1 Reply Latest reply: Apr 23, 2011 10:45 AM by plutonak RSS
    batch conversion from CS5 to CS4
    plutonak Community Member
      Hi all,
      is there a way to automatically convert CS5 Illustrator files to CS4 illustrator files using Illustrator CS5: I do not want to open them one by one and save them. Thanks
        • 1. Re: batch conversion from CS5 to CS4
          ok, sorry I found it on the help menu
          Play an action on a batch of files
          Saving files using the Batch command options always saves the files in the same format as the original files. To create a batch process that saves files in a new format, record the Save As or Save A Copy command, followed by the Close command, as part of your original action. Then choose None for the Destination when setting up the batch process.
