7 Replies Latest reply on Apr 23, 2011 7:16 AM by phil_Free
    Project doesn't load anymore
    phil_Free
      Hey everybody,
      I'm actually working on a mid-complex project with several afx-comps (using dynamic link) and a bunch of  Photoshop-graphics editing in Premiere. Everything worked fine until this morning. When I  started my machine, no graphical media or afx-comps load up. I tried  auto-save-files and older versions aswell. Still the same.
      I already relinked the Photoshop-datas manually, but the more serious problem is the dynamic link to After Effects or to be more accurate:
      The project doesn't load up anymore. After Effects freezes and has to be killed. Not even older versions or auto-saves. A new project works fine.
      I'm  working on a MacPro (late 2009), 12GB RAM, Bootdevice: Intel SSD,  Projectdatas: internal software raid1, Videodatas: internal software  raid0
      (backup on nas via timemachine). No disc errors or hardware failures found so far.
      Softwareversion Adobe CS5.0.3 Production Suite
      Footage: Canon xf305 (but this works fine!)
      Maybe you have any idea? Thanks a lot!
      Philipp
        • 1. Re: Project doesn't load anymore
          phil_Free Level 1
          It came up to my mind, to reinstall cs5.
          But now the next strange thing comes up: I'm not able to, as photoshopserver and dynamiclink are still active.
          But I don't know how to kill them.
          Suggestions welcome.
          • 2. Re: Project doesn't load anymore
            Dave LaRonde Level 6
            You didn't mention anything about it, so I'd start with these potentially easy fixes first:
            • Restart your Mac, and see what happens.  No joy?
            • Shut down your Mac, go get a cup of coffee, start it up again, and see what happens.  No joy?
            • Repair permissions, open the AE project and see what happens.
            It might be that simple.
            • 3. Re: Project doesn't load anymore
              phil_Free Level 1
              You're right. It was the cup of coffee in the sun.
              Now I reinstall the suite and see if the dynamic link works as it should be.
              Thanks a lot.
              • 4. Re: Project doesn't load anymore
                phil_Free Level 1
                So far, I reinstalled the suite but now I cannot update to the actual version:
                "Adobe QT32 Server" and "PhotoshopServer" have to be closed. But how?
                And the basic problem is not solved by the way: still my AFX project doesn't load and dynamic link is broken. The medias are not linked again.
                And yes, I tried reboots and shut downs. And I even did some sport just not to freak out.
                Dave, would you mind to give me a hint how to repair permissions on mac os? I'm very unexperienced with that issue.
                Thank you,
                Philipp
                • 5. Re: Project doesn't load anymore
                  Sorry, no.  I don't have system administrator privileges on my Mac at work.  You'll have to look it up in help.
                  • 6. Re: Project doesn't load anymore
                    phil_Free Level 1
                    Just an update:
                    With disc utilities I repaired the permissions.
                    I reinstalled cs5 production premium.
                    I updated it to the actual version (flash occured an error, but the other ones were fine)
                    I opend the project: no links to most of the media.
                    I relinkt all media - except the dynamic links to After Effects. That just doesn't work.
                    I saved the project on a different drive with a different name.
                    Opend the new project and - again - most of the files didn't link again! Missing more than 10.000 links to jpegs, psds, mxfs.
                    I opend the new and the old project on another mac - same results.
                    I think, repairing permissions with disc utility doesn't affect Adobe's software (Apple says that some 3rd Party Applicaton might not be affected.)
                    I found a workflow for repairing permissions in the case of updating-failure, but I didn't try that, as I don't want to make things worse.
                    Is there a way to repair CS5 permissions "internal"?
                    Thanks in advance,
                    Philipp
                    • 7. Re: Project doesn't load anymore
                      phil_Free Level 1
                      Thank you for the tips so far. I found some useful infos but I'm still unhappy.
