1 Reply Latest reply on Apr 24, 2011 1:00 PM by George_Johnson
    Change Field Values with Adobe Dialog Manager?
    Matt_Stantec Level 1
      Hello.
      I currently have my dialog setup.
      I have a text field on my page that is named: text_name
      When I enter in the dialog box, how do I set the text_name field to this value after OK button is pressed?
      Current Dialog Code:
      var myDialog =
           // Event handler to initialize the list_box
           initialize: function(dialog)
                dialog.load({
                "sub1":
                     // Create a radio Check named sub1 and set up 4 choices:
                     "Reviewed": 0,
                     "Reviewed and Resubmit": 0,
                     "Not Reviewed": 1,  // currently selected item
                     "Not Accepted": 0
           commit: function(dialog)
                // Retrieve the values stored in list_box sub1:
                var elements = dialog.store();
                // Iterate through items and take actions as needed
                for (var e in elements["sub1"])
                     // If the value is positive, it was selected:
                     if (elements["sub1"][e] > 0 )
                          // display the list value selected:
                          app.alert("You chose:\n" + e);
                          // call a related function for the selection
                          rc = elements["sub1"][e];
                          ListHandler(rc);
           // Dialog object descriptor (root node)
           description:
                elements:
                     type: "view",
                     align_children: "align_left",
                     elements:
                               type: "cluster",
                               elements:
                                         type: "static_text",
                                         name: "Enter Your Full Name",
                                         font: "default"
                                         type: "edit_text",
                                         char_width: 21,
                                         item_id: "sub1",
                                         font: "default"
                                         type: "radio",
                                         item_id: "sub1",
                                         group_id: "gp1",
                                         width: 200,
                                         height: 25
                                         type: "radio",
                                         item_id: "sub1",
                                         group_id: "gp1",
                                         name: "Reviewed As Modified",
                                         width: 200,
                                         height: 25
                                         type: "radio",
                                         item_id: "sub1",
                                         group_id: "gp1",
                                         name: "Revise and Resubmit",
                                         width: 200,
                                         height: 25
                                         type: "radio",
                                         item_id: "sub1",
                                         group_id: "gp1",
                                         name: "Not Reviewed",
                                         width: 200,
                                         height: 25
                                         type: "button",
                                         item_id: "butnn",
                          type: "ok_cancel"
      // Function to handle the user's list selection:
      function ListHandler(rc)
           switch (rc) {
                case 1:
                     app.alert("Reviewed");
                     break;
                case 2:
                     app.alert("Reviewed As Modified");
                     break;
                case 3:
                     app.alert("Revise and Resubmit");
                     break;
                case 4:
                     app.alert("Not Reviewed");
                     break;
                default:
                     app.alert("Invalid Selection");
                     break;
      rc = app.execDialog(myDialog);
