This content has been marked as final.
Show 3 replies
1. Re: Can I stream live video from mobile to fms using flashlite?
rajdeeprath Apr 24, 2011 11:00 AM (in response to Prasad Web Designer)Try this out:
2. Re: Can I stream live video from mobile to fms using flashlite?
Prasad Web Designer Apr 24, 2011 10:19 PM (in response to rajdeeprath)Hi Raj
Thanks for your reply. But, I need some open source.
Can I stream the live event from my mobile to FMS using Flashlite and Symbian C++
Prasad.
3. Re: Can I stream live video from mobile to fms using flashlite?
egyhots1 Aug 27, 2011 11:30 AM (in response to Prasad Web Designer)i have made a few test with Flash Lite 3.0 and Flash Media Server 3 and I have to say that it is pretty easy to stream FLV Video files and Live Video from local web camera to mobile phone. Here are a quick instructions how to do it in Windows (I will publish Linux version later).
Play FLV-video from Flash Media Server 3:
- Install Flash Media Server 3 (download developer version)
- There are a few sample FLV files in applications/vod/media folder, so you can use one of them for testing
- Create a new Flash Lite 3.0 file in Flash
- Add a new Video symbol to library
- Drag this Video symbol to Stage and give instance name to it: video
- Type following programming to timeline:
// make a new video-object
var video:Video;
// make a new NetConnection-object
var nc:NetConnection = new NetConnection();
// check connection status from server
nc.onStatus = function(info:Object):Void {
status_txt.text=info.code;
if (info.code == "NetConnection.Connect.Success") {
startStreaming();
// start streaming video to phone
function startStreaming() {
ns = new NetStream(nc);
ns.setBufferTime(5);
video.attachVideo(ns);
// play sample.flv from server
ns.play("sample",0);
// show info to user
status_txt.text = "Connecting server...";
// connect FMS 3 video on demand service (default port 1935)
nc.connect("rtmp://your.server.ip.here:1935/vod");- Go to Publish Settings...
- Set Local playback security: Access network only
- Publish your SWF-file
- Send your SWF-file to your phone
- Test and you should see FLV-video playing in your phone
Play live video from Flash Media Server 3:
- Install Flash Media Encoder 2 (Windows only)
- Start Flash Media Encoder 2
- You should see your live camera in Input screen
- Press Start-button to start sending live video to Flash Media Server 3
- Add Video symbol and programming as you did earlier
- Modify your programming:
// in startStreaming()-function
// Flash Media Encoder 2 publish stream name is "livestream"
ns.play("livestream",-1,-1,true);
// start connection to Flash Media Server 3
// Flash Media Encoder 2 publishes Flash Media Server's default
// live publishing point, so connect it
nc.connect("rtmp://your.server.ip.here:1935/live");- Publish, test and enjoy
