8 Replies Latest reply on Apr 28, 2011 10:30 AM by kglad
    MovieClip click problem
    melas076
      Hi!
      I have a problem with this code:
      targetClip.onRelease = function() {
          trace("OK");
          modelnamemc.play();
      when i click on it isn't work at all why?
      can someone help me plz
      regards,
      MELAS
        • 1. Re: MovieClip click problem
          if you don't see the trace(), you have a path/name problem with targetClip.  if you see the trace, you have a path/name problem with modelnamemc
          • 2. Re: MovieClip click problem
            melas076 Level 1
            i did another btn and put this code and it is working well
            but not my modelnamemc at all!!!!
            modelnamemc is loaded an external images from xml!!!
            i want to be clickable...
            how can i do?
            regards,
            MELAS
            • 3. Re: MovieClip click problem
              if modelnamemc is the target movieclip of a loadMovie() method, you must wait until loading is complete to assign a mouse handler to modelnamemc.  in addition, no where in the code you showed are you attempting to add a mouse handler to modelnamemc and applying a play() method to the target of a loaded bitmap makes no sense.
              • 4. Re: MovieClip click problem
                melas076 Level 1
                thanks for your help.
                but how can i do it?
                • 5. Re: MovieClip click problem
                  melas076 Level 1
                  Can you help me?
                  I try a lot of time but still not find it!!!!
                  thanks in advance!!!
                  • 6. Re: MovieClip click problem
                    for example,
                    modelnamemc.loadMovie("whatever.swf");
                    clearInterval(preloadI);
                    preloadI=setInterval(preloadF);
                    function preloadF():Void{
                    if(modelnamemc.getBytesLoaded()>=modelnamemc.getBytesTotal()){
                    mouseHandlerF();
                    function mouseHandlerF():Void{
                    modelnamemc.onRelease=function(){
                    //do whatever
                    • 7. Re: MovieClip click problem
                      melas076 Level 1
                      thanks for your help!!!!
                      unfortunatly it doesn't works :
                      there is the code:
                      targetClip.loadMovie(txtimage1);
                      if(targetClip.getBytesLoaded()>=targetClip.getBytesTotal()){
                      mouseHandlerF();
                      targetClip.onRelease=function(){
                      modelnamemc.gotoAndStop(2);
                      • 8. Re: MovieClip click problem
                        if textimage1 is correctly defined (ie, your image loads), use:
                        mouseHandlerF();
                        this.gotoAndStop(2);
