4 Replies Latest reply: Apr 24, 2011 1:49 PM by therayman RSS
    ePub errors
    therayman Community Member
      Converting to ePub using ID CS5 appears to work well and they do work in a reader but when I verify it, I always get errors. The most common is a problem with the date format in the content opf file. The epub also has unknown author even in Digital Editions. No author, title information other than the identifier appears to have been added to content opf. Is this normal? Do I have to do it manually and No I'm not interested in 5.5 - that carrot won't meet my deadline.
        • 1. Re: ePub errors
          [Jongware] Community Member
          The Date problem is a well-known one, and normally I'd suggest you to search the forum ... but Search Forum doesn't work.
          This thread: http://forums.adobe.com/thread/722581 is found using Google, and I think it describes a solution.
          ... and No I'm not interested in 5.5 - that carrot won't meet my deadline.
          The good news is that it (allegedly) solves this particular problem.
          • 2. Re: ePub errors
            DerekC1000 Community Member
            InDesign CS5 can automatically export metadata if you enter information in the file Information dialogue box. Do this on the cover file (usually one JPG): File > File Info…  There are only certain fields that can be completed: Document Title; Author; Description; Keywords (which are separated by commas or semi-colons); and the Copyright Status. Only these items will be exported to ePub. Put the metadata in the cover file, if it’s put elsewhere it will be ignored. Additional metadata can be entered in the Digital Edition Export Option panel: the name of the Publisher and the unique identifier (usually the ISBN). Tick the Include Document Metadata box in the same panel. Good luck!
            • 3. Re: ePub errors
              All very good and as you say the search was down. A much easier solution is
              to use eScape with Open Office which works perfectly first time, no messing
              about required and its free.  Adobe lags behind yet again....
              • 4. Re: ePub errors
                Thanks but I had managed to do that and even fixed the date. Then I found
                eScape which does it all for you. Great when your in a hurry...
