make new folder at thisFolder ¬
              with properties {name:"save"}
              else
              set saveFolder to folder "save" of thisFolder as alias
              end if
              move thisFile to tempFolder
              end if
              end repeat
              -- Get the file list
              set thePSDFiles to every file of tempFolder as alias list
              end tell
              -- Coerce each alias to string
              set thisFile to thisFile as string
              activate
              open alias thisFile showing dialogs never
              if mode is not RGB then
              change mode to RGB
              end if
              flatten
              --do action "CROPFLATTEN" from "SYMPA"
              save in file ((saveFolder as string) & name) as PNG with copying
              close saving no
              end tell
              end tell
              end repeat
              end tell
              This works fine here although Im no great fan of FAS… I just comment out the action call as I don't have this available…
              • 4. Re: Photoshop CS5 Applescript
                Thank you so much! All I had todo with this was uncomment the action portion and change CS4 to CS5.
                Perfect. If you have paypal I'll gladly send you a tip!
                sympa@me.com
                Finished Script:
                          else
                          end if
                          -- Ditto here…
                          else
                          end if
                               end if
                          end repeat
                     end tell
                               activate
                                         change mode to RGB
                                    end if
                                    flatten
                                    close saving no
                               end tell
                          end tell
                     end repeat
                     end tell
                • 5. Re: Photoshop CS5 Applescript
                  I have one more question. Is there any way to conver this script to a stay open application that will check the last modified date of the main folder "Folder2" ?
                  I found this script wich illustrates the principle but I cant get it to work.
                  In short.. could anyone conbine these two scripts?
                  property targetPath : "sneJ:Shared Folders:Jens Public:Drop Box:" -- path to target folder
                  property targetFolder : 0 -- target folder alias (set at startup)
                  property modDate : 0 -- mod date of folder when last checked
                  on run
                       set targetFolder to alias targetPath -- get alias to the folder
                  end run
                  on idle
                       set newModDate to modification date of (info for targetFolder)
                       if modDate = 0 or newModDate > modDate then
                            set modDate to newModDate
                            folderChanged(targetFolder)
                       end if
                       return 3 -- Idle time in seconds
                  end idle
                  on folderChanged(f)
                       beep
                       -- Put anything you want here, and it'll run whenever the
                       -- folder is modified. See the “What's New?” sample script
                       -- for a more sophisticated example,  which figures out what
                       -- files have been added and displays their names to the
                       -- user.
                  end folderChanged
                            else
                            end if
                            -- Ditto here…
                            else
                            end if
                                 end if
                            end repeat
                       end tell
                                 activate
                                           change mode to RGB
                                      end if
                                      flatten
                                      close saving no
                                 end tell
                            end tell
                       end repeat
                       end tell
                            set finalFolder to folder "Untitled:Users:sympa:Desktop:finalfolder"
                            set initialFolder to folder "Untitled:Users:sympa:Desktop:Folder2:save"
                            move everyFile of initialFolder to finalFolder
                            set label index of everyFile of finalFolder to 5
                       end tell
                  • 6. Re: Photoshop CS5 Applescript
                    Funny… thats other thing you can do with AppleScript that Im no great user or fan of… Stay open apps… What is much nicer is adding your scripts to iCal event alarms. Its very flexible, a piece of cake to set up… Nothing need be running either…
                    • 7. Re: Photoshop CS5 Applescript
                      Alright, If I wanted to attach this to an ical event alarm how would I do that and how would that benefit me more? What im trying todo is make sure no files get "missed". I need every file within the drop folder to get processed even if two users are dropping items simultaneously.
                      • 8. Re: Photoshop CS5 Applescript
                        The reason Im no fan of these is they tend to be a little erratic at times… (been called that myself) When testing the script I posted there can be a lag in response to the items added event some times it no trigger at all. The problem being there is little or nothing you can do when this is the case… Personally I always find these scripts the most difficult to get right. You do have several options available to you but knowing a little more about the work flow would be of help… iCal can run AppleScripts that are added to calendar events. I've also had it run ESTK scripts too although I have not checked now that CS5 appears a little fussier over it's script locations… Bridge scripting has a 'schedule tasks' but it requires it be running. iCal can do the same need not be running.
                        • 9. Re: Photoshop CS5 Applescript
                          Alright Mark. Youve been super hepful so far so I have one last question. This is being run on a separate computer as a server. Occaisionally when a user has dropped files a file will be corrupt and photoshop cannot open the file. When this occurs the entire script hangs and waits for input. It requires me to keep checking on the computer and forcing photoshop to continue. Is there a way I can force photoshop to skip this corrupted file if it throws an error?
                          I saw another post of yours here using the method below. However I cant seem to get the try block to play well with photoshop when I tried to combine it and my current script. Whenever I used the try block, the script would skip photoshop altogether and simply begin moving the file. Help please!
