4 Replies Latest reply on Apr 25, 2011 7:41 AM by dzelst
    Dynamic Form list/menu
    dzelst
      I'm trying to insert a dynamicly generated form list/menu dropdown item.
      Everything works but the list always shows me the last record from the database as the first item in the list (ASC or DESC).
      I want to put a dummy label as the first item in the list like: Select from list
      How can i do this, because even if i put a static value in the value list items, it still shows the last item from the recordset first instead of the static value.
      Does anybody have an idea how i can create a dynamic pulldown list in my form with the first item listed to be a statich dummy tekst or label like "Select from list etc"
        • 1. Re: Dynamic Form list/menu
          Level 4
          For those that are not looking over your shoulder or reading your mind it helps if you provide your code.
          • 2. Re: Dynamic Form list/menu
            dzelst Level 1
            I created a normal recordset with Dreamweaver getting tea
            m_id and team_names out of the database. Then i list the teamnames in a form list/
            menu (dropdown) to show all the available teams. Again it shows me the last record from the
            recordset as the first list item and i want a standard "select this" text or something default.
            The form code below is generated by dreamweaver itself. I already tried to also put one static value in the value list property but i get the same result. To me it looks like the while loop is overriding whatever you put as static text.
            <form id="form1" name="form1" method="post" action="">
              <label for="list_teams">Teams:</label>
              <select name="list_teams" id="list_teams">
                <?php
            do {
                <option value="<?php echo $row_Teams['team_id']?>"<?php if (!(strcmp($row_Teams['team_id'], $row_Teams['team_id']))) {echo "selected=\"selected\"";} ?>><?php echo $row_Teams['team_name']?></option>
                <?php
            } while ($row_Teams = mysql_fetch_assoc($Teams));
              $rows = mysql_num_rows($Teams);
              if($rows > 0) {
                  mysql_data_seek($Teams, 0);
               $row_Teams = mysql_fetch_assoc($Teams);
              </select>
            </form>
            • 3. Re: Dynamic Form list/menu
              Level 4
                <option value="" selected="selected">Select This</option>
                  <?php
              do {
                  <option value="<?php echo $row_Teams['team_id']?>"><?php echo $row_Teams['team_name']?></option>
                  <?php
                if($rows > 0) {
                </select>
              </form>
              • 4. Re: Dynamic Form list/menu
                dzelst Level 1
                Thanks!!  Looks like i used
                one field to many in the dynamic property window. It works now.
