2 Replies Latest reply on Apr 25, 2011 6:20 AM by nlk10010
    AddChild/RemoveChild Problem
    nlk10010 Level 1
      Hi, I had posted this in the FlashBuilder forum but someone very kindly suggested I post it here instead. So that's what I'm doing.
      I'm using FlashBuilder4 (set to Flex 3.5SDK for compatibility) and am running into an issue with RemoveChild/AddChild.
      I have a TabNavigator component with several tabs, each tab utilizing a canvas as its child component.
      What  I'd like to do is to be able to click a button and have one of the  tabs, say the first (index 0) inaccessbile, then to make it accessible  upon clicking another button. My first thought was to disable the canvas  for the first tab, but I don't see a property for that (i.e. no  tabnavigator1.getChildAt(0).enabled property). But I DO see a "visible"  property; unfortunately, doing a "tabnavigator1.getChildAt(0).visible =  false" in the button's click handler doesn't seem to work. So I settled  on removeChild. Clicking the first button calls a handler with  "tabnavigator1.removeChild(canvas0)", where canvas0 is the child of the  first tab, works fine. Unfortunately, to restore the child I use, in the  clickhandler of the SECOND button,  "tabnavigator1.addChildAt(canvas0,0);tabnavigator1.selectedIndex = 0"  and this does cause the first tab to be selected BUT THE CONTENTS OF THE  PREVIOUSLY DISPLAYED TAB OVERWRITE CANVAS0 (sorry for shouting, just  wanted to emphasize).
      The above seems to be an issue (for  me at least) with addChild, since when I started playing with the new  way FlashBuilder handles states, using Add/Remove Child, I would see the  same type of behavior; i.e. one tab's contents overwriting another's.
      Has  anyone run into this issue (I've searched and don't see anything)?  Failing that, any ideas what might be going on and what to do to  correct/workaround this issue?
      Thanks.
        • 1. Re: AddChild/RemoveChild Problem
          Lee Burrows Level 4
          hi
          not sure if it will fix your problem but you can enable/disable Canvas.
          instead of this:
          tabnavigator1.getChildAt(0).enabled = false;
          do this:
          (tabnavigator1.getChildAt(0) as Canvas).enabled = false;
          (FB doesnt know what kind of object getChildAt(0) is, so you have to help it out by specifying the type)
          • 2. Re: AddChild/RemoveChild Problem
            nlk10010 Level 1
            Well that certainly makes sense and is definitely worth a try, although I wonder why Flex itself doesn't realize this when it creates the code for various states. This issue definitely crops up when simply using the UI to create those states.
            Thanks for the post. I'll let you know what happens.
