6 Replies Latest reply on Jul 6, 2011 1:18 AM by lucsc
    FLEX PHP RPC
    lucsc
      Hi all,
      (sorry for my bad english)
      I'm working with flex 4 sdk and I tried to integrate flex and php with rpc.
      I have a little problem with this architecture. The problem is:
      I have table called 'user' in sql with columns: userid, email, password.
      I've created simple flex app. Flex created for me AS code and PHP code with DATA\SERVICES.
      I have methods:
      -count()
      -createUser(item:User):int
      -getAllUser():User[]
      If I want to select all users I have in my db I'm drag and drop getAllUser() method on DAtaGrid and configuring creation complete on datagrid.
      Everything is OK. RPC is OK.
      But...
      If I want to create user with createUser method I must have the 'item' type 'user' from valueobject.
      I created the item in AS code. I also update my flex code with button with click method generated automatically.
      My problem is the RPC not created new user in my db.
      But if i choose test operation it;s working.
      my code below:
      php
          public function createUser($item) {
              $stmt = mysqli_prepare($this->connection, "INSERT INTO $this->tablename (email, password) VALUES (?, ?)");
              $this->throwExceptionOnError();
              mysqli_stmt_bind_param($stmt, 'ss', $item->email, $item->password);
              mysqli_stmt_execute($stmt);
              $autoid = mysqli_stmt_insert_id($stmt);
              mysqli_stmt_free_result($stmt);
              mysqli_close($this->connection);
              return $autoid;
      as
          public function createUser(item:valueObjects.User) : mx.data.ItemReference
              var _internal_operation:mx.rpc.AbstractOperation = _serviceControl.getOperation("createUser");
              var _internal_token:mx.data.ItemReference = _internal_operation.send(item) as mx.data.ItemReference;
              return _internal_token;
      flex
                     xmlns:mx="library://ns.adobe.com/flex/mx"
                     minWidth="955" minHeight="600" currentState="home" xmlns:userservice="services.userservice.*">
          <fx:Script>
                  import mx.controls.Alert;
                  import valueObjects.User;
                  protected function button_clickHandler(event:MouseEvent):void
                      var item : User;
                      item.email = 'asd';
                      item.password = 'asd';
                      createUserResult.token = userService.createUser(item);
      </fx:Script>
          <fx:Declarations>
              <s:CallResponder id="createUserResult"/>
              <userservice:UserService id="userService" fault="Alert.show(event.fault.faultString + '\n' + event.fault.faultDetail)" showBusyCursor="true"/>
          </fx:Declarations>
          <s:Group x="0" y="0" width="100%" height="100%">
              <s:Button includeIn="home" x="102" y="246" label="create" id="button" click="button_clickHandler(event)"/>
          </s:Group>
      </s:Application>
      any ideas, helps and solutions are helpful
        • 1. Re: FLEX PHP RPC
          Chris.1234
          I have the same problem!
          Did you solve it?
          • 2. Re: FLEX PHP RPC
            lucsc Level 1
            Hi Chris.
            I was thinkin' a lot of time to solve this.
            And I get an answer.
            Instead of using zend i user amfphp from official.
            They got very simple documentation and a lot of samples which works.
            If You want more infos/code sample (mine) write reply.
            Ciao
            • 3. Re: FLEX PHP RPC
              Chris.1234 Level 1
              Here is a nice tutorial:
              http://www.adobe.com/devnet/flex/testdrive/articles/2_modify_the_database.html?PID=4176632
              But an alternative is also very nice
              Can you send more infos etc?!
              Thx..
              Mit freundlichen Grüßen / Kind regards
              Christian Meurisch
              Am 05.07.2011 23:29, schrieb lucsc:
              Hi Chris.
              Ciao
              • 4. Re: FLEX PHP RPC
                kokorito Level 4
                you havent instantiated the item
                var item:User = new User();
                • 5. Re: FLEX PHP RPC
                  Chris.1234 Level 1
                  Yeeah, that's right!
                  But this wasn't the solution of the problem...
                  Problem is that the data service call (only create & update - generated
                  php method and service calls by flash builder) doesn't leave the flash
                  player tho' the send method will be called!
                  When I try the TestOperation of Flash Builder, it works! -> mysterious =)
                  Christian Meurisch
                  Am 06.07.2011 01:28, schrieb kokorito:
                  • 6. Re: FLEX PHP RPC
                    lucsc Level 1
                    Yeap.
                    You're right. I forgot initialize new User().
                    Main thing witch isn't created using auto generated flash builder service calls is class mapping between PHP classes and AS3 classes.
                    I dont use zend becasu it's very advance.
                    I use simple amfphp from official website. ( try google )
                    If You need I can share my code with You.
                    ciao