                          try
                          with timeout of 2 seconds
                          open The_File
                          end timeout
                          on error
                          tell application "System Events"
                          tell application process "Adobe Photoshop CS2"
                          keystroke return
                          end tell
                          end tell
                          end try
                          property lastModDate : 0 -- mod date of folder when last checked
                          global targetFolder, saveFolder
                          on run
                             -- set targetFolder as an alias on first run
                             set targetFolder to alias "ACTION:Users:Shared:Hotfolder"
                              -- create the save folder if it doesn't exist; store its path as text
                                  if not (exists folder "save" of targetFolder) then
                                     make new folder at thisFolder with properties {name:"save"}
                                  end if
                                 set saveFolder to folder "save" of targetFolder as text
                             end tell
                          end run
                          on idle
                             -- 'info for' is deprecated, so getting mod date from the Finder
                                  set currentModDate to modification date of targetFolder
                             end tell
                              if lastModDate = 0 or currentModDate > lastModDate then
                                 set lastModDate to currentModDate
                                 ProcessNewItems()
                              end if
                             return 120 -- Idle time in seconds
                          end idle
                          on ProcessNewItems()
                              with timeout of (30 * 60) seconds —30 min timeout
                                      -- move psd files to save folder, go back to idle if there are none to process
                                     set thePSDFiles to move ¬
                                          (every file of targetFolder whose name extension is "psd") ¬
                                     if thePSDFiles = {} then return
                                 end tell
                                     -- Coerce each alias to string. files are in Finder file specs, so use the Finder
                                          set thisFile to thisFile as text
                                     end tell
                                          activate
                                         set display dialogs to never
                                     end tell
                                          activate
                                                 change mode to RGB
                                             end if
                                             flatten
                                             -- do action "CROPFLATTEN" from "SYMPA"
                                             save in file (saveFolder & name) as PNG with copying
                                             close saving no
                                         end tell
                                     end tell
                                 end repeat
                                      set finalFolder to folder "ACTION:Volumes:photobasearchive:hotfolder:finals"
                                      move every file of folder saveFolder to finalFolder
                                     delete every file of folder saveFolder
                                  end tell
                             end timeout
                          end ProcessNewItems
                          • 10. Re: Photoshop CS5 Applescript
                            Im currently at work and have no access to my snippets… But the example posted in this forum does work. What you need is a 'try/on error' inside of a short time out statement… Say 10 seconds dependent on your images and how long you expect to take to open… Photoshop will not error in these situations but AppleScript will from the timeout… in the on error call a sub-routine to do the keystroke. That should be it. It looks like we may get a change in this behavior in future releases Tom has requested it… I can't do any of this using the ESTK…
                            • 11. Re: Photoshop CS5 Applescript
                              Is this the correct code then?
                              on run
                                   set targetFolder to alias "ACTION:Users:Shared:GAP_PNG:process"
                                        end if
                                   end tell
                              end run
                              on idle
                                   end tell
                                        ProcessNewItems()
                                   end if
                                   return 60 -- Idle time in seconds
                              end idle
                                   with timeout of (30 * 120) seconds
                                                       to folder saveFolder with replacing
                                        end tell
                                             end tell
                                                  activate
                                                  try
                                                       end timeout
                                                  on error
                                                            tell application process "Adobe Photoshop CS5"
        keystroke return
                                                            end tell
                                                       end tell
                                                  end try
                                                            change mode to RGB
                                                       end if
                                                       if exists path item "crop" then -- check if there is a path called crop, if so do action, else flatten and save
                                                            flatten
                                                            close saving no
                                                       else
                                                            flatten
                                                            close saving no
                                                       end if
                                                  end tell
                                             end tell
                                        end repeat
                                             set temps to folder "ACTION:Volumes:photobasearchive:hotfolder:_temps"
                                             if not (exists folder "ACTION:Volumes:photobasearchive:hotfolder:_temps:GAP_PNG") then
                                                  make new folder at temps with properties {name:GAP_PNG}
                                             else
                                                  set finalFolder to folder "ACTION:Volumes:photobasearchive:hotfolder:_temps:GAP_PNG"
                                                  delete
                                                  move every file of folder saveFolder to finalFolder with replacing
                                             end if
                                             -- set the label index of every file of folder finalFolder to 7 -- grey
                                        end tell
                                   end timeout
                              end ProcessNewItems
                              • 12. Re: Photoshop CS5 Applescript
                                Jooni Oy Level 1
                                HI.
                                I can't "AppleScript"...  but get a feeling that this has something to do with the issue I came across:
                                In earlier versions of photoshop (e.g.CS3) in OSX I was able to move a PSD file that was still to a new folder and the path of the file would update automatically in PS without me having to close the file. I could see the new path by cmd+clicking the title bar. This is one of the most beautiful things in OSX, I think, and it works in most programs. It allows me to re-organize files on the fly and still continue working with them. Very efficient.
                                But I just noticed now -- first serious job with the new CS5.5 in my new iMac -- that this no longer works in Photoshop. Now if I want to move a file I have to close it, move it and reopen.
                                Is there a workaround for this issue? Or maybe my issue has nothing to do with this post?
